Transfer a taller morph of G8F to G3F
I've been trying to transfer a body morph (Leah) from G8F to G3F. The character is taller than G3F, and I am getting wonky arms after transfer. I have replicated this with Victoria 8 (who is also taller)
I assume I am missing the combination of settings in the Transfer Utility to do this.
I am using this transfer process, starting at PART 2, from @Sickleyield: [Tutorial] Transferring Character Morphs G1G2G3G8 by SickleYield on DeviantArt
I have tried a lot of combinations of 45 degrees down and legs at 6 degrees out/in, or clones of A pose or T pose...but I still get wonky arms as I dial it into G3F after transfer.
Here is what I am talking about using the V8 body morph...it is much, much worse with the Leah morph. Any ideas?
Darn, this must be more difficult than I thought! I think this is the first time I posted and went without reply for a day, and I've been around a while.
It's never easy. Sickleyield is awesome! She is just, really one of the best, most generous people in the community. And she has a video tutorial that likely includes a fix for your problem. I suspect (can't prove) that if you changed the figure pose, the height difference would give you the noodle-arms problem. The part you want starts at the 3:40 mark in the linked video. I hope this helps you.
Thanks for the idea! I am going to try it out right now :)
EDIT - No, it did not work, unfrotunately. In the video, the shape transferred well, but the bending/rigging was off. In my case the shape itself is not getting transferred correctly. Then again, after I get the shape (if I can) transferred, you are right, I will need to do that, so thanks!
I think I am just going to up-convert clothes/characters to G8F...now I just need a sale on: Character Converter from Genesis 3 Female to Genesis 8 Female | 3D Models and 3D Software by Daz 3D
That may be an easier way to do it!
