Star Trek Builders Thread!
1…1516182021…51
    Here's a little nose ridge for V4 and a hat loosely based on the one the spy wore ;-)
    http://www.sharecg.com/v/63920/view/11/Poser/NoseRidge_Morph-V4_nc
    http://www.ShareCG.com/v/63921/view/11/Poser/Hat_V4
    600 x 600 - 37K
    600 x 600 - 45K
    Mattymanx said:
    ssgbryan said:
    Ok
    Workflow:
    1. Export from 3dsMax to create obj. Receive obj (but not bacon)
    2. Import via obj into Poser.
    3. Save as Prop.
    4. pp2 file created. all obj information is inserted into pp2 file. Don't want that, so I need to use the obj2pp2 script.
    I have the obj2pp2 script (the new location is at: http://jwas3d.com Finding it in the forums could end up being an exercise in frustration.)
    Where does this script go in DS3? I stopped using it after throwing a mouse at the monitor and breaking it in frustration.
    OBJ2PP2 is not for stripping out the OBJ Data from a PP2. Its for creating a PP2 from a model in DS without ever having to go through Poser.
    I have just uploaded the last version of the OBJ2PP2 exporter here - http://www.mediafire.com/?3m5gbz5f8bjjgjm
    I recommend it over the older versions cause the older versions will rename your surfaces and thats rather anoying.
    The OBJ2PP2 can go in any folder in your Content folder tree. I tossed my copy in the Scripts folder.
    Your welcome Shadowhawk. Though I cannot take credit for the textures or modeling for that matter! :)
    Thank you for the ships and the new script :-)
  • jaguarry3jaguarry3 Posts: 230
    edited August 2012
    Mattymanx said:
    UPDATE...
    The Ferengi Marauder is now available over at Trekmeshes.ch
    The Volga is not yet back online at the moment
    Thanks Matty: nice one
    900 x 578 - 148K
    Post edited by jaguarry3 on
    The updated USS Volga is back online and ready to download!
  • GRFK DSGN UnlimitedGRFK DSGN Unlimited Posts: 1,126
    Here's the next page in the story. If you want to catch up on it you'll have to go to my blog. And since I CAN'T list the link here, you'd need to email or PM me. Please comment...
    David
    600 x 464 - 252K
  • rdudarduda Posts: 586
    Any one going to the Wizard World Chicago Comic Con next week?
    edited August 2012
    The updated Enterprise Refit is available. It will no longer crash DS4 when attempting to render. Several people includging myself tested it in Poser 8 and PP2012 and got mixed results. So poser users may or may not see issues with the mesh. All surface issues should be resolved (meaning it no longer glows like a lightsaber when you load it up)
    http://www.daz3d.com/forums/discussion/491/
    Post edited by Mattymanx on
  • RedfernRedfern Posts: 1,649
    Went grayscale to try capturing the feel of a promotional snapshot.
    Though in retrospect, I wonder if they would have gone to theespense of sculpting Dilithium crystal props. Probably not. More likely, if they knew of props remaing from some other production, they would "borrow" them.
    Sincerely,
    Bill
    750 x 750 - 147K
  • Ryuu@AMcCFRyuu@AMcCF Posts: 807
    Sincerely,
    Bill
    Pretty good, Bill!
    They look a bit like the crystal entities from P3X-562--So....I wonder if Kirk gets "replaced" in this episode.... ;-)
    edited August 2012
    The SS Botanybay by Prologic9 is now awailable @ F3D
    I am about to submit the USS Cantell as well and I plan on finishing at least one more today, though I would really prefer to finish a few.
    EDIT:
    The Cantell was just submitted.
    600 x 600 - 313K
    The USS Cantell is now available.
    The Cardassian Hebitian Class has just been submitted
    600 x 600 - 370K
    New posting to the blog. PM me if you need the link...
    David
    600 x 464 - 269K
  • ReisormocapReisormocap Posts: 146
    EDIT:
    Now that is a REALLY nice design. I'm going to have to see what I can do to make her fly when she's available.
    EDIT:
    The Cantell and the Hebitian Class are both available now.
    The Cantell is about the size of an Intrepid Class and the Hebitian Class is about the size of the Sovereign class
  • StarkillerStarkiller Posts: 15
    Hi all. Long time no read! As I'm no longer online, I'll pop in, from time to time, when I get the chance.
    For those who are interested, though it's not Trek, Eagle One and the MetaProbe are both released
    in Poser and D/S formats. Visit my DeviantArt page if you're interested. ^_-
    I'll pop in again the next time I visit my sister.
    Eric
    1920 x 1080 - 511K
  • ThalekThalek Posts: 318
    Does anyone remember the address to Eric's DA page?
    Try this...
    http://greywolf-starkiller.deviantart.com/
    From there you can reach his gallery where he has his goodies.
    Sincerely,
    Bill
    Thanks, Bill. That did the trick.
    Its also here in the Freebie section - http://www.daz3d.com/forums/discussion/5322/
  • TheCastellanTheCastellan Posts: 711
    Are there any non-Reliant Mirandas out there?
    edited August 2012
    Thanks, Matty!
    Anyone planning on storing their crew as cuboctahedrons as the Kelvans did in "By Any Other Name"? I ask because after fighting with Hexagon for more hours than I want to admit, I've made one. No texture yet, but I figure I can probably locate or create one. Just an object file at the moment, and no beveling on the edges. But it's mine, all mine! (Yeah, it drove me THAT crazy.)
    Edited to add:
    Okay, I applied a simple noise displacement map on it and did a hasty render.
    600 x 450 - 14K
    Post edited by Thalek on
    The displacement node really "sells" it, Thalek.
    To get the sharply defined facets without beveling, just access the block's "proprties" and reduce the "crease angle" to something around, oh, 32 degrees. I'd also scale down the overall size just a tad. Remember, Rojan could grip the the underside of the block in one hand.
    Sincerely,
    Bill
    Thanks, Bill. I'll try to get something a bit better.
    I can also get the sharp facets by going into the prop's properties and clicking on the checkbox. I was actually thinking more along the lines that the original probably didn't have very sharp edges.
    Hmm. You're right about the scale. I'd tossed in a figure for comparison; I should probably import the object somewhat smaller before turning it into a prop.
  • Richard HaseltineRichard Haseltine Posts: 111,659
    Note, however, that if the edge isn't being smoothed any displacement will pull it apart.
  • mdbruffymdbruffy Posts: 2,345
    For those that might need a dress uniform in the NG era, this might work as a base:
    http://www.runtimedna.com/search.php?mode=search&page=1
    Which item is it? When I click on the link it takes me to the last search I did on their site...
    David
    edited August 2012
    David
    It shoiuld have taken you to a whole selection of Space Defender outfits. Try this one. It's for V4, but there's one for M4, too:
    http://www.runtimedna.com/Space-Defenders-Commander-for-V4.html
    Post edited by mdbruffy on
    Thanks for the advisory, Richard. I wasn't aware of that.
  • mylochkamylochka Posts: 168
    Here's a version of the Efrosian Federation President's hair and beard I did for our own MD Bruffy. I just did an M3 version, but I could do an M4 or even V3 and V4 version if it strikes anyone's fancy.
    DOWNLOAD HERE: http://www.sharecg.com/v/64070/view/11/Poser/Efrosian-Hair-for-M3
    609 x 669 - 506K
    Oh, also, some dude on DA asked me if I knew where he (or maybe she, I dunno...) could find models of the ships from the Star Trek Online game.... Are there some of those out there?
