Blender Bridge no pose
Hi,
I was able to use the weight with blender, but the model arrives in blender without pose.
At what point did I miss something?
Thanks.
Hi,
Thanks.
I don't think the bridge supports posing. The default skeleton is designed to convert to Rigify, so I assume the character not having an A-pose would cause problems.
AFAIK, the bridge is just an asset exporter. You pick what assets you want to send to Blender, and do everything else in there.
Hi margrave,
Hmmm ok! Does the DAZ importer (.duf) import the poses?
I have a problem with this importer: Here is the error that is displayed in blerder:
ERROR:
Mesh fitting set to DBZ (json).
Merci.
If you mean the Diffeomorphic one, I don't know. I've never used it.
Thank you for your answer
I will continue my research.
Hi Kargall1
Did you do the "export basic data" in DAZ?
