Genesis 8.1 / Victoria 8.1
1…2930323435…59
    Thyranq said:
    AllenArt said:
    It is ONLY expressions that are not compatible. All morphs, poses, hair, clothing and wearables (with the exception of geoshells, for which there is a workaround for now) will STILL WORK.
    This.
    This has been said SOO many times, and it needs to be stressed. Too many people are getting the wrong idea that all their G8F stuff is obsolete, and it's not.
    But all my expressions ARE working! See above.
    Richard Haseltine said:
    PerttiA said:
    WendyLuvsCatz said:
    absolutely none of the expressions in my content under expressions work and yes all those useless sliders annoy me too
    since they are incompatible don't show them
    the HD ones all work and a few other sliders as well as of course the FACS ones
    I can probably export each one as an obj and use morphloader then move them from body to head or edit the dsf files but just noooo
    The "annoying sliders" come from G8.1 reading not only the G8.1 morph folder but also G8.0 morph folder with DS 4.15 and I assume that it cannot distinquish the (PA made) expression morphs from any other morphs, at least outside the Daz 3D folder (where the visemes are located)
    I gather that DS can distinguish - if the product is set up for it to do so.
    But how many G8.0 expressions would be set up for that since this is the first time when loading a base character, makes DS read morph folders for two base characters.
    Inside the DAZ 3D folder there is a clear categorisation for expression-related morphs, so it could have been taken into consideration inside the code.
    Wonderland said:
    So far every paid expression I tried does work! I haven't tried them alone to see if they are exactly as they should be since I combine them in increments anyway. But so far, they all do something! And visemes are still there and work...
    This is crazy, everything works!
    I'm not sure why I can't see visemes...unless it's because I have the HD Visemes product and that replaces the stock ones.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,743
    yeah mouth open is tricky, jaw open works
    mouth upper up and lower down bares teeth
  • takezo_3001takezo_3001 Posts: 2,044
    edited January 2021
    melissastjames said:
    In case anybody is interested, here is a side-by-side comparison of a franken-skin I put together (mostly Babina 8)(I only updated the head, so please ignore any funk in the neck on the right) -
    And here is the HDRI I used in case anybody wants to replicate the lighting - https://hdrihaven.com/hdri/?h=studio_small_03
    PBR shader works best with spectral rendering enabled...
    Oh, and we finally have the vellus hair!
    1478 x 1273 - 319K
    Post edited by takezo_3001 on
  • Wonderland said:
    Thyranq said:
    This.
    Yes, it's some expressions that don't work.
  • dawnbladedawnblade Posts: 1,723
    Wonderland said:
    dawnblade said:
    Wonderland said:
    I don’t even have Genesis 8.1. I just downloaded the new package from DIM and have Genesis 8 Basic Female and Genesis 8 Female Dev Load INSIDE Genesis 8 MALE Powerpose Templates. Where IS 8.1?
    Click on Genesis 8 Female folder and she is alongside G8F.
    There is no Genesis 8 Female folder since I updated. The figures are under Male Powepose and G8 female only.
    I think Dawnblade is looking in the Content Library under Daz Studio Formats while you are using one of the category views. The bad categorisation is apparently known and being worked on.
     Correct! I updated my post right afterwards along with a screenshot.
  • lexbairdlexbaird Posts: 168
    Is this new Genesis 8.1 usable with earlier versions of Daz Studio?
    Being on a Mac with Catalina, I am holding at Version 4.12.1.118, which is the last stable version for me as far as I know. This means that such things as Hexagon 2.5 and Filiment renders are not useable. Is this yet another thing Daz has let Mac users fall behind on?
    edited January 2021
    I've never liked the look of spectral rendering...it seems to give everything a green cast and pops seams into visibility. Not to mention exponentially higher rendering time.
    I also have to wonder what the real difference is that makes the Uber shader somehow not PBR? Because I've always been of the understanding that it is. I get the new shader is called "PBR Shader" but isn't the Uber shader still technically a physically based rendering shader?
    Post edited by MelissaGT on
    It does load and pose, but without any of the G8.0F morphs - Using 4.12.0.86 on W7
    Maybe it was. Remeber that not all expressions are broken in 8.1.
    Wonderland said:
    Thyranq said:
    This.
     And the only place I see this disclaimer is under the video on the V8.1 product page. It also says you can't use G8.1 content on previous characters, including G8, so it's a bit confusing on which expressions won't work from G8 to G8.1, and which specific content isn't backwards compatible from G8.1. Especially since some have found workarounds using Scene ID:
    "Note that your Genesis 8 products should work with Genesis 8.1 characters, with the exception of some expressions. However, you cannot apply your Genesis 8.1 content to Genesis 8 or earlier characters."
    Sort of.  You can load 8.1, but you can't access any previous morphs because the back-end technology is only in 4.15.  If you render using the new PBR shader, it seems it'll turn out white.
  • charlescharles Posts: 866
    Masterstroke said:
    Masterstroke said:
    Wonderland said:
    I don’t understand why new clothes and pose products are no longer compatible with G8. If that’s true, my shopping is pretty much done here. [...]
    Here's a little work around for clothes and props:
    Scene Tab -> Edit -> Scene identification -> Prefered Base
    Set it Genesis 8/Female
    then conform your 8.1 clothes to Genesis 8 Female
    I must be on everybody's ignore list...
    I feel the same, I think most just read the last 1 or 2 comments in a 30 page thread.
    edited January 2021
    I'm finding all my expression dials I've tried so far work. I always combine them so I'm not sure if they look exactly the same as they do on G8 but they all do something. I panicked for nothing lol.
    1302 x 1728 - 275K
    Post edited by Wonderland on
  • AllenArtAllenArt Posts: 7,176
    Wonderland said:
    Thyranq said:
    This.
    All of my expressions from the original Daz expressions work, but some others by 3rd parties do not. Are you sure you're on 8.1 or are you using all Daz expressions?
  • AllenArt said:
    Bamboozler said:
    I've given it a couple days to see if an update would come through DIM that would fix my problem, but it hasn't happened thus far.
    I have no Genesis 8 Female Starter Essentials.They're installed via DIM. I tried uninstalling and reinstalling, but they just don't show up in Daz.
    Here's a pic of things I do have, according to Content Manager inside Daz.
    What to do? Just keep waiting to see if it gets fixed? I put in a support ticket, but I don't expect that to be of any use.
    I had to install mine manually. I figured it was just easier to take the path of least resistance.
    Hmm, might be worth trying. Probably can't make it worse, at least.
  • DaikatanaDaikatana Posts: 830
    Daikatana said:
    takezo_3001 said:
    Daikatana said:
    Well, this is interesting.  While the product store page does state that the Vellus hair is included with the victoria 8.1 figure, that is apparently NOT the case.  While I did put in a sales support ticket, those have been taking so long to answer recently that it just adds to my frustration.  I had held off on purchasing the V8.1 figure in large part because of the somewhat misleading advertising-which I am choosing to believe was unintentional but with the statements on the forum that DAZ3D was including it with V8.1, I decided to go ahead with the purchase.  Now, I find that even though the product store page states it is included, it is still apparently NOT included.  I have uninstalled -and made sure to delete the download package- via DIM and still no vellus hair. Hopefully someone here can advise me?
    I guess that it was delayed due to Daz needing to package the item, but that's my guess, Daz needs to confirm that, anyway it's coming soon as it's located on the V8.1 product page.
    Its alreadly listed on the product page.  I checked that.  Its definitely NOT in my library though.
    I've sent in a query on this.
    Andd the Vellus hair just showed up in DIM.  Thank you Mr. Haseltine!
    AllenArt said:
    Wonderland said:
    Thyranq said:
    This.
    Yes using 8.1 and tried a bunch of PA expressions. Haven’t even opened the Daz ones. A few of the ones that came with specific characters like 3DU seem like they may be a bit off, but they do something. Since I rarely use full expressions, but increments of many, everything seems to be OK for me so far. I haven’t found an expression that does nothing yet. But I have a LOT of expressions, including many specific to PA characters.
    But you can still apply materials from G8/G3 characters, giving you essentially the same as when the base G8 came out - New base figure but very little morphs to work with.
    With DS 4.15 the situation changes and you have most of your G8 morphs available.
    4.15 works on Catalina. I am using it on macOS 10.15.7
    It is rather okay, but you may experience render issues with opacity. This seems to be a general 4.15 issue and not related to Macs. Filament renderer is not available, the rest is and so far it seems to work. What I did before upgrading:
    • make a copy of the DAZ Studio application folder "/Applications/DAZ 3D/DAZStudio4 64-bit". You can name is as you like, I have named mine "__DAZ Studio 4.12"
    • make a copy of your user's "Library" DAZ folder, "/Users/<username>/Library/Application Support/DAZ 3D". I kept the orignal name and prefixed it with "__412_"
    Then do the upgrade. That way, you can move back to 4.12 if things go really bad,
  • Richard John SRichard John S Posts: 391
    edited January 2021
    I have to say that I really like the improvements in Genesis 8.1. I also like how everything from Genesis 8 including morphs work!
    1350 x 1080 - 1M
    Post edited by Richard John S on
    Wonderland said:
    AllenArt said:
    Wonderland said:
    Thyranq said:
    This.
    even all those Zeddicus ones that come with the pro bundles?
    WendyLuvsCatz said:
    Wonderland said:
    AllenArt said:
    Wonderland said:
    Thyranq said:
    This.
    Yes!
    PA eyelash morphs don’t work though because these are different lashes.
    Thanks. I dunno if the increased facial expression control is worth the hassle, since I play with opacities a lot. But it's good to know 4.15 works. I'll keep an eye on it for bugfixes.
  • KharmaKharma Posts: 3,214
    @Wonderland, where did you find the visemes for G8.1?  I see them for G8F  but no way to apply to 8.1 .
    edited January 2021
    Wonderland said:
    WendyLuvsCatz said:
    Wonderland said:
    AllenArt said:
    Wonderland said:
    Thyranq said:
    This.
    Yes!
    well thats really odd, maybe my installation is hosed, I already uninstalled all the basics and reinstalled them once
    so maybe lipsync and mimic also should work and something is borked on my library?
    Under Pose Controls/Head
  • thd777thd777 Posts: 947
    Wonderland said:
    WendyLuvsCatz said:
    Wonderland said:
    AllenArt said:
    Wonderland said:
    Thyranq said:
    This.
    Yes!
    Can you maybe show one of the Z expression just diasled onto the Base G8.1 Fermale? Like in my example? Because for me nothing happens with any of those.
    TD
    3817 x 2013 - 2M
