Commercial: DP Aiko 6 Sport Dynamic Hair & DP Aiko 6 Carrara Shaders 30% OFF
ringo monfortringo monfort Posts: 945
edited July 2014 in Carrara Discussion
DP Aiko 6 Sport Dynamic Hair is perfect for when you want to take Aiko 6 Carrara render to the Next level!
Twenty beautiful hair colors are also included to give you realistic hair renders.
http://www.daz3d.com/new-releases/dp-aiko-6-sport-dynamic-hair
Post edited by ringo monfort on
  • ringo monfortringo monfort Posts: 945
    More Aiko 6 Sport Dynamic Hair Images.
    1000 x 1300 - 598K
    1680 x 1010 - 694K
    1000 x 1300 - 373K
    1. From the Browser Object Tab Drag and Drop "Aiko 6 Sport Hair" into the Instances Tab.
    2. From Instances Tab select the Aiko 6 Sport Hair and up in the General tab use the "Fit To" option to fit it on to "Genesis 2 Female". This will attached the hair onto Aiko 6.
    3. How to apply the Shaders from the Shader Browser tray shader tab.Make sure that your Instances Tab is open. Drag and drop any of the shaders onto the "Aiko 6 Sport Hair" that is attached to the "Actor" on the Aiko 6 Sport Hair, or you can just drag and drop the shader right on to the hair in the Scene.
    1739 x 1003 - 790K
    1739 x 1003 - 685K
    This is Stephanie 6 with DP Aiko 6 Sport Dynamic Hair.
    1000 x 1300 - 576K
    This is try of Victoria 6 with the Dynamic hair.
    1000 x 1300 - 557K
    Another Carrara Screen Capture of Aiko 6 and Sport Dynamic Hair.
    1920 x 1054 - 866K
    Thanks Ringo - been waiting for this :)
    Thank you Tim!!!!!
    Regards
    edited July 2014
    Update:
    NOW back on sale at 30% OFF.
    http://www.daz3d.com/dp-aiko-6-carrara-shaders
    Perfect combo to go with DP Aiko 6 Sport Dynamic Hair.
    1000 x 1300 - 302K
    851 x 315 - 183K
    Dumb question (possibly): How do I get to the list of shaders for this hair? You have a screenshot that shows a "DP A6 Sport Dynamic Shaders" entry under the shaders tab. But in my install, that is conspicuously absent. I can see all the .cbr file listed in the Install Manager installed file list, but I can't find them in Carrara.
    The hair itself shows up in the objects tab with no trouble (but it comes out bright red...)
    Thx (again!) :)
    Greetings Tim!!!
    The hair shaders need to be added to the Browser's Shaders tab.
    Add Folder Button in the browser.
    Program Files\DAZ 3D\Carrara8.5\Presets\Shaders\DP A6 Sport Dynamic Shaders
    Ringo Monfort
    Thx (again!) :)
    Thanks Ringo.
    Any idea how to add the folder on a Mac? The folder path is buried inside the Carrara.app "file", and while I can browse to it from the Finder by selecting Show Package Contents, the Add Folder button in the Carrara browser doesn't allow it.
    I've figured a workaround for the moment - which is to copy the shaders into the My Shaders folder in Documents:Daz 3D, from where I _can_ add the folder.
    But I'd still like to know how to add them in their proper place, and how come these don't automatically show up, when the various G2F skin shaders do.
