Commercial: DP Aiko 6 Sport Dynamic Hair & DP Aiko 6 Carrara Shaders 30% OFF
ringo monfort
DP Aiko 6 Sport Dynamic Hair is perfect for when you want to take Aiko 6 Carrara render to the Next level!
Twenty beautiful hair colors are also included to give you realistic hair renders.
http://www.daz3d.com/new-releases/dp-aiko-6-sport-dynamic-hair
Post edited by ringo monfort on
More Aiko 6 Sport Dynamic Hair Images.
1. From the Browser Object Tab Drag and Drop "Aiko 6 Sport Hair" into the Instances Tab.
2. From Instances Tab select the Aiko 6 Sport Hair and up in the General tab use the "Fit To" option to fit it on to "Genesis 2 Female". This will attached the hair onto Aiko 6.
3. How to apply the Shaders from the Shader Browser tray shader tab.Make sure that your Instances Tab is open. Drag and drop any of the shaders onto the "Aiko 6 Sport Hair" that is attached to the "Actor" on the Aiko 6 Sport Hair, or you can just drag and drop the shader right on to the hair in the Scene.
This is Stephanie 6 with DP Aiko 6 Sport Dynamic Hair.
This is try of Victoria 6 with the Dynamic hair.
Another Carrara Screen Capture of Aiko 6 and Sport Dynamic Hair.
Thanks Ringo - been waiting for this :)
Thank you Tim!!!!!
Regards
Update:
NOW back on sale at 30% OFF.
http://www.daz3d.com/dp-aiko-6-carrara-shaders
Perfect combo to go with DP Aiko 6 Sport Dynamic Hair.
Dumb question (possibly): How do I get to the list of shaders for this hair? You have a screenshot that shows a "DP A6 Sport Dynamic Shaders" entry under the shaders tab. But in my install, that is conspicuously absent. I can see all the .cbr file listed in the Install Manager installed file list, but I can't find them in Carrara.
The hair itself shows up in the objects tab with no trouble (but it comes out bright red...)
Thx (again!) :)
Greetings Tim!!!
The hair shaders need to be added to the Browser's Shaders tab.
Add Folder Button in the browser.
Program Files\DAZ 3D\Carrara8.5\Presets\Shaders\DP A6 Sport Dynamic Shaders
Ringo Monfort
Thanks Ringo.
Any idea how to add the folder on a Mac? The folder path is buried inside the Carrara.app "file", and while I can browse to it from the Finder by selecting Show Package Contents, the Add Folder button in the Carrara browser doesn't allow it.
I've figured a workaround for the moment - which is to copy the shaders into the My Shaders folder in Documents:Daz 3D, from where I _can_ add the folder.
But I'd still like to know how to add them in their proper place, and how come these don't automatically show up, when the various G2F skin shaders do.
