Ready - a morph and a d-form to address Aiko3's flat-thigh-top issue
mCasualmCasual Posts: 4,607
edited July 2014 in Freebies
well in the end the solution i give you is a d-form, packaged as a morph
i also include the d-form as a dsa file
it’s not perfect, but it does de-flatten the thighs and gives mildly accemptable results smile
https://sites.google.com/site/mcasualsdazscripts4/mcja3sitmorph
Post edited by mCasual on
  • English BobEnglish Bob Posts: 118
    I usually just tweak her joint parameters, but that has limitations - looking forward to a tailor-made morph! A3 has the best thighs in the business, as long as she doesn't sit down. ;)
  • mCasualmCasual Posts: 4,607
    dont' know if i'll be able to replicate this in Daz Studio
    but in Poser someone found a solution involving Inverse Kinematics and the "pull" tool http://www.poserbydesign.com/news/index.php/component/content/article/32-tutorials/pose-tutorials/69-pose-joint-corrections
    Casual said:
    ... in Poser someone found a solution involving Inverse Kinematics and the "pull" tool http://www.poserbydesign.com/news/index.php/component/content/article/32-tutorials/pose-tutorials/69-pose-joint-corrections
    I couldn't understand what was supposed to be happening in that article, in terms of underlying Poser 'mechanics'. I followed their advice step-by-step, as far as I was able, and couldn't get a good result myself. A correction morph would still be useful for both D|S and Poser, in my opinion.
    I have a suspicion this won't work on figures that aren't quite A3 (or H3 either). I use the Melody and Micah fuzzy-critter characters a lot, and this kind of fix would certainly make certain poses easier to set up. Unfortunately the figures use a custom head mesh, plus an extra Easyposed tail, so the meshes won't match and the morphs won't work. Unless anyone knows something different...?
    Morphs only need to match the body parts that are being morphed - in this case, I imagine it will be the buttocks and thighs (casual will correct me if I'm wrong!). So a custom mesh or additional parts won't make a difference.
    what i will do is a morph that only works for Aiko3
    more than that it will only be useful for sit-poses similar to the one shown here
    ( each vertex in a figure has a number and a morph simply
    tells which vertex to move and by how much - only Aiko 3 will have the
    vertex order for the morph i will build)
    That's fine - just what I wanted!
    By the way, A3 shares her vertex order with the other generation 3 figures: V3, M3, SP3... But although the morph would work on them, I doubt it would be useful. :)
    edited April 2014
    quick study
    the flattening is linked to the thigh rotation
    here you see a target curve similar to what i'll use
    1188 x 660 - 106K
    600 x 337 - 389K
    edited April 2014
    spending a few minutes on the flatthigh tops issue :)
    figure 1 : null nodes are marking the buttock vertices that are not simply rotated-around-the-thigh-node
    shown below is the script i used to obtain this
    in figure 2 we will see what their positions would be if they were ... simply rotated-around-the-thigh-node
    so the solution will probably be to generate a fix-morph using a carefull blend of those displacements
    ... but that will be next time !
    figure3 and 4 show the buttock shell parented to the thigh bone and rotated along with it
    and figure 5 shows that a lot of things are going on when the thigh bends
    // DAZ Studio version 3.1  filetype DAZ Script
    var majorMovers_Thigh = [
     244, //1.246368408203125
     245, //1.5458928346633911
     257, //0.8236872553825378
     727, //1.5249663591384888
     731, //1.3258849382400513
     737, //0.6463871598243713
    thigh = Scene.getPrimarySelection();
    buttock = thigh.getNodeParent();
    showDiff( thigh, buttock )
    function showDiff( rotatorbone, rotatedBone )
     thighobj = rotatedBone.getObject()
     thighcgeo = thighobj.getCachedGeom()
     thighshape = thighobj.getCurrentShape()
     thighgeo = thighshape.getGeometry()
     n = thighcgeo.getNumVertices();
     rot = rotatorbone.getWSRot()
     pos = rotatorbone.getWSPos()
     var cpt = 0;
     for( i = 0; i < n; i++ )
      v1 = thighgeo.getVertex( i );
      v1 = v1.subtract( pos );
      v1 = rot.multVec( v1 );
      v1 = v1.add( pos )
      v2 = thighcgeo.getVertex( i );
      d = v1.subtract( v2 ).length();
      if( d > 0.1 )
       debug( i + " " +  d );
       addnode( cpt++, v2 );
    function addnode( ii, v )
     node = Scene.findNode( "v" + ii )
     if( !node )
      node = new DzNode()
      node.name = "v" + ii
      Scene.addNode( node );
     node.setWSPos( v );
    1426 x 794 - 187K
    1426 x 798 - 96K
    1418 x 796 - 106K
    1422 x 800 - 119K
    1012 x 580 - 96K
    edited April 2014
    in poser (7) we can see the red/green lines which delimit the regions under the influence of the thigh Bend
    now ... what if we move one of them? ( by now poser probably destroyed aiko's rig )
    fig2 ... interesting no? it doesnt look too bad
    and somewhere in the CR2 those angles can be changed
    it can possibly be done using a daz script "live"
    i didnt know it but you dont need to be in Poser's setup room to use the Joint Editor
    which is a good thing because entering the setup room is extremely scary for the Aikos of this world
    Fig 3 - apparently the angle is called Incl(uded) Dynamic C
    Fig 4 - changing the other green like, removed much of the back-oof-the=thigh bulge ... interesting results here too, with a minimum of effort
    Figure 5 - that's the initial vialues for - so we just have to locate those in the CR2 ...
    the changes to make for the right thigh bend would be something like
    284.443 --------> 337
    240.691 ----------> 225
    200 x 564 - 24K
    984 x 816 - 88K
    983 x 787 - 83K
    782 x 728 - 46K
    802 x 714 - 33K
    edited April 2014
    so i make a copy of aiko's cr2 which i call aikoMissThigh.cr2
    i open it in wordpad
    i look for actor rThigh
    ( is it me or didnt wordpad handle humongous files well in XP and not well at all in Windows 7? )
    and within rThigh i find the "JointX" channel which holds our angles ! albeit with a 360 degrees offset ( probably to keep angles between -180 and 180 )
    so uhhh i change
    the second value (B) from -75.5571 ( = 284 - 360 ) to ( 337 - 360 ) = -23
    and i change the third value (C) from -114.992 ( = 240.691 - 360 approx!? ) to ( 225-360 ) = - 135
    save, load aikomissthigh in DS3A and it ......... didnt work
    so i search for the angle 9.64795
    and i find 4 occurences of a jointX
    i change the -75.5571 angles to -23 and the -114.992 angles to -135
    save aikomissthigh
    load her in DS3
    Figure 2 it kinda works but it's rough, no flat thighs but rough bemd
    Figure 3 the back of the thigh/buttock fix worked too, but it reduced the stretch area too much and the "accordion" is rough
    on the other hand this part could be hidden by the seat
    Fig 4 - in previous examples we were Bending the thigh -90 degrees to exagerate the problem, but here we split that angle between the thigh and the buttock angles, -45 degrees each and it looks ok!
    figure 5 - idem
    1014 x 594 - 40K
    1022 x 594 - 51K
    1018 x 588 - 36K
    1018 x 586 - 32K
    800 x 600 - 95K
    edited May 2014
    worked on the issue some more !
    that's the target shape for the morph
    the thigh-top arcs were modified to end at the bikini uh arches
    the thigh side bend arcs need to have a larger radius i think
    in real live the acute folds begin about mid-way
    ( mcjTeleblender export followed by Blender Cycles render )
    figure 2 i may also do something for the underside
    1920 x 1200 - 513K
    1920 x 1200 - 342K
    edited May 2014
    a few hundred tweaks later
    some of it on the sides near the bikini "gills"
    so the acute-angle skin fold begins closer the the middle
    1920 x 1200 - 186K
    1920 x 1200 - 1M
    1920 x 916 - 268K
    1920 x 1200 - 255K
    edited May 2014
    back of the thighs substantially pushed up
    next time i get back to this project i'll build the morph from this "sculpture" and post it on my site !
    1920 x 1200 - 982K
    1920 x 1200 - 527K
  • FightingwolfFightingwolf Posts: 50
    This video show how I fixed A3's flat thighs. So far I haven't had a flat thigh pose that I couldn't fix in Poser.
    http://www.poserbydesign.com/news/index.php/component/allvideoshare/video/latest/a3-flat-thigh-fix
    Additional Aiko 3 Flat thigh Solutions
    Solution for those without Poser Pro 2014:
    When Posing Aiko 3 in a seated position
    STEP 1: Pose the buttock (upper thigh) in the seated position. Bend this as far as it will go.
    STEP 2: Pose the thigh in the seated position
    These two steps will greatly minimize the flat thigh look.
    If you have Poser Pro 2014 follow the steps above and do step 3 below
    Step 3: Use the Smooth Tool to smooth out the bend
    I did a quick render in Poser Pro 2014 using the smooth tool. I know that new morph dials can be created using the morph brush but I'm not sure if it works the same with the Smooth Tool
    788 x 431 - 76K
    edited July 2014
    thanks ! i may generate the morph using what i can imagine smoothing works like
    or using by observing how V4 / Genesis bends thighs
    1920 x 1080 - 493K
    1920 x 1080 - 418K
  • fleetppfleetpp Posts: 199
    I am patiently waiting for the Aiko 3 morph.
  • TheCastellanTheCastellan Posts: 711
    Same :D
    Is is just on my PC (using DAZ studio 3), or does Aiko 3's right buttock bend more that the left buttock?
    on my version , the "generation 3" Aiko both legs have the same limits -50 degrees to 30 degrees
    the Genesis based Aiko3 may be different
    for the same bend angle, the difference between both legs is extremely small\
    each slider in the parameters tab has a button that opens a settings menu where you can see/change those limits
    edited July 2014
    i think i'll make it a simple morph which i created using a d-form
    also, i'll include the d-form in a .daz file
    so you can apply it to skirts and pants
    1280 x 808 - 384K
    962 x 562 - 144K
    1600 x 900 - 300K
    1600 x 900 - 300K
    edited July 2014
    Thanks, I learned something new.
    I'm looking forward to the morph.
    Post edited by fleetpp on
    edited July 2014
    it's not perfect, but it does de-flatten the thighs and gives mildly accemptable results :)
    1200 x 758 - 378K
    1200 x 758 - 379K
    1200 x 758 - 562K
    edited July 2014
    Thank you; downloading now.
    EDIT: The DSA file works great in DAZ Studio 3.
  • VilianVilian Posts: 293
    Have to try out this miracle tool in Poser, because this may be the solution to the biggest of my problems with A3... Unfortunately, recently I don't have much time for playing with anything fun, even Poser *sobs*
