Carrara Community Art Gallery - Show us your Renders!!!
1181921232460
  • magaremotomagaremoto Posts: 1,238
    edited May 2021
    testing DOF and glare
    3440 x 1935 - 5M
    Post edited by magaremoto on
    converted to carrara.  stillfighting with saving the pose presets in carrara.  the poser presets move the figure back to center
    1280 x 720 - 687K
    edited May 2021
    tee hee   500 percents bump amplitude
    1280 x 720 - 696K
    1280 x 720 - 120K
    1280 x 720 - 636K
    Post edited by Mistara on
    Headwax said:
    May be an image of 9 people
    apparenty according to forum software this maybe an image of 9 people
    kewl.  reminds me of that Bosch painting.  think it was called garden of unearthly or earthly
  • StezzaStezza Posts: 8,804
    edited May 2021
    it's cold outside!
    800 x 600 - 844K
    Post edited by Stezza on
    playing with the pbr plugin and displacement and replication.
    is any tricks to make tiling jpg look not so tiled?
  • HeadwaxHeadwax Posts: 10,434
    an underutilised carrara characteristic - nice work with the dof - could be magical!
    Stezza said:
    it's cold outside!
    Nice visual joke there Stezza :) Yep wind goes stright through today!
    effective job on the flowers on the ground !
    to get rid of that tiling look - one approach I have tried but doesnt work perfectly is to add a mixer to the colour channel,
    then use the same two textures i n both resulting channels but flip one texture on its side
    then put eg cellular or noise in the blend channel
    export the resulting texture at 4028
    then in PS use the clone brush to obliterate as much of the tiling effect as possible,
    then reuse that modified texture on the plane back in carrara
    edited May 2021
    thanks.  i should do more with the blend in shaders.
    rendered another surface rep diaster.  some are floating, some sinking.  meh    randomized the wrong options.
  • DartanbeckDartanbeck Posts: 21,984
    magaremoto said:
    thx DB, well it mainly depends on good maps and lighting; G8 Hersilia has very good maps suitable for testing sss in carrara, what I actually do is create a skin shader usable for any lighting condition, by tweaking color and sss channels
    here are 2 screenshots: in the first you can see how doubling the map and invert its color you can make skin more or less reddish (it counts a lot), in the second one you can check my simple sss settings; normally I act on color tab and intensity slider only.
    maps with white or pink background (like Hersilia's) work better in carrara; translucency is needed only for ears shader most of times
    about lighting, I suggest to keep it simple, just a good irradiance map and a bit of sky light, as in my shot, it speeds up rendering times considerably
    Thanks Magaremoto! I'll try playing with this more.
    Very cool renders, all!
    absolutely
    DOF, glare, haze and light fog are all part of my realistic scene settings
    the guys behind carrara did a great work indeed
    magaremoto said:
    absolutely
    i second  that, wonder where they are now....
    my pleasure DB, most of time a good map has all we need to get an effective realism, as body scans can prove
    edited May 2021
    trying to match camera and lighting between carrara and 3delight
    3440 x 1935 - 1016K
    1920 x 1080 - 426K
    i like your ui color scheme
    Rynne after the toe fix.  starting to think it was worth it.  lol
    mixed in fitness. and breast gone for a fey look.
    1280 x 2297 - 1M
    1280 x 2297 - 1002K
    edited May 2021
    thx Misty, gold and bright green are good colors to stimulate creativity. I really appreciate your commitment on G8 figures, thx again
    here is the iray matching at the moment
    1920 x 1080 - 395K
    Rosita.  pbr
    2048 x 2048 - 186K
  • cynthia1968cynthia1968 Posts: 36
    edited June 2021
    That's awesome Mystiara.
    I'm working on an animation, this is a screen caputer of the titile screen, introducing the first main character....
    1900 x 957 - 3M
    Post edited by cynthia1968 on
    i'm doing something wrong with the eyes.
    all that work on the eyelashes looks terrible.  sigh
    2048 x 2048 - 2M
  • DiomedeDiomede Posts: 15,393
    Wow so much going on since I last checked in this thread.
    - magaremoto, the realism and lighting in these latest renders are top notch.
    - Misty, glad you are getting these funky characters in Carrara with the DUF plugin.  Agree, something is up with the eyelash shader, or the eyelash is being distorted somehow.  Otherwise, looks amazing.
    - cynthia1968, wow, you are still getting amazing results with the classic figures.  You and UB should offer a thread of older figure tips and tricks.  I am looking forward to the animation.  Great stuff.
    discovering not all layered make up is of the same quality.  thought i had it licked but some are showing anti aliasing lines.
    alas experimenting lead to some interesting summing and gaussian filter stuff
    https://www.daz3d.com/forums/uploads/FileUpload/a5/1e36d9c48d0779ad20c64aabc33437.jpg
    1024 x 1024 - 84K
    more playing with pbr + HDR.  needs some softbody on the straps, theoretically should work.
    200
    1024 x 1024 - 368K
    learned the dyn hair shaders is more than just colors.  saves stuff like strand thickness.
    oblivion01a.hdr
    4096 x 4096 - 4M
    this is what she supposed to look like https://www.daz3d.com/leony-character-clothing-and-hair-bundle ; lol
    2048 x 2048 - 2M
    edited June 2021
    thx Diomede laughcool
    here a test to reduce by half the render time and act in post to get a decent realistic outcome:
    a- final render
    b-logarithmic lut
    c-final result
    2880 x 1620 - 997K
    2880 x 1620 - 1014K
    2880 x 1620 - 4M
    here is an animation test, poor flickering, 29 minutes/frame
