I'd like to move position that already fitted like hat and anatomical elements
when ever i try to move that already fitted to character by using XYZ it didn't move
so i try to move scale slider than it goes nuts. it goes back flipping and rotating unintentionally.
how can i fix this problem?
  • Richard HaseltineRichard Haseltine Posts: 111,371
    Use a dForm, perhaps? You could use a weight map to have it affect the whole item uniformly, in the case of the hat.
  • kjino570kjino570 Posts: 39
    Yeah i figiured out about that hat but still got problem with anatomy. it's not something with Dform.
    https://streamable.com/q84iln
    here is the video link that will show what is the problem.
    Why didn't you try the head bone of the mask thing?
    Yeah i did thing but it only has scale but  no xyz
    In the Parameters pane option menu (the lined/hamburger button in the top corner, or right-click the tab) enable Preferences>Show Hidden Properties and the translation controls should show up.
    there is hidden XYZ but those are works same as what video described. I did with scale thingy. it's not perfact but worked on this case. thanks for the help.
