I'd like to move position that already fitted like hat and anatomical elements
when ever i try to move that already fitted to character by using XYZ it didn't move
so i try to move scale slider than it goes nuts. it goes back flipping and rotating unintentionally.
how can i fix this problem?
Use a dForm, perhaps? You could use a weight map to have it affect the whole item uniformly, in the case of the hat.
Yeah i figiured out about that hat but still got problem with anatomy. it's not something with Dform.
https://streamable.com/q84iln
here is the video link that will show what is the problem.
Why didn't you try the head bone of the mask thing?
Yeah i did thing but it only has scale but no xyz
In the Parameters pane option menu (the lined/hamburger button in the top corner, or right-click the tab) enable Preferences>Show Hidden Properties and the translation controls should show up.
there is hidden XYZ but those are works same as what video described. I did with scale thingy. it's not perfact but worked on this case. thanks for the help.
