• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz to Blender- Surface settings
wjpblathwaytwjpblathwayt Posts: 45
March 2021 edited March 2021 in Blender Discussion
Hello
thank you for taking the time to read my post.
I'm stuck, and I don't know what i'm doing (Double threat!)
So, I've changed Amy_aimei's great ST uniforms to be TOS, however, I'm stuck at one spot.  The uniform is glossy.  In DAZ, I've removed all gloss settings, in Blender and this type of surface setting (below), I cant find 'gloss' or 'specular' settings in this set of options.
What can I do to make this more clothy?
Thank you
Post edited by wjpblathwayt on March 2021
  • margravemargrave Posts: 1,822
    March 2021
    That looks like a custom shader. How did you import it, using the official Daz bridge?
    What does it look like in the Shader Editor?
  • Krys KryngleKrys Kryngle Posts: 313
    Node setups for Cycles attached.  Don't know about Eevee.
    There are some shading artifacts in the render but I was too lazy to figure out what the issue was.  SubD fixes the artifacts but messes up the black line on the uniform.
    3839 x 1966 - 602K
    Post edited by Krys Kryngle on March 2021
    March 2021
    With specularity down to 0.05 and roughness cranked all the way up to 0.95, there should be little if any gloss. You only posted the shader for the black part though, so I can't say about the yellow bit. As to the subsurf, that's a natural consequence of smoothing the vertices. Since the texture map is connected to the UV output, you might be able to fix it by finagling the UVs.
  • wjpblathwaytwjpblathwayt Posts: 45
    March 2021
    Good Morning!
    Thank you for getting back to me so quickly!
    I used the official Daz to Blender utility, and here are my shader settings... From Krampus' post, looks like I've got alot to learn!
    639 x 317 - 46K
    The green node in the center is a node group. Select it and hit tab to go inside the group. Once there, look for "roughness" and turn to all the way up. And/or post a pic of what you see if you want more help.
    Post edited by margrave on March 2021
  • TheKDTheKD Posts: 2,711
    March 2021
    I would click on that default shader node and delete it. Then shift a and drop down a principaled bsdf and rehook up the texture maps to that. Then you will have the controls for roughness, specular etc to fine tune it to your liking.
    March 2021
    From my experience, there is a Principled BSDF inside the node group already.
    March 2021
    That did it!!  Using the TAB key was the perfect solution!
    Thank you very very much everyone, I've learned alot with this.
    March 2021
    Shoulda refreshed before posting, would have kept me from lookin like a dumbass lol.
    March 2021
    I would've deleted it too, honestly, but I figured I might as well keep it simple since the OP seemed like a new user.
    March 2021
    This is a WIP (fix the seams to TOS), i have more to do, but so far....
    Thank you
    1080 x 1920 - 3M
    March 2021
    Here's something else to help you:
    https://docs.blender.org/manual/en/latest/modeling/modifiers/deform/corrective_smooth.html
    March 2021
    Thanks margrave, something to read while i sit around the house.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
