• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1…18192021222324…49»
  • mCasualmCasual Posts: 4,607
    August 2014 edited August 2014
    that's Stephanie 4 Elite , the poser-compatible / non-shader materials
    so all the materials are based on the Daz Default "shader"
    and that's ideal for TeleBlender ( though teleblender 3 ( and 2?) will be improved )
    tele-rendered using today's Teleblender 2
    i reduced the bump map strength by half
    i "manually" adjusted the specular map multiplier from 0.1 to 0.15
    i adjusted roughness from 0.3 to 0.1 which makes the glossiness look more wet ( tighter bright spots )
    1280 x 720 - 237K
    1910 x 780 - 673K
    Post edited by mCasual on August 2014
  • MelanieLMelanieL Posts: 7,749
    Well thanks to all who helped, with a bit of tinkering in DS and the updated scripts I managed to get the eyes reasonably good.
    Here's what I've got so far - now to work on the hair a little (rather dull) and learn how to light things a bit better...
    I'm loving Cycles though - reasonably fast and I get to use the CPU for something else at the same time!
    1024 x 1024 - 279K
    Post edited by MelanieL on August 2014
  • nakamuram002nakamuram002 Posts: 813
    August 2014 edited December 1969
    Nice render, MelanieL!!!!! Nice shadow.
    great render!
    a few times i experimented with getting the tight bright eye reflections
    the way i did it was to place an extremely bright area-light ( a plane with an ambient light )
    it was quite large,
    since it's far away the light doesn't illuminate the character
    next i made the eye surface( in the case of Aiko, that's just the cornea ) very glossy like a mirror, but very weak
    this way the area-light reflexion is visible, since it's extremely bright, but the rest of the scene, which is normally bright
    is not seen on the eye surface
    i basically build that material "manually" then saved it as a mat-lib material for later re-use
    note that if you save a blender scene as a blend file, later on, using Blender's File/Append you can go pick in that file any material and bring it into your scene -- which is exactly what mcjTeleBlender/mcjBlendBot do with the mat-lib trick
    around the 1:05 mark in this video you can see the result of that setup but animated
    https://www.youtube.com/watch
    800 x 400 - 32K
    800 x 800 - 58K
    800 x 800 - 103K
  • ladagaladaga Posts: 4
    I express my gratitude to the creator of this very necessary script. I want to share a link to a script which can be imported into DAZ studio animations in the format attached to the mdd objformat
    https://onedrive.live.com/?cid=9E5F8EE5BF3FA682&id=9E5F8EE5BF3FA682!281
    Just wanted to ask about how to export animation in blender.How can I upload sequence objfiles in the blender?
    1053 x 881 - 126K
    welcome !
    your onedrive link is not valid
    are you saying you have a script to import mdd/obj to Daz Studio? i guess not
    here's what i understand about mdd/obj, it's a way to package an animated scene
    the obj file contains the initial geometry and materials, the mdd file contains
    the vertex movements ( morphs ) for each frame - and probably lights and cameras
    i think i did see there was/is an mdd/obj file importer for Blender
    and there's a mdd/obj import/export plugin for Carrara
    www.daz3d.com/mdd-file-format-for-carrara
    so one way mcjBlendBot could help is, after importing the mdd/obj in Blender
    you could run the special version of mcjBlendBot which was designed for Carrara obj/scenes
    https://sites.google.com/site/mcasualsdazscripts2/mcjblendbotspecial
    or even the one for Poser's obj/scenes https://sites.google.com/site/mcasualsdazscripts3/teleblendforposer
    note that those scripts are quite old, so they possibly dont work anymore
    or they work only with Blender versions before 2.71
    but if they do work, they would make the scene cycles-renderable
    a while ago also, i created scripts to convert a sequence of obj files into a morphing prop
    a prop with 1 morph per animation frame, which is very similar to what mdd does
    So if you figure how to export an animation in Blender into a series of obj files
    You could import it in Daz Studio as an animated morphing prop
    Then you could adjust the materials
    Then you could render the animation using mcjTeleBlender 2 from Daz Studio
    https://sites.google.com/site/mcasualsdazscripts2/mcjobjstomorphingprop
    i'm sure this script works with Daz Studio 3, and ..... it works in DS 4.6 ! ( tested it right now )
    ok i did some research
    importing the mdd in Blender is done by
    1 - loading the base obj file
    2 - applying a "Modify / Mesh Cache" modifier
    But you have to be very carefull about the way you import the base obj file
    for instance the "preserve vertex order" option must be used
    also there are axis ( X Z ) issues to figure
    in various Blender forums they discuss this
    example: http://blenderartists.org/forum/archive/index.php/t-274406.html
    300 x 800 - 59K
    662 x 490 - 119K
    300 x 800 - 65K
    oops no navel
    thinking of participating in the August freebies challenge which ends this weekend
    and finishing teleblender 3
    .. i have doubts :)
    but anyway , if you missed it, be aware that a new mcjBlendBot for Teleblender 2 was posted this week, it now handles the eye opacities without the need for a black opacity image map
    1280 x 720 - 235K
    September 2014 edited December 1969
    Just lurking by... ;-)
    September 2014 edited September 2014
    after the mcjJet and matAnim diversion i'll be back on the mcjTeleBlender3 project
    it was aaalmost ready
    ( in fact i already use it )
    600 x 1000 - 85K
    Post edited by mCasual on September 2014
    OK, now your are just teasing us, LOL!
  • robert_c_gladstonerobert_c_gladstone Posts: 1
    This has probably been covered. But while I am able to export the static Daz character into my blender created scene, what I really want to do is export that fully animated character into that scene. Is this possible with this script or no? And if not, any suggestions about how to best go about doing that?
    825 x 755 - 634K
    there's http://www.blender3dclub.com/posertools/CharacterImporter.php
    and there's a method that uses daz studio's fbx or collada export
    i discussed it a few pages ago
    http://www.daz3d.com/forums/discussion/2877/P555
    see here http://maddieman.wordpress.com/2012/04/23/exporting-daz-studio-4-figures-to-blender/
    I apologize for the wrong link to download MDD Importer for DAZ Studio 4.6 and for my english:) Instead of that, use this.
    http://amarijun.wordpress.com/2014/08/23/mdd-importer-for-daz-studio-4-6/
    also recorded a short video tutorial on how to use the plugin.
    http://www.youtube.com/watch?v=6cqpa7mUZhU&feature=youtu.be
    please explain how to use the plug-in for the successful transfer of the animation in blender?
    Casual,
    Why don't you release a "Beta" version of mcjTeleblender 3 and let us play with it for a while? That way, you could get ideas and feedback from your users?
    nakamuram002 said:
    Casual,
    it's almost ready it's almost ready :)
    i'm on the case
    i can always say it's Beta
    Dawn with the default materials
    one sunlight
    rendered in TB3 add-specular mode
    and shadow catcher plane similar to
    http://blender360.blogspot.ca/2012/01/integracion-de-imagen-real-con-imagenes.html
    https://www.youtube.com/watch?v=k7gKzgvFiGM
    oops i rendered the background image the wrong size
    960 x 540 - 149K
    960 x 540 - 114K
    1920 x 900 - 475K
    1920 x 1080 - 126K
    as previously stated teleblender 3 has better support for daz studio "shaders"
    case in point, Dawn uses the OmHumanSurface, even for the eyes
    the specular color is a very bright white, which would often result in very glossy materials in Blender
    but since we now have new ways to transfer the "specular strength" value
    we get properly not-too-glossy eye surfaces
    707 x 1000 - 125K
    publishing teleblender 3 ( beta ) tonight
    I will write the manual this week
    though the teleblender 1 and 2 manual covers most of it
    you'll notice that spotlights, distant lights are now properly oriented spotlights and sunlights
    instead of point lights
    i want to have a very sleek looking and better written user manual,
    with details about the material node trees
    also i'll study and discuss rendering of Poser / Carrara scenes,
    using the same "mcjBlendBot" scripts used by mcjTeleBlender
    and see what exists for rigged figures and formats like ... what was it called ...
    same render as the previous one but HDR environment lighting instead of JPG
    ---- next forum post is the link for TB3's homepage ! ---
    ... oh oh did i re-write code for the the normal maps .... bah we're in Beta :D ah sweet beta
    809 x 445 - 121K
    424 x 600 - 44K
  • SzarkSzark Posts: 10,634
    I haven't looked back so apologies if this has been mentioned already.
    I noticed bump maps (Image Texture node) are set to Colour when they should be set to Non Colour Data. And Mix Shader gives more control over Add Shader even though you mentioned it last time. But I still think Mix Shader is better which gives more control of Diffuse and Glossy mixing. ;) I have spent the last few days doing a big scene with lots of materials and this what popped in my head
    Brave mcjTeleBlender 3 Beta testers go here
    https://sites.google.com/site/mcasualsdazscripts4/mcjteleblender3
    455 x 455 - 95K
    there's a "glossy mix" checkbox in TB3 which selects the use of a mix shader or an add-shader for the specular mix
    for bump maps, if you mean in the blender node network, i observed that bump maps
    work as expected without the need to convert the image color output
    well i didn't study that matter a lot, you seem to say we can change the output type to non-color
    i'll see if it changes the bump map appearance .... if there's gamma correction on color outputs for example
    ( TB3 and the new Blendbot is out in beta testing )
    Thanks Casual!! I gave TB3 a quick test. My hair transparencies don't work properly in the new version. Also, the world output is messed up -- There is no World Output node and it does not appear to support .hdr equirectangular mapped images.
    If I use the "TB2 Legacy Mats" option, I get much better results, but my world image is not equirectangular mapped, like it was in TB2.
    the world-environment is one of the features that didn't change
    when all goes well, it's the first task executed right after the obj/mtl files were loaded
    1280 x 720 - 378K
    Found interesting, and I think can be useful to facilitate the scene
    1920 x 1080 - 783K
    ( TB3 and the new Blendbot is out in beta testing )silly me yes you did mention the Glossy Mix node, sweet idea thanks a lot for that.
    Here you go some visual references on what I am talking about. I noticed a better Opacity Maps implementation when Non colour data was chosen. Colour didn't cut it and for the bump I noticed an increase in quality when set to non colour. :) Saves using a RGB - BW node. ;)
    These aren't complaints as a you are doing this for free and b I love this script so much.
    PS It would help to attach the image
    833 x 912 - 328K
    Post edited by Szark on September 2014
  • HellKoreaHellKorea Posts: 17
    Thank you Teleblender3
    Error in script execution!
    WARNING: Script Error: Line 2088
    WARNING: TypeError: Result of expression 'mat.findProperty( "Glossiness" )' [null] is not an object.
    WARNING: Stack Trace:
    ()@:2088
    error comes when use AoA SSS Shader.
    it will need error processing when not using default and omHumanSurface shader.
    (sorry my poor english..)
    ()@:2088
    it will be a chance for me to try AoA's SSS !
    this will be easy to fix, thanks giving me the error message
    someday i may do SSS export to Blender Cycle's SSS, which i think is still CPU-only
    Fig 1,2 - DS render the mcjTeaPot, less the spout which had problems - also i had to inverse the normals -- so, i'll update the free mcjTeaPot prop very soon
    The Aoa Subsurface shader will now be processed by mcjTeleBlender 3 ( TB3 was looking for DzShaderMaterials, but this is a DzBrickMaterial
    the OmSimpleShader does not contain specular/glossiness properties. TB3 will now deal with this by setting specular strength to zero, glossiness to 0.5 and specular color to gray ... or simply doing nothing
    707 x 1000 - 387K
    707 x 1000 - 99K
    Update - TeleBlender 3.01 beta - Update - TeleBlender 3.01 beta - Update - TeleBlender 3.01 beta - Update - TeleBlender 3.01 beta
    History
    2014 September 9 10:54 PM - version 3.00 beta released
    2014 September 10 4:00 PM -
    version 3.01 beta released -
    now supports all non-DzDefaultMaterial materials including those with no specular properties
    tested : Aoa Subsurface - OmSimpleSurface
    only the script needs to be upgraded not the mcjBlendBot package
    707 x 1000 - 75K
    i'll check it out today
    i used your mddImporter right now and imported the houdini ball, then imported the mdd
    then i used mcjTeleBlender to export the animation as a series of 50 numbered obj files
    mcjTeleBlender also created a batch file ( .bat ) which is used to start Blender in hidden-mode
    it then renders each frame as an image
    then i can convert the images into a video using a video editor like virtualDub
    to get the whole animation in Blender you'd have to import it using Blender's mdd importer
    the materials would probably be usable for "Blender Internal Render" renders but not Blender Cycles renders
    next i will see if you could use some of the mcjBlendBot scripts to create the Blender-Cycles-compatible material-node-trees
    How to import an mdd in Blender
    File / Import / Wavefront (.obj )
    imported MDDImporter\sample data\houdini13_output\houdini_output_frame0.obj
    i selected the ball
    i went in Blender's Object Modifiers panel
    and added a "Mesh Cache" modifier
    i selected the MDD file that comes with the ball : MDDImporter\sample data\houdini13_output\houdini_output.mdd
    and its done this is now an animation in blender but the materials are not good materials for cycles
    next we will borrow the materials from an mcjTeleBlender exported scene
    844 x 412 - 797K
    544 x 512 - 69K
    1270 x 518 - 179K
    1037 x 481 - 110K
    176 x 250 - 1M
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
