Kiko 8.1 - cute kitsune, stands on her own without a "seasonal passport" or the like
1356
  • evacynevacyn Posts: 993
    She's cute and I really like the bundle. The Maho Outfit (https://www.daz3d.com/dforce-maho-outfit-for-genesis-81-female) sleeves are removable, which is pretty great and the extra textures have this beautiful pattern which I love.
  • KrzysztofaKrzysztofa Posts: 226
    There was a thread here talking about folks desire for more "asian/eastern high-fantasy" wear. I think this Maho outfit is a step in that direction for sure. I really like it.
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    edited June 2021
    Okay, simple-ish test render with Kiko.
    Blended Kiko 8.1 (65%) with Kanade 8 (35%), then tweaked the nose a very little bit. I stayed in the "Stylized" bracket here, not "Realism".
    I tweaked all the SSS maps for more contrast. (Actually, took the Diffuse maps, increased brightness & also cranked up contrast to recreate SSS maps.) I don't know if they helped reduce the "plastic" of the skin, but it was worth a look.
    I took out all the foxy hair bits. They are well done but heavy, and my machine kind of gags on them all. It's probably the SBH settings, but I didn't have time to sift through and mess with them. (Again, it takes knowledge of Daz to mess with all of that... let alone diagnose what's causing things to drag or hang.)
    Again, I think she's really nice, but she probably needs a little Daz knowledge to know what is working and what does not work for your particular setup.
    Post edited by The Blurst of Times on
    Worlds_Edge said:
    @wonderland you can get similar and sometimes better effect through this photoshop plugin - https://graphicriver.net/item/cartoon-maker-clone-photoshop-plugin/28654885#:~:text=Clone is Photoshop smart plugin,special Photoshop or drawing skills.
    I just used it an will show you how it came out.
    If you add a curve or some other method to make it lighter, it is probably almost exactly like the befunky version.
    Thanks, but it looks a bit too filtery for me when I look at the samples zoomed in large on their site and it’s overpriced. Although your image looks a lot better than the ones on the filter sales page! In general, I like having the capability to have images fairly large for wall prints and don’t like that filtery look so mostly do things by hand. But for small images, it looks pretty decent.
    edited June 2021
    For some reason I’m having a big problem making her look good. I don’t understand the PBR shader, I’ve been fiddling with it for like two hours and still not happy. Thank god for post.
    Can anyone get the fur on the ears or tail to look like the promo? Mine isn’t even close. Not sure what I’m doing wrong. And she takes expressions horribly and no matter what I do, her skin looks awful. Fred looked amazing compared to her. I’m wasting too much time trying to make her look decent, can’t get the fur to work. I might return the whole bundle... I think I’ll stick to G8.
    ETA, so here you can see that the fur on the tail renders but the tail underneath is invisible no matter what I do while the fur on the ears doesn't look like fur. Anyone able to get it to work???
    1388 x 1840 - 307K
    Post edited by Wonderland on
    @brimstoneomega, that looks like an AprilYSH hair to me. Can't think of the name of it, but browse her catalogue here at the store and you should see it.
    brimstoneomega said:
    Alright, so after sleeping on her I'm on the fence a bit about the bundle. I'm probably just going to get the sailor outfit, hair, and Kiko herself, don't really need the poses, and I have a few outfits that are close enough to the Poison Love one that I don't really need it.
     Might give it a bit more thought, but I can save a bit of my Daz money opting that way. The free stuff I could get I've picked over too many times and don't need any of that, so while I could get a few things, nothing is anything I'd likely use much. Those monster skulls have been tempting me for years though...
    Can anyone tell me which hair this is? I really like the way it looks on her, especially this rainbow texture.
  • PetraPetra Posts: 1,157
    This hair is by LLF and should be coming out soon.
    hmm maybe not. My first thought was that it is Eilis Hair but the parting is wrong.
    LOL I was just looking through LLF's catalogue here to see if I could match it, cos she was the other one I thought of. :)
    I keep getting the odd feeling that Kiko 8.1 is a Lady Littlefox character actually.
  • The Ear Fur makes my system crashy. I guess I have too much of a potato to handle the density of hairs.
    I'm not going to bother with her tail because I have other fox tails that work. (I don't know what would make the inner Tail prop invisible. Bizarre.)
    Kiko's skin? I re-did all the SSS maps to fit what I like. I didn't think the default Kiko SSS maps would work for me.
    That's the only tweak that I did to the PBR setup for Kiko, and I didn't get a grey-skin girl... but I kind of like the PBR and I've been messing around with it.
    Another render baking on my potato, so time to go do some chores...
    She mixes quite well with other shapes if you turn down just a bit.
  • SeraSera Posts: 1,675
    The Keiko Monique mix from the promos reminds me of Billie Eilish. Just need to widen the tip of her nose a bit.
    1200 x 1200 - 90K
    762 x 1710 - 2M
    Were you using premade expressions? Maybe the face rig thing would work better? The issues with her tail and ears are a bummer.
    I couldn’t even render this image. It crashes my whole computer every time. I have a 1080ti. I see others are rendering without the fur but if I turn it off, there’s no tail underneath for me. It’s there, I can see it in the viewport on texture shading, I see everything in surfaces but it doesn’t show up in iRay preview although the fur does. And something is causing it to crash every time I hit render...
    As far as expressions, I’m using the 8.1 expressions, but like G3 and Thorne characters, the mouth doesn’t take expressions well.  The way things are going I may return the whole bundle.
    With the ear and tail hair turned on, Daz Studio becomes very crashy for me. Almost after every dForce sim, I'd get a crash as soon as I tried to render.
    Otherwise enjoying this character a lot. I think she pairs well with Aiko 8 in scenes.
    If I turn off all the fur, I can render without crashing but the tail underneath it becomes invisible when I render although I can see it in the viewport in texture preview. I don’t understand this product...
  • Oso3DOso3D Posts: 15,119
    The tail is intentionally invisible; it provides good structure for the tail fur, and if you have enough tail fur it's not necessary.
    But if you look at my image above, you can see through the fur and see that there’s no tail there. I put in so much time into this stupid thing now, I’m just going to see if I can render the tail separately without crashing and put it together in Photoshop and even add fur from the tail to the ears IF I can get the fur to render at all without crashing.
  • j cadej cade Posts: 2,310
    That image looks to be in the viewport yes? like most dforce hairs, the tail does not render at full density in Iray preview
    That makes sense. I couldn’t render or it would crash. But if I hide everything else, I can render the tail separately and it doesn’t crash. Maybe if I just do her head with the ear fur separately and hide everything else, it might work. So much for thinking a 1080ti was a good graphics card...
    edited June 2021
    also fwiw the tail fur isn't bad in terms of resources.
    The ears are heavy
    more than a gb calculating the hair geometry
    thankfully there is some easy calculation you can do to improve your life
     PR Hair density *  line width = visible density
    so if you make there be half as many strands but each strand is twice as thick it looks a silikar density but with half the strands so half the mesh needed
    PR Interpolation Segment Length is the other setting you can tweak
    compare ears that use 1.252 gb
    vs ears that now use 377mb
    For the 377mb version I halved the Density, doubled the line with and doubled the interpolation width
    also a simple material preset that applies just those settings youll need haver already picked the fur color you want and have the ear fur selected
    800 x 1040 - 453K
    800 x 1040 - 466K
    duf
    duf
    Lower Memory Fur.duf
    6K
    Post edited by j cade on
  • benniewoodellbenniewoodell Posts: 2,001
    The ears are heavy
    Thank you for explaining how this works, it makes a lot of sense.
  • Okay, I'll have to try that with the Ear hair... I figured it was hair density, but I don't play with the hair enough to know how to do all that.
    Now back to the rendering...
    Blend of Kiko 8.1 (65%) and Aiko 8 (35%), minor nose adjustments, and then I increased the butt (and I cannot lie).
    Thank you both! I had a feeling it was a LLF hair and checked her catalog but didn't see it. The rainbow texture reminded me of a few of her hairs that I have.
    (That sounds really bad out of context, lol)
    Very pretty! I decided to just pick a few items out of her bundle. Can't wait to render her up a bit.
  • Mr BowenMr Bowen Posts: 404
    There is a "No Brow" option for normal and HD versions. Apply it and then the makeup.
    The price is a good deal for all that is included in comparison to other "8" characters when they debut.
    602 x 603 - 309K
  • AprilYSHAprilYSH Posts: 1,522
    Looks like a classic Lady Littlefox to me :)  I've not seen it before, maybe it will be out with another Kiko bundle - and that's NOT to say there will be another bundle, I'm kinda out of the loop with so much stuff going on! %}
  • Kaye KayeKaye Kaye Posts: 210
    edited June 2021
    No post work and a bit of a mixing with the head and HD. The tail needs to be added from anatomy - it's an attachment and vanishes when you add the fur materials.
    Her skin works better in certain lights - not so well in this one - so I'm going to play more.
    1000 x 1500 - 710K
    Post edited by Kaye Kaye on
    Yeah, the adjustment of line width and hair density is a great way to adjust. The further away the subject is, the lower quality you can get away with (to a point, and not all fur setups are as forgiving)
    Yeah, I am not fond of the skin as it is, which is why I am recreating the SSS maps for my own purposes. The SSS maps feel like they are simply lighter/more white versions of the Diffuse, and that just tilts things towards 255,255,255.
