• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
using mirror in Blender 2.8 *SOLVED*
KharmaKharma Posts: 3,214
January 2021 edited January 2021 in Blender Discussion
Hi can someone help me to use the mirror function in Blender 2.8?  I don't know why it won't work, I am trying to modify the ear of G8F and mirror the changes on the other ear but when I hit CTRL M and select the X option then go to the right ear ( on my right looking at the screen) and manipulate that ear, nothing happens to the ear on the other side. Is there something I need to do to validate the mirror command once I select it to get it to work?
Post edited by Kharma on January 2021
  • nicsttnicstt Posts: 11,715
    Personally, I'd sculpt the changes with the mirror option enabled for something like using a studio figure that i can't necessarily change geometry-wise; first create a shape key, so if it's wrong can delete it - or dial down how much is used; just select the shape key before making changes to be sure they apply there.
    I've never actually mirrored the way you explain; I have either used mirror modifier or scult with mirror on.
    Post edited by nicstt on January 2021
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,258
    January 2021
    I think you want to be using a mirror modifier, rather than the mirror operator. I think you just mirrored the object and because it is already symmetrical, you didn't notice any change.
    You'll have to delete half of your model perfectly at the x plane, add a mirror modifier, and check "clipping" and "merge".
    You can apply the modifier when you're done.
  • KharmaKharma Posts: 3,214
    I was following the steps in a tutorial, but the person was using an older version 2.78 or 2.79?  So when they applied what she called symmetry then used the mirror and set it across x axis, then when she modified the ear using grab and pulling it up into an elf ear, the opposite ear mirrored what she was doing .  Is using that same function in 2.8 a different process?  I have Blender  2.79 as well so maybe I will try in that one and see if it works.  I just feel I am missing a step...  learning Blender is hard!  LoL
    The tutorial also says not to apply any modifiers because it will add geometry to G8F and then the morph I am trying to create won't import back to Studio
    I found the answer:  On the right side of the screen on the Properties menu  under Active tool and workspace ( the first icon at the top) expand the options menu and there is 2 boxes  labelled X Mirror and topology Mirror.  I checked the X Mirror box and now when I edit my mesh on the right ear the left ear mirrors the action.
    369 x 278 - 13K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
