• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
Materials Not Loading
cliftonweathersjrcliftonweathersjr Posts: 0
November 2020 in Cinema 4D Discussion
Whenever I try to import an obj, the materials never load. I try to manually link them but they never turn out right. Is there a certain setting I need to use so that the model is imported correctly.
  • Luftsturmregiment40Luftsturmregiment40 Posts: 328
    December 2020 edited December 2020
    from DAZ to C4D or from C4D to DAZ?
    one reason that it fails could be that the per-polygon selection tags are not correctly exported or applied with default white material (this happens with "some" 3d apps that interpret countless materials with the same naming convention like in C4D as one material and apply a default material specific to the app you import the model in to.
    say model structure looks like this in Cinema 4D the materials all have the same name and in C4D this is perfectly acceptable even if all polygon selection tags have the same name (sort of) other programs treat this as one material and there the problems start
    have a look what it says in the material selection tag list in DAZ AND C4D - there could be the answer but without screenshot or scene file it's hard to tell from a distance
    either way in Cinema 4D it should look something like this
    and in DAZ it should then look like this
    I include for you a test cube in C4D format and the same cube as OBJ for you to test the import into DAZ and C4D as well
    when you import into C4D the selection tags will get named numerically for a simple reason: you could have already a selection tag named "blue" in your scene that will cause some issues so MAXON made it that way and there is nothing you can do to change that other than manually, but at the same time in other apps it will read the selection tags as made in C4D for better or worst. And there is definitly space for improvement for the developers of both programs.
    964 x 691 - 109K
    1128 x 580 - 79K
    1230 x 640 - 130K
    zip
    zip
    OBJ cube.zip
    938B
    zip
    zip
    material_shader_cube_test_im-ex.zip
    113K
    Post edited by Luftsturmregiment40 on December 2020
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
