What's a nice brick shader?
Sevrin
I've tried a few brick shaders, and many look great at a distance. I'm looking for a Daz Studio shader with displacement that would look good in a close-up, say with a character leaning against it.
Any suggestions? TIA
Displacement in Iray frankly is crap as you have to Sub-D the heck out of the mesh to get fine details.
well subd the heck out of it then
are these any good? https://www.daz3d.com/stoneworks-from-mexico-02-iray-shaders-and-merchant-resource
idek, i would just use free ones from texturehaven or 3dtexures.me but im just the ideas man
Maybe you can find something here:
https://texturehaven.com/textures/?c=bricks
https://texturehaven.com/textures/?c=plaster
I used the 4K JPG versions in my examples: Diffuse, Roughness, Bump and Normals. No displacement!
https://texturehaven.com/tex/?c=plaster&t=wall_bricks_plaster
https://texturehaven.com/tex/?c=bricks&t=castle_brick_07
https://texturehaven.com/tex/?c=bricks&t=brick_wall_001
Ancient Stones - Masonry, Stone and Brickwork Shaders for DS and Iray uses Displacement and Normal maps. Great detail, if a little repetitive, but in closeup, you won't see the pattern. Not necessarily standard brick, but these (mostly) wall textures also use Displacement and Normal Maps: Stoneworks From Mexico 01: Iray Shaders and Merchant Resource, Stoneworks From Mexico 02: Iray Shaders and Merchant Resource. Don't forget, there is a separate SubD Displacement Level control.
For 3DL, there are a few (not all just brick) from ForbiddenWhispers / David Brinnen (custom shaders, do not convert well, if at all, to Iray): DAZ Studio 4 Grunged Shaders, Industrial Walls DAZ Studio Shaders, Historical Masonry DAZ Studio Shaders Vol 1, Historical Masonry DAZ Studio Shaders Vol 2
Thanks all.
I have the Mexican Stoneworks shaders, but was looking for something more brick, less stone. The Texture Haven ones look good. I support HDRI Haven, but haven't been to check out textures yet.
