Replace Genesis 8.1 F figure with shoe prop.
Hi , I am trying to do followonig.
As per attached picture, #1 figure has shoes objects attached on feet.(not genesis 8.1 but modified v4), My Goad is to put this shoes to genesis 8.1 figure of #2.
But difficult part is #1 shoes is not clothing nor the prop, figure's feet is replaced with shoes like object. I can state this because when shoe is invisible, there is no foot.(Please refer #3 of image)
Does anyone know how to archive the goal? ( The shoes and figure does not have boundary. Shoe is must seems to be part of body).
Thank you.
Post edited by yoshinobufuruya1988 on
With Genesis figures you would typically use a geograft, which is a figure specifically meant to replace part of another figure.
The geograft needs to have an edge loop in common with the base figure where they would be linked, and when you set it up you can select which polygons it will replace.
There's a tutorial on geografting here: https://www.daz3d.com/forums/discussion/24555/tutorial-starting-out-with-geo-grafting-repost/p1
Great! I need to learn geografting now but now I know which direction to go.
Many thanks.
