• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Help, DIM won't install Blender Bridge into Daz Studio
deathbycanondeathbycanon Posts: 1,227
February 2021 edited February 2021 in Blender Discussion
I open DIM, select Daz to Blender bridge to download, it downlaods and goes into the 'ready to install' tab, I click that and it looks like it goes into the installed tab.... but look at the attached image. There is a ? where the size of the file should be, and when I try an dlocate files it's just a blank box... if I close DIM and open it again the bridge is back in the 'ready to install' tab. It never actually installs into daz. What am I doing wrong??
Post edited by deathbycanon on February 2021
  • Razzle-Dazzle3DRazzle-Dazzle3D Posts: 32
    February 2021
    No worries, you aren't doing anything wrong at all. Sometimes, even though uninstalling and reinstalling can resolve many installation issues, there are problems with the file itself; so now I would recommend that you erase the file completely and reinstall fresh.
    To do this:
    1. Go to Install Manager. Uninstall the product.
    2. Under the Ready to Install tab, right click on the product. Select "Delete Packages" and select the product.
    3. Now, got to Ready to Download and redownload the product.
    Are you able to install the file as expected after this erasure? You'll know this installed correctly with Daz to Blender bridge now appearing under the Installed tab of DIM, as well as a file size replacing the "?".
    813 x 728 - 93K
  • deathbycanondeathbycanon Posts: 1,227
    February 2021
    Thanks for the response Razzle, I tried deleting the files and redownloading and then installing several times before posting, and again after your response and still it does the same thing as above.
    March 2021 edited March 2021
     New blender update... still won't load and get the exact same problems as shown above.
    I have deleted the beta version of daz and all older versions of blender off the hard drive so there is only one version of each software on my system. I have uninstalled and reinstalled dim, I have undownloaded and redownloaded and tried to instal daz to blender bridge multipule, so far nothing is working.
    Post edited by deathbycanon on March 2021
  • DartanbeckDartanbeck Posts: 22,159
    March 2021
    Make sure that you allow DIM to make changes to your computer - requires admin permission because it installs a folder into your AppData
    Not much of anything gets installed, so it may actually already be installed.
    I'll try and remember to check this out after work - the exact procedure. I think we need to enable or add a script to our Daz Library/interface, but then we also must install the addon in Blender:
    There should be a zip file in your [Drive] > Users > Your User Name > AppData > Roaming > Blender
    Something like that. Find it first so you find it. Not at 'my' computer to check right now.
    In Blender go to Edit > Preferences > Addon tab
    Click Install and navigate to the zip file and double-click the zip
    When done, back in the addons tab enter Daz into the search bar and enable the plugin by putting a check in the box. Be patient with this step as some time for refreshing will be needed. Don't keep clicking the check box - just click it once and wait.
    Restart Blender
    In Blender, type "n" and a panel will open from the right side window. One of the tabs will be your Daz Bridge
    Hope this helps
    March 2021
    Restart Blender
    Hope this helps
    Thank you so much for the response Dartan. In my appdata roaming file I have Blender Foundation then two folders Blender 9.0 and one that says BLENDER_VERSION no zips in either folder. The one that says blender version then goes to scripts/addons/DTB  so I'm guessing that's daz to blender bridge... it goes to another couple folders and files, no zip anywhere. I deleted the Blender version folder then reinstalled through the DIM to see what would happen. It just recreated the blender_version folder in the same place. No zip files.
    March 2021
    Restart Blender
    Hope this helps
    Have you customized your install paths at all? If so, I would recommend opening a help ticket with a title something to the affect of "Blender Bridge Help (Forums)" and I can look into assisting you with this further here:
    Submit a request – Daz 3D Help Center (zendesk.com)
    Otherwise, it is possible that this could be a permissions issue. Would you please ensure that both the Daz Studio and Blender applications are both closed and attempt the uninstall / re-install process once more? If this does not resolve the installation issue for you, then I would recommend opening a help ticket so that I can look into this issue further for you and see why these files aren't appearing on your end where they should be.
    March 2021
    DTB is the one.
    Select that inside the Install dialog in Blender's Addon tab within Edit > Preferences.
    Sorry - was at work
    March 2021
    When I first tried, I went inside the DTB folder (zip? Don't recall - either way) and tried installing something in there. Don't. Just select the folder when telling Blender what to install.
    April 2021
    The new version of daz to blender bridge puts me..... right back where I started. It will not install.
    Ryan from daz worked with me for a bit and I have the script showing up in blender with some files he sent me but nothing in Daz. Last time I heard from him he told me he sent me the wrong files for daz  and I haven't heard back.... That might have been a week ago.
    The last scene I built would have been nice to put the daz horse in. Rendered in cycles. Built following the Create 3d Environments class from Udemy.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
