Morphs affecting fit props?
Hi, I made a custom morph for a genesis 8 face, and I need the eyelashes to follow it, as in the eyelashes morphing along the face? "Transfer active morphs" does NOT work for this.
Have you saved the cuistom morph as an asset (File>Save As>Support Assets>Morph Asset)? AutoFollow does not, or has not in the past at least, work reliably for morphs embedded in the scene file.
It's a morph I made in Blender and applied with the morph loader, what should I select to be saved?
File>Save As>Support Assets>Morph Asset - then you tell it which morph(s) to save. Make sure they are zero before saving.
Got it, thanks.
In the end I just used the transfer utility, saving a morph as an asset doesn't propagate it to fit props.
Sorry, I saw fit and assumed you meant that the props were figures fitted to the morphed figure. No, morphs are not projected into props; for items with only a limited area of contact (e.g. badges, studs, possibly belt pouches) a Rigid Follow Node might be an option.
