Is it possible to do motion blur inside of Daz Studio with Iray?
Fae3DFae3D Posts: 2,927
Is it possible to do motion blur inside of Daz Studio with Iray?  I'm doing a scifi speeder chase scene, and it would be hard to render the background separately because of all the lights that it is casting.
  • xyer0xyer0 Posts: 6,518
    I don't think so, but I've done motion blur using 3Delight with IBL Master (to help match the renders) and composited it with the main Iray render.
  • I don't think there is? There are some things that do a faux motion blur, but if you're doing a custom background, then probably not without rendering separately... but that is why you mess with the Iray Matte pass, IMO.
    Select all background stuff, turn on advanced iray properties, enable Iray Matte... makes everything else a light/shadow-catcher, then run background separately.
  • QuasarQuasar Posts: 709
    I have seen that motion blur has been added to the newer versions of Iray. I'm not sure if DS has a way to implement it, though. Hopefully they will add it into DS soon if they haven't yet.
  • Fae3DFae3D Posts: 2,927
    Hmm, I kinda thought that there wasn't an easy way to do it in Iray, but I figured I'd ask.  Unfortunately, advanced Iray properties are WAYYYYY beyond me.  I'll figure something out with compositing.
    Thanks, everyone, for your comments, I appreciate it!
  • MoreTNMoreTN Posts: 340
    Don't know if this is of any use - it's a free tutorial from Dreamlight but I haven't watched it myself -
  • HylasHylas Posts: 5,345
    I happen to have just done a motion blur experiment!
    I used Photoshop (also works in GIMP) to add motion blur, then used a depth map as a layer mask.
    Gallery link
  • KinichKinich Posts: 941
    There is this product to help create motion blur effects within Daz Studio Blur Crazy I've used it a couple of times but now I need to find the images.
    1. New Horizons - Used it to blur the propeller on top of the balloon.
    1214 x 2000 - 988K
    edited May 2021
    Aha!  That's what I need.  I can't pick it up in time for this project, but I've got it wishlisted for later.  Thank you!
    And thank you, everyone, for the tutorials, I'll watch those and see if I can get some good ideas!
    Post edited by Fae3D on
    You're welcome, I couldn't locate the street scene I was playing with a while back but here is a quick test of a car speeding along a street, Blur props applied to the two wheels in view and a props cylinder applied to the scene, scaled and positioned to go around everything but the car, you need to remember to have your camera inside this prop  or the car blurs as well. Note this does slow down the render and the attached one was stopped early and has no postwork, this is straight out of DS.
    Health & Safety Notice, there is a driver, it's just that he's invisible.
    1920 x 1080 - 1M
  • 31415926543141592654 Posts: 975
    There is also this product for motion blur: https://www.daz3d.com/motion-blur-for-iray
    In regards to using a background, but not having it show while still having the lighting effects: have you tried using Canvases yet? It is a great tool although it can be a little heavy on system resources.
    Wow, I was not aware of that product!
    Gallery link
    That looks really cool! Thanks for the links. Will have to check them out. I’m still much more comfortable (and capable) in Photoshop than DS.
    Very cool renders!  I don't know anything about canvases, I'll have to look into that.
    Thanks for all the suggestions!
  • Hurdy3DHurdy3D Posts: 1,113
    I highly not recommended this product, it's super slow after you have to render lot of additional frames to simulate motion blur with this script.
    So the short answer is no, you can't do motion blur within DS with Iray, at least not like how Poser does it with Cycles, nevermind. I just pretend my camera lens is 50mm set to f22 and I'm using ISO 800 film. Motion blur.... what's that? MB is just a photographic effect, albeit plaesing to the eye, but very rarely seen in real-life situations..... the human eye has no shutter.
