Help finding some hair
skelegraphskelegraph Posts: 31
edited February 2021 in The Commons
Hey fam, I am curious if anyone can reccomend any hair that looks like the below. This is SOPHIE, a musician who sadly passed away this weekend. I was thinking of making a portrait of her in Daz and need help finding hair that matches:
Thank you!
Post edited by skelegraph on
  • I was so sad to hear about that over the weekend. SOPHIE's experimentalism is something that I've always admired, even if I didn't always enjoy the end result.
    For the hair, you might consider Sprite's Spirit, although it has more of a side part: https://www.daz3d.com/sprites-spirit-hair-for-genesis-8-females
    You'd probably want another shader on it to create more unified curls, maybe something from UHT2 or ColorWerx.
  • FSMCDesignsFSMCDesigns Posts: 12,858
    maybe this woud  work. https://www.renderosity.com/rr/mod/bcs/biscuits-lois-hair/117613/
    it has a GF3 fit, but you could probably just parent it to the head if thast didn't work
  • Thanks friends. Indeed, it is a huge loss for pop music and the LGBT community.
    These are close, but the side part isn't in keeping with the style I'm looking for. Does anyone know of anything similar, but with a middle part?
    Thank you!
  • Closest I can think of is Esme, also in Biscuits' shop over on Rendo, but while it has a center part it lacks what Sprite's Spirit and Lois have in the rest of it.
    You could also try Amie (same artist), but it's more of a wave than a curl and the texture may be too aggressive at the roots.
    AprilYSH has Caleela available here, and you could uncheck the limits on the Length dial and set it heavily into the negative (-300% maybe), to pull the hair way up. But, the curls are larger barrel curls than the ones in your references and so you'll have fewer of them. Could still be worth a look, I've never found having a ton of that particular PA's hair to be any kind of a bad thing as it's all great quality and beautiful.
  • TaozTaoz Posts: 10,384
    This is Long Mane Hair , actually a male hair but if autofits fine to G8F.  I've done some quick editing of the mesh with Mesh Grabber and changed the shader color a bit (can probably be done better) and then converted it to SubD.
    799 x 930 - 1M
    Post edited by Taoz on
