Dynamic Clothing Questions
2»
    To stop the cloth going through the floor you need a thicker, more solid floor.
  • kyoto kidkyoto kid Posts: 42,351
    ...so the floor plane on Blondie9999's Backdrops made easy isn't sufficient? Not wanting to bog down the process with a more complex model.
  • edited December 1969
    I'll try upgrading my DCC if I can then. It can't hurt. Thanks for the tip.
    When it comes to floors, remember that the cloth doesn't collide with the object, it collides with the polygon edges of the object mesh. If the mesh is too open, the cloth will "fall through the holes". If the floor's smooth and flat, try adding a plane primitive with a bit more mesh density, lay it flat on the floor, make it transparent and set the cloth to collide with it instead of the floor.
    edited July 2014
    ...thank you, that worked.
    Post edited by kyoto kid on
