Genesis 8.1 / Victoria 8.1
1…89111314…59
  • Haruchai said:
    rayglendenning said:
    Haruchai said:
    melissastjames said:
    I purchased Victoria 8.1 and got her loaded up, but I'm not finding any vellus hair? I don't see that listed on her product page as "included" either...but it's listed as a feature of 8.1...so...?
    Seperate product called Genesis 8.1 Female Vellus Hair
    Is this only available with Victoria 8.1?
    It's part of the Victoria 8.1 University Bundle. Bundle only it appears.
    Shame, nothing else I want in the bundle
  • FntsyArtFntsyArt Posts: 27
    edited January 2021
    Personally, I'm pleasantly surprised by how this works. I took one of my favorite 8 characters, Pia HD, morphed the 8.1 base, and applied the character's materials. I used poses for 8 and an outfit for 3. I adjusted the smile etc. and did a quick test render. I'm very happy how easy this was to do.
    1920 x 1080 - 3M
    Post edited by FntsyArt on
  • ChangelingChickChangelingChick Posts: 3,453
    edited January 2021
    Edit: Weirdly spaced double post.
    Post edited by ChangelingChick on
  • scorpioscorpio Posts: 8,533
    Having looked it seems you have to buy G8.1 - honestly that is not going to happen - total rip off.
  • Interesting...
    So, Victoria 8.1 has a "Makeup Weight" instead of "Diffuse Overlay". More or less the same thing, but it's a different label.
    (I don't think the Genesis 8 diffuse overlay makeups work well on the 8.1 UV maps without modification, but I only tried with Babina 8 late last night for me... so maybe it'll work okay, but I kind of doubt it. I'm positive I can make them work eventually.)
    It's going to take some time to unpack the Victoria 8.1 surface details in my brain because there are a few new things added in there and some different labels as well.
    Nope. You already own it. G8.1 is in your Genesis 8 Starter Essentials already.
  • scorpio said:
    Richard Haseltine said:
    Ben Oaks said:
    WendyLuvsCatz said:
    unless they made it Carrara compatible I really don't care.
    Translation, likely nothing to see here for me. indecision
    I concur. It appears to be yet another attempt to wrangle money for 'New and improved content'. I'm not impressed, and I will not participate in this any longer. I will study up, and create my own content from now on.
    It showcases new features, most of which (bar the velus hair, on which we have sent in a queery) are free. Victoria X is the flagship figure for the X generation, so with an update to 8.1 of coruse we get a victoria 8.1 (which is a new character, not just a rejig of Victoria 8, as far as I can see).
    And where do we find this free stuff because I'm not seeing it in the store or DIM
    Genesis 8 Starter Essentials, Default Resources - though soem people have said they had to uninstall and reinstall rather than just update. I haven't had time to download yet.
  • melissastjames said:
    jaxprog said:
    Here's the way this new upgrade should've been implemented. All the new features should be a module like, that Genesis 8, can take advantage of, without rebuying Victoria all over again. It might as well be Genesis 9. Soon we'll see Stephanie 8.1 and all the other premier character "X" 8.1 and Genesis 8 will fade away. Calling it 8.1 is just marketing making it seem "compatible." There's alot of people here, like myself, who have spent tens of thousands of dollars since genesis 2, watching each previous version's investment get flushed down the tiolet because the previous version was found wanting or lacked compatibility.
    But Victoria 8.1 looks nothing like Victoria 8...it's literally a whole new character. They might as well have named her Sarah.
    Right, it's a new Victoria for an updated base - I would doubt we will have a flood of 8.1s to match the 8s, and if we do I'm sure they will be new characters along the same lines rather than tweaks to the older character.
    And it's my understanding that all of your G8 characters will still be able to use hair and clothing and poses made for 8.1. Or...you could load up an 8.1 base and then *pop* turn your current G8 characters into G8.1 characters. They'll still use their G8 skins, but they'll have all the other benefits of 8.1...from what I'm gathering based on reading this thread.
  • vagansvagans Posts: 422
    Daz Central had an update for Daz itself but the starter essentials didn't have any kind of update available. Thus I had to uninstall and reinstall it and it worked.
  • XenomorphineXenomorphine Posts: 2,421
    edited January 2021
    Considering all of these incompatibility quirks, I hope that content creators will continue to supply for Genesis 8, not just exclusively 8.1, for the forseeable future.
    Wondering what this means for Face Transfer, as it loads up a Genesis 8 by default.
    Because I've been wanting to depict a truly hermaphrodite character (a canonical one; Slaanesh, from the 'Warhammer' fandom), I'm intrigued by this: "Male anatomical elements will now work on females. Conversely, female anatomical elements will work on males." But aren't anatomical elements geografts? Wouldn't there be a visible texture seam where they attach to? Although, I suspect the scrotum wouldn't be able to be removed, which would make such an artistic exercise impossible.
    Post edited by Xenomorphine on
  • takezo_3001takezo_3001 Posts: 2,044
    Note to the other specular rendering users out there, you need to bump up the Transmitted Measurement Distance in order to see a compatible SSS as the default if you choose to use the much more realistic specular rendering mode!
  • So then if I just load in my custom G8F character, as far as I understand there is no way to use the new expression system, unless I convert the character into a G8.1 one. Som epeople have said, that this conversion doesn mess up the parameters of the character, so that's at least a plus.
    And what about the new shader than? In order to use that, do I also need to convert the character into a G8.1 one? Or can I somehow manually apply the new shader to the already existing custom G8F?
    And thanks for all the replies by the way!
  • Haruchai said:
    RobotHeadArt said:
    What about LIE (tattoos and makeup) and geoshells? The UVs are different so do textures laid out for G8 (and G3 which has the same UVs as G8) work on a G8.1?
    My experience so far is only with Geoshells.  If I load a Geoshell directly onto Genesis 8.1 Female and try to use an existing 8 preset it will not work. This doesn't change even if I change the UV from Base 8.1 Female to Base Female on the Geoshell.
    If I load a preset Geoshell made for 8 in one of the existing packages on to 8.1 it will load with the body white. If you are looking to add makeup to the face you can turn off the rest and it will work. If you want to add nails or arms/legs it will work if you turn off the body also. Anything that appears on the body or crosses a boundary with the body will not work.
    I suspect you would get similar error with LIE but it might work IF you change the UV to Base Female first but then you couldn't use the new skins.
    If anyone else could confirm/refute the above I would be interested :)
    G8 LIE does work on G8.1. I did a few tests of this after the geoshell was noticed. The Geoshell thing is being looked at.
  • LucielLuciel Posts: 475
    edited January 2021
    Male elements do work on females (and i'd assume female will work on male when Male 8.1 arrives).
    As it's basically just an alternative geograph, if textures are made specifically for male genitals on female then there won't be a seam any more than when the female parts are used. Unfortunately there's no textures, and from what I can see Victoria 8.1 doesn't have textures for male regions (maybe she does but it's not listed), so they might be a bit hard to come by. So you'll need to wait for some tools or figures that specifically include the other anatomy, or make your own.
    You could always shrink the rear dangly region. Or make/find a morph.. laugh
    Post edited by Luciel on
  • SotoSoto Posts: 1,451
    An analogy goes like this. Microsft used present different versions of Windows to its customers. Each new version replaced the previous version giving the customer new features and improved functionality and you paid for it. Those days are over with. Microsoft now makes one operating system, windows 10, and improves the same operating system with all the new features via updates, without having to buy windows all over again. This is the way Genesis 8 should be. One Genesis 8 and it improves, whilst all previous investment retains its value as opposed to a new Victoria with features that the all the previous investments cannot benefit from.
    Despite my opinion, I might buy 8.1 and I might not.  What I can tell you in this current moment in time, is I'm not too pleased with the latest development in its current implementation. Yes, it looks amazing and is amazing, but I shouldn't have to shell out thousands of more dollars over the course of the future rebuying the same models just so she smile with greater realism. All my library I've invested in since June 2013 should be able to use this new technology.
    Genesis 8.1 is free.
    Victoria 8.1 is a new character, you wouldn't be buying her again.
    The new features are part of Genesis 8.1, not Victoria.8.1. Your previous characters can benefit from the new features without spending anything.
    It's not Genesis 9 because it's not a new figure, it just improves Genesis 8, all your Genesis 8 content except some expressions work on Genesis 8.1 as they always did, which seems compatible enough for me.
    The way you describe it should be, is actually the way it is.
    Daz Central's "Daz Studio" includes the base cotnent as well as the application.
  • HylasHylas Posts: 5,344
    What about Geografts?
  • Matt_CastleMatt_Castle Posts: 3,294
    All the geografts I've tried so far still work, including those from *ahem* other stores.
    Yup. The mesh is the same so the grafts will still work :D
    Still can't find the genesis 8.1 vellus hair described on the genesis 8.1 announcement page :-/
  • HaruchaiHaruchai Posts: 2,040
    Thank you for the update, really appreciated
  • artistb3artistb3 Posts: 188
    To those new to DS with Genesis 8 and waking up to find that those G8 characters you bought are no longer compatible with new content, welcome to the Obsolescence Club.  I have to tell you, however, you likely have it easy.  Imagine waking up to find that your G1 and G2 (even worse) were suddenly obsolete.  All the money and time invested, much of it down the drain.
    Oh yes, there are always a number of people scurring around, excited like it's Christmas morning, "Oh boy, a new version of Genesis!".  The end-users who are already heavily invested are thinking, "Here we go again..."
    Enjoy!
    yes
  • Faeryl WomynFaeryl Womyn Posts: 3,781
    Do I have to upgrade to Daz 4.15 in order to use the new G8.1...I currently have 4.12 installed and not exactly looking forware to upgradign with so many bugs still in it.
    Odd_Platypus said:
    skboa said:
    Urich3d said:
    Does anyone know how to get th G8.1 FASC interface to appear?
    It's located under Anatomy in smart content.
    Though it doesn't work for me, often times it just crashes Daz or it just does nothing when I try to move something.
    Trying to drag any of the FACS nodes just crashes DS for me every time as well.
    Which version of DS?
    For me too - 4.15.0.2
  • DVoidDVoid Posts: 40
     This was discussed on the previous page. There's a slight marketing/communication/wording mishap, regarding this.
    This is inaccurate. All the G8 characters you bought are compatible with the new content. There's just more to play with in addition.
    Or buy UV swap and use Genesis 8 Male materials on both figure and geograft
    Genesis 8 UV Swap: Male and Female Base | 3D Models and 3D Software by Daz 3D
    Enjoy!
     But the content you bought before hasn't become obsolete over night. You can still use them. Especially during the time while new content for the new figure are still being made.
    As an example, I still use G3 and I don't feel at all like I'm missing out or like I've been left behind. There are still a lot of content being made with G3 support.
    I know people that still use V4, one of whom only recently decided to update to G8. All those old content don't stop working just over night.
  • evilded777evilded777 Posts: 2,550
    edited January 2021
    Not entirely OT.
    This new shader is going to take some getting used to and some learning... but: ok, sign me up.  Huge improvement and I have barely scratched the surface here with a G3 male. And I didn't have to change my TMD.  Maybe this new shader helps to demonstrate how Dual Lobe Specular actually works, because I largely didn't care for it... now I think I am better understanding how to use it.
    1200 x 960 - 388K
    Post edited by evilded777 on
