Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Hi. I need to see the morph before it is rigged, and then rigged with bones showing so I can see what is going on.
Oups i forgot ERC Freeze....
Hi! I've just bought this product and I have a problem with re-saving head morph created with Facegen. The first problem is that the default path where the morphs are located Library/data/Daz 3D/morph/genesis 8/male/Facegen is shown as "path issue" in save window. I moved the morph out of the folder and, after rigging process, the morph was finally ready to re save. When I clicked to save the morph, the progress bar goes instantly to 50%. After 30 minutes the bar was still there. I clicked cancel and the process was aborted. I've tested the product on Mac and on PC too. Same problem. I tested all morph created with Facegen and all of them have this problem. Can you help me? Thanks
Ok. I moved the Facegen morph in a sub vendor folder as described in this post and finally I get it works like a charm
Product updated to version 1.8
-Fixed issue with the G3 lip bones causing inconsistencies.
Thanks for a great product. It works like a charm, but I have 2 major issues... Hair + eyelashes. They do NOT end up on my characters head, instead, waaaaay above. (My character is not full G8 length). How do I make sure the hair + eyelashes end up correctly placed?
Hi. I need to see the figure dialed up and the bones.
Hey, here's a screenshot with bones... Also, a screenshot with the morph at 0, showing proper fitting of hair + eyelashes (towards original G8 female shape).
And this hair follows any other shape?
Yes, tested with lots of other custom characters that have a more "petite" size, that hair fits them perfectly.
Something is off though, since the morphs are saved as Genesis 8 morphs, and each time I load a base G8 female, the morphs are there. What I want and need, is a custom character that can be loaded. Not a morph dial.
This rigs morph dials. I am confused as to how you are setting this up. Send me a pm pls
Just wanted to thank you Zev0 for your personal assistance with the issue I was having. So glad it's workig now... You rock man! :)
Np.
Glad ur all sorted.
Hello!
Should we expect Shape Rigger Plus for Genesis 9?
Hi. There is one for G9. We just adding some stuff.
When is it going to be released?
Don't know yet.
I'll be waiting. Hope, it'll be released soon.
Hi Zev0
Trying to save an existing morph and I get 'unable to save morph' for any existing morph I try.
I can create new morphs fine
Pretty sure my path is ok.
