My WIPS, renders and animations :)
12223252728
  • FishtalesFishtales Posts: 6,216
    Irradiated Planet
    2021-01-20 14:39:55.777 Total Rendering Time: 6 minutes 38.23 seconds
    Click on image for full size.
    414
    edited January 2021
    The Phantom
    2021-01-19 23:30:18.043 Total Rendering Time: 4 hours 27 minutes 24.23 seconds
    443
    1920 x 1080 - 234K
    Post edited by Fishtales on
    edited February 2021
    The Keep
    2021-02-02 15:54:30.787 Total Rendering Time: 4 hours 26 minutes 53.85 seconds
    523
    1920 x 1080 - 1M
  • NovicaNovica Posts: 23,925
    I like the lighting on both of the last two, the Phantom is eerie!
    Thank you.
    It is a real Phantom too there is no figure, just the cloak :)
    The Market
    2021-02-07 09:49:53.659 Total Rendering Time: 1 minutes 11.97 seconds
    562
    1920 x 1080 - 1M
    edited March 2021
    Spider Baby
    2021-02-23 21:20:44.454 Total Rendering Time: 4 hours 58 minutes 45.69 seconds
    759
    1920 x 1080 - 1M
    edited March 2021
    Lone Hunter
    2021-03-15 21:45:49.381 Total Rendering Time: 1 hours 2 minutes 38.95 seconds
    797
    1920 x 1080 - 2M
    edited April 2021
    Quick! Scatter!
    2021-03-31 17:46:47.549 Total Rendering Time: 10 minutes 40.96 seconds
    852
    1920 x 1080 - 1M
    edited April 2021
    edited April 2021
    Chilling Out
    2021-04-06 10:05:40.061 Total Rendering Time: 42 minutes 5.81 seconds
    903
    Fishtales said:
    Chilling Out
    903
    Very nice:)
    Sven Dullah said:
    Very nice:)
    Thank you.
    edited April 2021
    I use the Auto Exposure Tool on occasion, that's the little box at the top right of the render window with the +/- signs, using a grey cube as my selection surface set at 18% grey, that is 118 or 0.18/0.18/0.18, Base Colour.
    To set the tool to White Balance go here in DAZ Studio it is under the Menu: Window/Draw Settings/Advanced/Draw Style/NVIDIA Iray/
    It set me wondering if the colour actually made a difference so I set up a scene with three cubes with the base colour set at 118, 192 and 250 with the numbers at 255. These are set with colour settings I found on the internet.
    118 is the Grey Scale Card used by photographers.
    192 is a medium Grey.
    250 because there isn't a pure white in nature.
    255 which is pure white.
    I added the base Genesis 8 and , for outdoors, the Highlands Preload scene with the fog and mist turned off. The indoor scene uses Spa and Lounge preload scene. Lighting was Sun and sky 21st June at 14:30 in the Northern Hemisphere 56º N -4º W for the Daylight scene, 21st December at 23:30 for the night scene with a Distant Light -- Colour 217; Intensity 89%; Lumen 0.10; Temperature 4100 for the Moon.
    I used the front right corner of the cubes for the processing point.
    This is the 118 which gave a White Point of 1.00-0.96-0.86
    This is 192 which gave a White Point of 1.00-0.97-0.89
    This is 250which gave a White Point of 1.00-1.00-1.00, so did the letters at 255.
    This is 118 which gave a White point of 0.81-0.52-1.00
    This is 192 which gave a White Point of 0.50-0.31-1.00
    This is 250 which gave a White Point of 1.00-1.00-1.00
    The indoor scene gave a White Point of 1.00-1.00-1.00 on all cubes.
    To summarise then In that particular outside Environment the colour of the Cube didn't make a lot of difference in the Daylight renders but it did in the Night renders.
    In the indoor scene using that Environment the colour of the Cube doesn't make any difference to the White Point.
    This is in no way a comprehensive test and probably each environment and lighting will cause different White Points but it was interesting to see.
    990
    1000 x 1500 - 1M
    1000 x 1500 - 1M
    1000 x 1500 - 1M
    1000 x 1500 - 943K
    1000 x 1500 - 947K
    1000 x 1500 - 973K
    1920 x 1080 - 1M
    003
    edited April 2021
    Updated the Swing Ride with music.
    015
    edited May 2021
    Can I help you?
    2021-04-11 22:02:32.115 Total Rendering Time: 50 minutes 16.86 seconds
    028
    1920 x 1080 - 1M
    edited May 2021
    Story Time
    2021-05-04 20:18:01.919 Total Rendering Time: 1 hours 13 minutes 46.14 seconds
    043
    1920 x 1080 - 2M
    edited May 2021
    After many hours with the Strand Based Hair Noggins Hare and Rabbit it still looks like a Hare even with the Rabbit Morph :)
    2021-05-09 13:59:10.992 Total Rendering Time: 2 minutes 48.84 seconds
    Sand Bunnies
    2021-05-09 16:03:20.560 Total Rendering Time: 1 hours 9 minutes 48.13 seconds
    CPU
    067
    1920 x 1080 - 968K
    1920 x 1080 - 2M
    edited May 2021
    Mud Bath
    Of course I fell in!
    2021-05-11 14:45:38.271 Total Rendering Time: 32 minutes 27.63 seconds
    104
    1920 x 1080 - 2M
    edited June 2021
    Space Patrol
    2021-05-21 16:06:48.172 Total Rendering Time: 2 hours 15 minutes 15.95 seconds
    CPU Only
    144
    1920 x 1080 - 868K
    edited June 2021
    In The Forge
    This is the Viking Forge and Genesis 8 with a few adjustment morphs and new skin.
    2021-06-09 07:25:28.354 Total Rendering Time: 15 hours 28.62 seconds
    Stopped 70.15% of image converged
    This is the same scene after I had adjusted everything of the Forge, adding smoke to the fire and deleting the supplied one and deleting the structural ambient light and adding a Point Light.
    2021-06-09 17:32:59.248 Total Rendering Time: 53 minutes 16.41 seconds
    169
    1920 x 1080 - 1M
    1920 x 1080 - 1M
    Fishtales said:
    In The Forge
    Still trying to spot that Genesis 8blush. Any hints?
    Sven Dullah said:
    Fishtales said:
    In The Forge
    That is him over the anvil with his hammer in the air, left side of the forge :)
    edited June 2021
    Vince
    2021-06-16 07:07:24.065 Total Rendering Time: 3 minutes 28.17 seconds
    Vince for Genesis 8 with Thorn Hair Long and Drago Beard, my skin materials.
    246
    800 x 1000 - 319K
    Just a quick animation of Genesis 2 and then taken into Vegas Pro 16, combined with two videos from Particle Illusions and two sound bytes from my collection.
    269
    I got to wondering who she was angry at :)
    275
    edited July 2021
    Despair
    308
    800 x 1000 - 475K
    edited July 2021
    Distant Base
    329
    1920 x 1080 - 686K
    edited July 2021
    Cat Fight
    2021-07-06 19:53:02.851 Total Rendering Time: 2 minutes 4.53 seconds
    Catalyzer Fur
    378
    1920 x 1080 - 1M
