4.15 help
I just got me a new computer and started using Dim to install itebs. WhenI try to save the scene Daz Studio bring up a comment saying it can't be done. Secondly whenever I select any Genesis 8 Female it woulg not allow me to select wardroge or hair unless I click off of it. I'm usind 4.15 and I was hoping someone could help me figure this out. Thank you in Advance
Please post a screen shot of the error.
The Smart Content issue may be due to a product you have isntalled - try reinstalling the Genesis 8 Starter Essentials and see if that will correct the metadata (which includes the compatibility details). There were one or two items that would do this.
Yes reinstalling Genesis 8 solved one problem. Here's the sceenshot hopefully
https://mega.nz/file/qg92ARBT#AwAhxL6yvBVP17wu3qykLPzNppYTXZHMC5qo3Pd9VOI
That was saving the thumbnail, is the actual content file (.duf) there - just without an image in the content pane?
ok
yes it's there
OK, that does seem to happen sometimes - I've no idea why. You could always use File>Save Last Draw to, in effect, take a screen shot of the Viewport and save it to the same folder in PNG format with the same name as the scene to generate a thumbnail (or not, if it failed), or even do a full render and save as PNG with the same name as the scene (it would need to be only 91 pixels square) but obviously it is worrying when things like this happen.
