UltraScenery - new territory [Commercial]
11920222425100
  • davesodaveso Posts: 7,839
    Is it possible to change the shaders/textures on the pebbles, or the water? I tried to change up the water color via the surfaces tab, but the only change I could actually see were with ripples. It didn;t make them jhigher or whatever but did change how the reflection and glossiness presented itself.
  • sandmanmaxsandmanmax Posts: 992
    Is there any way to introduce variability in plant size in UltraScenery?  As in baby plants, partially grown, fully grown?  I know I could use UltraScatter.  But in UltraScenery, it's all or nothing, right?  I'd have to shrink each plants down and add the babies in as a separate plant group, like the Small, Med, Large tree layers?
  • GoggerGogger Posts: 2,496
    edited April 2021
    daveso said:
    This may have been covered, but is it possible to combine 2 or more ecologies to an environemnt? so ,say grass and oaks, or pine and willow, etc
    Edit 2 - Rereading your quesiton, this doesn't quite answer it, but is one way to get the result.  Be sure to use the same initial land/scene and then add different ecologies to the second generated US scene.  Hope this helps.
    I have posted examples of this in this thread before (maybe in the first thread this one comes from). The trick is you generate your first UltraScenery scene then in the Scene pane be sure to click OFF that whole first US group - if your first scene is still selected UltraScenery will just make modifications to that first group. Then go back and generate a new US scene like you did before and make different selections (except for the terrain - best to keep it the same unless you want to really stir things up). You can move and rotate each group once finished as well.  Have fun!
    Edit: I dug one of my old images up. I used two different overlayed US scenes in this shot - notice the extra lushness, or thickness of vegetation in the scene.
    Post edited by Gogger on
  • DaventakiDaventaki Posts: 1,624
    There is variablity built into the trees, most if not all give seedlings, young and adult trees.  But there is no way to control this inside the script.  You could after it has run remove various instances to give you more of one set or another and even duplicate instances if you wanted more of them.
    Thanks. that is really nice, and thick. Just what I'm looking for. I'll polay around a bit and see wha happens.
  • barbultbarbult Posts: 26,292
    This is how I mix ecologies:
    1. Build the first ecology, using a black and white layer mask on large items like trees so they don't land on top of each other on the first and second ecology.
    2. Select the UltraScene and execute Edit/Duplicate/Duplicate Node. Don't waste time duplicating the whole node hierarchy. You are going to wipe it out by building the sceond ecology anyway. Duplicating the UltraScene node ensures that you are using the same terrain settings and feature.
    3. Select the duplicated UltraScene and run UltraScenery again to build the second ecology. Use the same black and white layer mask on the large trees, but right click and select to invert it. Hide layers like Base Grass, River Pebbles, etc, that already provided full coverage in the first build. Otherwise it can get too dense and slow things down a lot.
    4. Hide the UltraScene (2) Terrain  and UltraScene (2) Water and any UltraScene (2) Feature Props. You don't need (or want) two of these to be rendered.
    5. Render.
    5. Render.
    not sure about this layer mask deal. I see nowhere to place that or how to make one that fits the scene. My expertise is very limited.
    5. Render.
    Layer masks are discussed in the User Guide section 2.5.1. The are added in the Build tab. They have also been discussed in various places in the forum (maybe the previous version of this thread). You don't necessarily need anything specific to the scene in order to mix ecologies. I also discuss layer masks in my UltraScenery Experiments thread, specifically in the experiment about making a flower garden.
    5. Render.
    thanks. i'll search around
    edited May 2021
    Since we are talking about mixed ecologies, I mixed Swamp 2 with Mossy Hollow 1. Now I have a more Florida swamp with palm trees.
    2000 x 1125 - 2M
    Post edited by barbult on
    edited May 2021
    I found some interesting wildlife in my swamp...  the Swamp Sprites come out to play around dawn.
    1500 x 1200 - 3M
    Post edited by sandmanmax on
  • Eggs ActlyEggs Actly Posts: 168
    edited May 2021
    I just bought the Ultrascenery - Country Ford extension and there seems to be a problem with the textures, not installing properly? Tried both DIM and manual installation in Daz 4.15.
    Post edited by Eggs Actly on
  • FishtalesFishtales Posts: 6,215
    You  also need the original Country Ford
    edited May 2021
    Ahh - missed that one yes
  • alexhcowleyalexhcowley Posts: 2,403
    edited May 2021
    After downloading the UltraScenery extension to Country Ford, I have updated my tame Excel spreadsheet showing all the possible combinations of land features, ecologies and water textures.  As before, this is straight out of the box, before you start tinkering around with Alienator Pro, Hedge Maker or go full @barbult and start hacking json files.
    Things should get even more interesting when Howie's Pacific Northwest sets hit the store.
    Cheers,
    Alex.
    Ecologies    91
    Water Textures    15
    Water Features   39
    Land Only Features   12
    Total Features   51
    Water Combinations   53235
    Land Only Combinations    1092
    Total Combinations    54327
    Post edited by alexhcowley on
    edited May 2021
    the list is beginning to look like DAZ female to male ratio for new characters. Water is overwhelming land only by far.laugh
    The new TangoAlpha sitting in my cart, along with required product.
    Post edited by daveso on
    Got them both!  Love it as always!!
    1884 x 935 - 1M
  • NathNath Posts: 2,956
    edited May 2021
    Another wonderful addition to a wonderful product!
    Quick one: Harpwood Ford (sky from Skies of Economy)
    1000 x 650 - 686K
    Post edited by Nath on
  • butterflyfishbutterflyfish Posts: 1,493
    Looking forward to playing with the country ford. Nice renders so far, everyone.
  • AnEye4ArtAnEye4Art Posts: 852
    Not too impressed with this release at all - kinda looks like the rest only with a little difference.
    edited May 2021
    its starting to get repetitious for sure. Need some kind of different environments. More rocks, bigger ones. Fallen down trees, stumps, old wood, etc. Also different kinds of trails. Maybe some roads. gravel at least. Also the ability to join terrains together to give a larger area...so the meshes line up from one piece to the next. I think it was Bryce that could do that. Very good feature.
    County Ford ecology has trees and grass that may look similar, to things we already have available, but it adds some unique new things, like daffodils, bluebells, fish in the water (also good on the end of a fishing pole), mushroom fairy rings, and props for ford water height, crossing footpath, etc. I think the new flowers alone make it a winner for me. I love the daffodils!
    What!  I missed this will have to check that out when this render finishes!  I love the daffodils and bluebells!
    1884 x 935 - 2M
    Daventaki said:
    Very impressive!  How about a close up of the young lady?
    Cheers,
    Alex.
    edited May 2021
    First one I've done in awhile...just for fun ;). Haven't used a Nursoda figure for a dog's age. LOL
    1760 x 1073 - 471K
    Post edited by AllenArt on
    very nice.
  • MelanieLMelanieL Posts: 7,743
    edited May 2021
    My first look at the Country Ford add-on. I fancied some daffodils (and of course my mandatory ducks).
    1024 x 768 - 654K
    1024 x 768 - 749K
    Post edited by MelanieL on
    I have a problem with my trout! @TangoAlpha - I think there's a tiny bug in Country Ford Ecologies 3 and 4 where the trout don't know where to swim to (they are assigned a minimum altitude greater than the maximum altitude - I think you have a couple of minus signs missing). Apart from that, I'm loving it.
    edited May 2021
    I don't get fish on either one except for the one that the instances are generated from.  My Fish Layer shows (0).  I did notice one thing, both fords are showing the same image on the right.
    819 x 567 - 243K
    Post edited by Daventaki on
