Daz Studio Iray - Rendering Hardware Benchmarking
1121315171845
    Have you ran a single 2070 Super bench with 4.14? If you don't mind, that would give us a more direct comparison to 4.12 as each of the 4 benches you ran were all different hardware configurations.
    Also, do you plan on using Nvlink?
  • cheelong72cheelong72 Posts: 97
    edited November 2020
    System Configuration
    System/Motherboard: TUF GAMING X570-PLUS
    CPU: AMD Ryzen 9 3900X 12-Core Processor 3.79GHz (stock)
    GPU: NVIDIA GeForce RTX 2070 SUPER 8GB / stock
    GPU: NVIDIA GeForce RTX 2070 SUPER 8GB / stock [new]
    System Memory: Corsair Vengence LPX 32GB kit (4x16GB = 64GB) DDR4 @ 3200 MHz
    OS Drive: Samsung SSD 970 EVO Plus 1TB M.2 NVMe (disk 0)
    DAZ3D Drive: Samsung SSD 970 EVO Plus 1TB M.2 NVMe (disk 1)
    Asset Drive: AMD-RAID0 (Samsung SSD 860 EVO 1TB x 2)
    Operating System: Windows 10 Home 10.0.18363 Build 18636
    Nvidia Drivers Version: 27.21.14.5167 (2020.07.05)
    Daz Studio Version: 4.12.1.118 Pro Edition 64bit [old]
    Daz Studio Version: 4.14.0.8 Pro Edition 64bit [new]
    Optix Prime Acceleration: N/A (Daz Studio 4.12.1.086 or earlier only)
    GPU only
    Benchmark Results (GPU x1) [old] Daz Studio Version: 4.12.1.118 Pro Edition 64bit
    DAZ_STATS
    2020-07-16 21:37:49.876 Total Rendering Time: 5 minutes 51.51 seconds
    IRAY_STATS
    2020-07-16 21:38:08.433 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 2070 SUPER):   1800 iterations, 2.358s init, 346.371s render
    Iteration Rate: (1800 / 346.371) =  5.197 iterations per second
    Loading Time: ((0 * 3600 + 5 * 60 + 51.51) - 346.371) =  5.139 seconds
    Benchmark Results (GPU x1 - CUDA#0) [new] trial#1 Daz Studio Version: 4.14.0.8 Pro Edition 64bit
    DAZ_STATS
    2020-11-29 15:19:05.822 Total Rendering Time: 4 minutes 39.10 seconds
    IRAY_STATS
    2020-11-29 15:19:26.699 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 2070 SUPER): 1800 iterations, 1.907s init, 274.321s render
    Iteration Rate: (1800 / 274.321) =  6.561 iterations per second
    Loading Time: ((0 * 3600 + 4 * 60 + 39.10) - 274.321) =  4.779 seconds
    Benchmark Results (GPU x1 - CUDA#1[new] trial#2 Daz Studio Version: 4.14.0.8 Pro Edition 64bit
    DAZ_STATS
    2020-11-29 15:42:38.182 Total Rendering Time: 4 minutes 36.4 seconds
    IRAY_STATS
    2020-11-29 15:42:53.783 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (GeForce RTX 2070 SUPER): 1800 iterations, 2.364s init, 270.908s render
    Iteration Rate: (1800 / 270.908) =  6.64 iterations per second
    Loading Time: ((0 * 3600 + 4 * 60 + 36.4) - 270.908) =  5.42 seconds
    CPU + GPU x1
    Benchmark Results (CPU+GPU x1) [old] Daz Studio Version: 4.12.1.118 Pro Edition 64bit
    DAZ_STATS
    2020-07-16 18:46:25.543 Finished Rendering
    2020-07-16 18:46:25.567 Total Rendering Time: 4 minutes 58.22 seconds
    IRAY_STATS
    2020-07-16 18:46:52.008 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 2070 SUPER):   1509 iterations, 1.939s init, 293.483s render
    2020-07-16 18:46:52.008 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU:   291 iterations, 1.595s init, 293.221s render
    Iteration Rate: (1509 +291/ 293.483) =  6.133 iterations per second
    Loading Time: ((0 * 3600 + 4 * 60 + 58.22) - 293.483) =  5.737 seconds
    Benchmark Results (CPU + GPU - CUDA#0 ) [new] trial1#1 Daz Studio Version: 4.14.0.8 Pro Edition 64bit
    DAZ_STATS
    2020-11-29 15:30:58.718 Total Rendering Time: 6 minutes 29.26 seconds
    IRAY_STATS
    2020-11-29 15:31:38.985 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 2070 SUPER): 1441 iterations, 1.996s init, 384.491s render
    2020-11-29 15:31:38.993 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: 359 iterations, 1.703s init, 384.614s render
    Iteration Rate: ((1441+359) / 384.491) =  4.682 iterations per second
    Benchmark Results (CPU + GPU - CUDA#1[new] trial#2 Daz Studio Version: 4.14.0.8 Pro Edition 64bit
    DAZ_STATS
    2020-11-29 16:22:45.229 Total Rendering Time: 6 minutes 15.99 seconds
    IRAY_STATS
    2020-11-29 16:24:12.722 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (GeForce RTX 2070 SUPER): 1452 iterations, 1.884s init, 371.295s render
    2020-11-29 16:24:12.726 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: 348 iterations, 1.557s init, 371.467s render
    Iteration Rate: ((1452+348) / 371.467) =  4.846 iterations per second
    Loading Time: ((0 * 3600 + 6 * 60 + 15.99) - 371.467) =  4.523 seconds
     CPU + GPU x2 & GPU x2
    [NEW BENCHMARK GPUx2]
    Nvidia Drivers Version: 27.21.14.5671 (2020.09.30)
    Daz Studio Version: 4.14.0.8 Pro Edition (64 Bit)
    Benchmark Results (CPU+GPU+GPU)
    DAZ_STATS
    2020-11-29 02:42:01.188 Finished Rendering
    2020-11-29 02:42:01.225 Total Rendering Time: 3 minutes 42.6 seconds
    IRAY_STATS
    2020-11-29 02:42:15.989 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (GeForce RTX 2070 SUPER): 799 iterations, 2.800s init, 216.428s render
    2020-11-29 02:42:15.989 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 2070 SUPER): 810 iterations, 2.318s init, 216.444s render
    2020-11-29 02:42:15.989 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: 191 iterations, 1.939s init, 216.804s render
    Iteration Rate: (799+810+191/216.428) =  8.317 iterations per second
    Loading Time: ((0 * 3600 + 3 * 60 + 42.6) - 216.444) =  6.156 seconds
    Benchmark Results (GPU+GPU)
    DAZ_STATS
    2020-11-29 02:31:06.979 Finished Rendering
    2020-11-29 02:31:07.015 Total Rendering Time: 2 minutes 24.20 seconds
    IRAY_STATS
    2020-11-29 02:32:00.968 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (GeForce RTX 2070 SUPER): 902 iterations, 1.860s init, 139.457s render
    2020-11-29 02:32:00.968 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 2070 SUPER): 898 iterations, 1.754s init, 138.989s render
    Iteration Rate: (902+898/ 139.457) =  12.907 iterations per second
    Loading Time: ((0 * 3600 + 2 * 60 + 24.20) - 139.457) =  4.743 seconds
    My humble conclusion for my personaly setup for 4.14 is,
    1. NOT CPU friendly, turn off CPU rendering
    2. GPU rendering speed has improved
    EDIT: Answer to outrider "Also, do you plan on using Nvlink?"
    I do have plans on using Nvlink, but not in the near future as things seem all good at the moment. If I do later, I will post benchmark. yes
    Post edited by cheelong72 on
  • SevrinSevrin Posts: 6,301
    GPU only
    DAZ_STATS
    IRAY_STATS
    DAZ_STATS
    IRAY_STATS
    DAZ_STATS
    IRAY_STATS
    CPU + GPU x1
    DAZ_STATS
    IRAY_STATS
    DAZ_STATS
    IRAY_STATS
    DAZ_STATS
    IRAY_STATS
    DAZ_STATS
    IRAY_STATS
    DAZ_STATS
    IRAY_STATS
    Turning off CPU rendering is not new to 4.14.  It's never been a good idea to combine CPU and GPU rendering unless your CPU renders faster than your GPU.
    With my hardware, Daz 4.12 helped speed up the rendering, so I had it on. Whereas in 4.14, CPU hinders it, so I have it off.
    My benchmark makes me agree with you and disagree with you at the same time.
    GPU only Daz4.12
    GPU+CPU Daz4.12 (winner) disagree
    GPU only Daz4.14 (winner) agree
    GPU+CPU Daz4.14
  • cajhincajhin Posts: 154
    Quick test: beta 4.14.0.10 takes exactly as long as 4.14.0.8 (for me, on RTX2070S)
  • RayDAntRayDAnt Posts: 1,120
    That's as expected because they have exactly the same version of Iray embedded in them (fwiw there's a breakdown of which Iray version correlates to what Daz Studio version at the start of this thread.)
    That was my first thought, too, but then remembered talk about "how DAZ handles bump maps has improved".
    I was hoping that maybe DAZ is on a roll and revisits old code because of Filament or whatever... but nope, no improvements this time.
    Post edited by cajhin on
  • I would love to see a new benchmark for the RTX 3080 with Daz Studio Ver. 4.14.
    That's the GPU I'm considering over the 3090 for sheer cost to performance ratio. It seems 4.14 would make it even faster!
  • Waitting for the results with the rtx 3070 e rtx 3060 ti Benchmarks.
  • evacynevacyn Posts: 958
    edited December 2020
    Just got my MSI 3090 and thought I add my benchmark to the list.
    System/Motherboard: ASUS ROG Crosshair VII Hero
    CPU: AMD Ryzen 5 3600
    GPU: MSI NVIDIA GeForce RTX 3090 VENTUS 3X OC 24GB GDDR6X
    System Memory: Corsair Vengeance RGB Pro 32GB (2x16GB) DDR4 3200
    OS Drive: Crucial MX300 525GB SATA
    Asset Drive: WD Black 6TB - 7200 RPM SATA 6 Gb/s 128MB Cache
    Operating System: Windows 10 Home (Version 10.0.19042 Build 19042)
    Nvidia Drivers Version: 457.30
    Benchmark Results
    DAZ_STATS
    2020-12-02 13:32:54.693 Finished Rendering
    2020-12-02 13:32:54.728 Total Rendering Time: 1 minutes 41.61 seconds
    IRAY_STATS
    2020-12-02 13:33:02.249 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2020-12-02 13:33:02.249 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 3090): 1800 iterations, 2.198s init, 96.199s render
    Iteration Rate: (1800/ 101.61) =17.7147
    Loading Time: ((101.61) - 96.199) = 5.411
    Post edited by evacyn on
  • clab.hd989clab.hd989 Posts: 5
    1st test with the rtx 3060 ti + rtx 2060 :
    System/Motherboard: MSI X470 Gaming Plus MAX
    CPU: ADM Ryzen 5 @ 4200 Mhz
    GPU: NVIDIA RTX 3060 TI (pny rtx 3060 ti xlr8 revel epic x rgb 8gb) @ 1665 MHZ, GPU: NVIDIA RTX 2060 (pny XLR8 Gaming OC) @ 1830 MHZ
    System Memory: CORSAIR Prédator 32 GO @ 3200 MHZ
    OS Drive: OCZ Vertex 4 128 GO
    Asset Drive: SAMSUNG SSD 860 EVO 1TB
    Operating System: W10 Pro Build 20262.fe_release.201113-1436
    Nvidia Drivers Version: 457.51 GRD (NO studio for now)
    Optix Prime Acceleration: STATE (Daz Studio 4.12.1.086 or earlier only)
    Benchmark Results
    DAZ_STATS
    2020-12-04 17:14:46.393 Finished Rendering
    2020-12-04 17:14:46.432 Total Rendering Time: 2 minutes 0.93 seconds
    IRAY_STATS
    2020-12-04 17:15:01.786 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2020-12-04 17:15:01.786 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 3060 Ti): 1226 iterations, 1.826s init, 116.362s
    render
    2020-12-04 17:15:01.786 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (GeForce RTX 2060): 574 iterations, 2.013s init, 115.969s render
    Iteration Rate: (1800 / 116.36) 15.46 per second
    Loading Time: ((0*3600+2*60+0.93) - 116.362) 4.568 seconds
    Post edited by clab.hd989 on
    RTX 3060 ti only :
    Benchmark Results
    DAZ_STATS
    2020-12-04 17:36:09.324 Finished Rendering
    2020-12-04 17:36:09.360 Total Rendering Time: 2 minutes 53.70 seconds
    IRAY_STATS
    2020-12-04 17:36:21.652 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2020-12-04 17:36:21.658 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 3060 Ti): 1800 iterations, 1.913s init, 169.040s render
    Iteration Rate: (1800 / 169.040) 10.64 per second
    Loading Time: ((0*3600+2*60+53.70) - 169.040) 4.66 seconds
  • Due to the silly GPU prices atm I decided to sell my 2060 super. I actually got back the money I spent on it over a year ago. I figured if I wait until 30 series are on the shelves then I'd only get around half of that.
    In the mean time I managed to get a room heater, sorry a Titan x for a reasonable price. It's not quick by any means but it's probably the cheapest way to get a good amount of vram.
    System/Motherboard: Asrock b450m steel legend
    CPU: Ryzen 5 2600 @ stock
    GPU: Titan X (maxwell) @ stock
    System Memory: Corsair vengence 32GB @ 2933
    OS Drive: Intel  660p 512gb
    Asset Drive: Seagate Barracuda 2TB
    Operating System: Windows 10 pro 19042
    Benchmark Results
    DAZ_STATS
    2020-12-05 16:45:47.383 Finished Rendering
    2020-12-05 16:45:47.414 Total Rendering Time: 12 minutes 53.97 seconds
    IRAY_STATS
    2020-12-05 16:46:14.885 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2020-12-05 16:46:14.885 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce GTX TITAN X):      1800 iterations, 2.879s init, 771.513s render
    Iteration Rate: (1800 / 771.513) 2.33 iterations per second
    Loading Time: ((0 * 3600 + 12 * 60 + 53.97) - 771.513) 2.457 seconds
  • ghostfighter 2099ghostfighter 2099 Posts: 15
    Benchmark Results
    DAZ_STATS
    IRAY_STATS
    render
    Is possible to you rebuild the test with the rtx 3060 ti only?
    Post edited by ghostfighter 2099 on
    Benchmark Results
    DAZ_STATS
    IRAY_STATS
    render
    The next post down is the same setup but with just the 3060Ti active.
    @clab.hd989 am I correct in assuming this and this were done using DS version 4.14.2.008?
    Similarly, @droidy001 am I correct in assuming this was done using DS version 4.12.1.117?
    Post edited by RayDAnt on
  • just wanna say, the 4.14 update litarily feels like a GPU update.  went from 7M 48sec to 6m36sec on my old dying 2060.   originally planned to buy a 3090 to fulfill the project I envisioned, now I think a 3080 or 3080 ti stack up with my 2060 should be plenty
    829 x 46 - 3K
    It's 4.12.1.118
  • colcurvecolcurve Posts: 145
    do I understand the figures on the first page right and 3060ti vs 3080 is about 15% difference only? but price is like 500 vs 800?
  • nonesuch00nonesuch00 Posts: 17,929
    Well, looking at the numbers for the 3060 TI they are about 50 seconds slower than the 3090s numbers I've seen in this thread.
    I don't see no 3080 or 3070 numbers though. I'm more interested in a 3070's numbers though from a personal affordability perspective. Did I miss those posts? I know those cards are the 2 most difficult to get.
    As of this post, the only benchmark result we have for the 3080 was done on Daz Studio version 4.12.2.051 Beta. Whereas The onky 3060Ti and multiple of the 3090 results were done on DS version 4.14.0.008 Beta or newer. Since there was a major across-the-board rendering performance uplift for all graphics cards during that time, that 3080 result (nor the majority of the rest of the results compiled in this thread) is not as fast as it should be in comparison to those other 3000 series cards. We need someone to test/re-test a 3080 and post there resutls while running DS 4.14.0.008 or later here to know for sure how it really matches up.
    I think we may need to change up the table a bit to better differentiate 4.14 from the previous versions. The performance change is just too dramatic, and anybody who casually looks at the chart may be mislead by the skewed results between different versions.
    While DS versions are listed in the second chart, the big main table does not. I do not think we need to have every version of DS on there, since performance never really changed between them. But I think would should have a column on the chart just for 4.14 and even make it a different color so that it stands out from the rest. As well as a note at the top of the chart (since many people will not read notes at the bottom) describing what we have found with 4.14 so far. Every bench before 4.14 is now simply out of date.
    So, @colcurve, what we have found is that just upgrading DS to 4.14 has offered a performance jump that is on par with a full tier upgrade of hardware...sometimes even more. Once somebody benches their 3080 with 4.14 I believe it will be faster than the 3090 was in 4.12. My 1080tis cut 30 seconds off their previous bench times. We have never seen a performance lift like this from just upgrading Daz, not since the introduction of Iray RTX.
    Post edited by outrider42 on
  • LenioTGLenioTG Posts: 2,118
    Hi RayDAnt, is it possible that you have missed a few benchmarks?
    I had tested RTX 2060, RTX 2070 Super and Ryzen 5 3600 in all combinations, both in 4.12, 4.14 Beta and 4.14, but I don't see them in the updated charts.
  • droidy001droidy001 Posts: 277
    Wow 4.14 has knocked nearly 4 mins off the Titan X. The load time has more that doubled but this is only around 3 seconds more.
    Iteration rate has gone from 2.457 to 3.31
    Daz Studio Version: 4.14.0.10
    Benchmark Results
    DAZ_STATS
    2020-12-07 10:53:02.603 Finished Rendering
    2020-12-07 10:53:02.634 Total Rendering Time: 9 minutes 9.30 seconds
    IRAY_STATS
    2020-12-07 10:53:13.510 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2020-12-07 10:53:13.510 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce GTX TITAN X):      1800 iterations, 2.275s init, 543.949s render
    Iteration Rate: (1800 / 543.949) 3.31 iterations per second
    Loading Time: ((0 * 3600 + 9 * 60 + 9.3) - 543.949) 5.351 seconds
    Post edited by droidy001 on
  • TheKDTheKD Posts: 2,674
    System/Motherboard: GIGABYTE B450 AORUS PRO WIFI-CF
    CPU: AMD Ryzen 5 2600X @ 4.0 ghz
    GPU: MSI RTX 2080 Super Gaming X Trio
    System Memory: Corsairw DDR4-3200 8gb x2   gskill DDR4-3200 8gb x2
    OS Drive: Samsung 960 EVO 250gb
    Asset Drive: Seagate 2TB 7200 rpm
    Operating System: Microsoft Windows 10 ENT LTSC 1809
    Nvidia Drivers Version: Unknown(nvidia control panel keeps crashing when I try to open at the moment)
    Daz Studio Version: 4.14 BETA x64
    Benchmark Results
    DAZ_STATS
    2020-12-07 07:44:12.308 Finished Rendering
    2020-12-07 07:44:12.339 Total Rendering Time: 4 minutes 15.68 seconds
    IRAY_STATS
    1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 2080 SUPER):      1800 iterations, 2.719s init, 250.869s render
    Iteration Rate: 7.2 iterations per second
    Loading Time: 5 seconds
    No, it's 4.14.0.10
    A new test with version 4.14.1.22.
    A slight gain of 3 seconds compared to 4.14.0.10 (test performed 3 times).
    I don't activate the CPU anymore, which impacts the rendering time negatively.
    RTX 3060 ti :
    Operating System: W10 Pro Build 20270.fe_release.201124-1440
    Nvidia Drivers Version: 460.79 GRD (NO studio for now)
    Daz Studio Version: 4.14.1.22
    Benchmark Results
    DAZ_STATS
    2020-12-10 00:38:36.065 Finished Rendering
    2020-12-10 00:38:36.091 Total Rendering Time: 2 minutes 50.26 seconds
    IRAY_STATS
    2020-12-10 00:38:39.805 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2020-12-10 00:38:39.805 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 3060 Ti): 1800 iterations, 6.287s init, 161.725s render
    Iteration Rate: (1800 / 161.725) 11.13 per second
    Loading Time: ((0*3600+2*60+50.26) - 161.725) 8.53 seconds
  • A new test with version 4.14.1.22 and RTX 2060.
    A passage under 6 minutes
    RTX 2060 :
    Nvidia Drivers Version460.79 GRD (NO studio for now)
    Benchmark Results
    DAZ_STATS
    2020-12-10 19:38:40.765 Finished Rendering
    2020-12-10 19:38:40.802 Total Rendering Time: 5 minutes 34.75 seconds
    IRAY_STATS
    2020-12-10 19:38:43.818 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2020-12-10 19:38:43.818 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (GeForce RTX 2060): 1800 iterations, 2.950s init, 329.065s render
    Iteration Rate: (1800 / 329.065) 5.47 per second
    Loading Time: ((0*3600+5*60+34.75) - 329.065) 5.68 seconds
  • StuffStuff Posts: 8
    2x 3090 repeated with 4.14
    System/Motherboard: Gigabyte Aorus Extreme TRX 40
    CPU: Threadripper 3960X in Precision Boost Overdrive mode
    GPU: Inno3d iChill x3 3090 (stock settings and cooler) + Colorful iGame OC Advanced 3090 (stock setting and cooler)
    System Memory: 48Gb various G.Skill modules at 3200 XMP (2x 16Gb and 2x 8Gb in quad channel)
    OS Drive: Samsung 960 Pro NVMe SSD 1Tb
    Asset Drive: Same
    Operating System: Windows 10 64bit
    Nvidia Drivers Version: Game Ready Driver v 460.79 **NEW**
    Daz Studio Version: 4.14.0.10 (64-bit) **NEW**
    Optix Prime Acceleration: Nope
    Benchmark Results - 2x 3090
    2020-12-12 16:42:40.610 Finished Rendering
    2020-12-12 16:42:40.655 Total Rendering Time: 53.48 seconds
    2020-12-12 16:42:47.784 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Device statistics:
    2020-12-12 16:42:47.784 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 3090): 893 iterations, 1.748s init, 48.861s render
    2020-12-12 16:42:47.784 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 1 (GeForce RTX 3090): 907 iterations, 1.682s init, 48.290s render
    Iteration Rate: 36.84 iterations per second
    Loading Time: 4.619 seconds
    That's a huge improvement from 27.81 iterations per second in 4.12. Also, now sub-1 minute with 2 cards.
  • valzheimervalzheimer Posts: 519
    System/Motherboard: ASUS STRIX Z490-E Gaming
    CPU: Intel Core i9 10900KF (3.7GHz)
    GPU: NVIDIA GeForce RTX 3080 (Asus TUF Gaming 10GB OC)
    System Memory:32GB DDR4-3600 RAM Gskill Ripjaws 2x16
    OS Drive: Seagate BarraCuda
    Asset Drive: Same
    Operating System: Win 10 Home
    Daz Studio Version: 4.14.0.10 Public Build
    Optix Prime Acceleration: none
    Benchmark Results
    CPU+GPU
    DAZ_STATS Total Rendering Time: 1 minutes 56.53 seconds
    IRAY_STATS CUDA device 0 (GeForce RTX 3080): 1712 iterations, 1.497s init, 112.459s render | CPU: 88 iterations, 1.249s init, 113.090s render
    GPU only
    DAZ_STATS Total Rendering Time: 1 minutes 57.44 seconds
    IRAY_STATS CUDA device 0 (GeForce RTX 3080): 1800 iterations, 1.332s init, 114.543s render
    Iteration rate: 15.72 iterations per sec
    Loading time: 2.9 sec
    Post edited by valzheimer on
    I've made this Google Sheet for me, and it's public.
    It has all entries for this monstrous 4.14 update, and it quickly compares the iteration rate for all the GPUs.
    Link: https://docs.google.com/spreadsheets/d/1wkuVTjE9LDrq_YHstg_iJy6HUO5eQTNlXGMB25mfk44/
    I'm attaching the charts comparing the various GPUs.
    I know it's not 100% precise (you can't see if the GPU was overclocked, some entries are extrapolated from multi-GPU setup where the total result differs from the sum of the single ones, you don't know in what system the GPU was etc.), but I needed a quick a clear comparison to compare the GPU prices and all.
    1720 x 1066 - 110K
