Please give Poses & Expressions Names!
2
  • j cadej cade Posts: 2,310
    I would like hair colours, in particular, named so I don't give someone green hair by mistake. Make up too, though that can be trickier.
    I create my own presets for the Daz core figure makeups that I know will leave the other settings alone and I try to name them but it's *hard* especially to keep short. And you have to be pretty familiar with makeup terms makeup terms I'm not sure if "winged nude" is any more useful to most people than "makeup 01"
    To the main point i definitely have some sympathies. I don't tend to use expressions but sorting through to find all sitting poses, for instance, isn't the most exciting way I spend my time
  • SevrinSevrin Posts: 6,314
    Mattymanx said:
    Mattymanx, are you really not able to use "G8F" instead of Genesis 8 Female?! I use abbreviations like that for all my content.
    Its Daz-Law to not use abriviations within the product in regards to the figures.  Shortening the PA name and product name is good to do as it makes for much shorter file names.
    That's a bummer.  Whenever I install something from Rendo with Content Wizard I ALWAYS abbreviate to G8F, G3M, etc.  It's can be a pain to fix compatibility for stuff from other stores, so just typing G8 into search is a quick way to find what I'm looking for.
  • Ron KnightsRon Knights Posts: 2,755
    I just spent awhile working on my content management again. Yeah there were all those numbered poses, etc. Then there were so many folders hidden under other folders, etc. I just want to make art.
  • NylonGirlNylonGirl Posts: 2,391
    • neutral
    • sidelong grin
    • shy smile
    • my porridge is cold
    • thats interesting
    • stepped on a lego
    • concerned
    • are you sure
    • oooh goody
    • bruh
    I want to buy this pose set.
    My personal thought would be, "Winged Nude" is a useful/meaningful name to some people. "Makeup 01" doesn't mean anything to anyone. Where "Winged style 1", "Winged style 2" at least gives you a general expectation of what it will be.
  • SBibbSBibb Posts: 600
    edited November 2020
    I've had success using "8F" to represent Genesis 8 Female in naming my poses when submitting them, but I have not tried "G8F" (mostly because I'd seen that it was frowned upon). Hopefully I'm able to continue doing that, since it's nice and short while giving an idea of who it's for.
    I've definitely considered naming the poses and expressions based on something more descriptive, but ended up sticking to numbers for simplicity's sake and not being sure what to call them. (Smile? Slight Smile? Smirk?) If even simple names would help, I'd definitely consider adding those to future pose sets, though.
    I do use TIP files, and I add the thumbnails to the expression dials as well. (They're super tiny... but when working with other expressions I've found I preferred having at least a tiny image idea to work from more helpful than just "smile" named across a number of expressions... especially when the particular "smile" looks more nervous to me than genuinely happy. Still useful... just a different kind of smile).
    Also, I now too like the idea of a pose set with fun naming conventions... like that "Stepped on a Lego" one.
    Post edited by SBibb on
  • kgrosserkgrosser Posts: 141
    Poses, e.g. I am personally fine with the "by function" option and one could do the same with expressions. But....
    - G3 and G8 variants
    THIS!!!
    At least give us the option to categorize them in batches by a new "Generation" category.  In general I think the category category (hm....) could be improved. E.g. if I categorize a material as "Iray" it should get a "MDL" tag applied to the icon in the library.
    Which brings me to the point of tags: it would be helpful if these were assignable by the user and stick with the files even when moved to another folder. Some older presets and characters I created on an older version of DS suddenly lost their "tag" along the way and there is no way to get it back.
    Although it needs to be said, that the issue of this topic is not with DAZ per se but the varios respective vendors/creators if products in general simply would be blessed with the indicated attention before pushing to store, it would be nice to have better options and also documentation in oprganizing products or creating your own.
    Post edited by kgrosser on
  • cherpenbeckcherpenbeck Posts: 1,418
    I always wondered why DAZ doesn't use easy identifiers, like
    Generation- Male/female -Name of figure morph/Pose/Expression/Hair/Outfit -Name of texture oder color, if provided - 3DL and/or Iray
    Like: G2M-Michael-poses-sitting-posenumber (if there are several sitting poses)
    Would make life easier for users, would make cataloging easier for PAs and users and Smart Content.
    But no, probabely too easy. We would have far too few forum threads if we had no reason to complain anymore.
  • DripDrip Posts: 1,269
    I now wonder whether it'd be technically possible to script in transparent overlays on top of the images in Smart Content, so we could add tags ourselves with just two clicks on top of those images there.
    There are really HUNDREDS of products by now which include both G3 and G8 versions, with no clear or convenient indication on their icons or names to tell them apart. It's most common for poses, but for hair and clothes it's at least as inconvenient. "Uhmmm, nothing happens, is it still loading, or did I pick the wrong one?" Then wait for a whole unproductive minute to get your answer..
    Actually, it is a tad faster to right click, browse to folder, and then apply either this or the other one - a tad, as said, but this is whI find doing myself all the time and it shows the urgent need for something more 2020 ....
    Mattymanx said:
     Especially since we are not allowed to use G8F in place of Genesis 8 Female.
    Oh, aren't we? I'm pretty sure and like Ron Knights I added this on basically all the poses bought externally and prepared the  .zips for "regular" installation via DIM. Btw. while I'm at hijacking this: is there a way to create the manifest or .duf in a way such poses  install with the correct categorisation from the start without browsing the unassigned section and do that manually?
    Oh, aren't we? I'm pretty sure and like @Ron Knights I added this on basically all the poses bought externally and prepared the  .zips for "regular" installation via DIM. Btw. while I'm at hijacking this: is there a way to create the manifest or .duf in a way such poses  install with the correct categorisation from the start without browsing the unassigned section and do that manually?
    Q&A won't allow abbreviations. I've have had to change the names of presets so they spell out "Genesis 8 Females" or "Genesis 8 Males". I've not yet tried just adding 8F or 8M,though. Might be worth a shot next time the issue arises.
    So I copy, it's a political, not technical limitation. Not that political decisions are wise by nature, as we do know.....
    May I suggest giving Gen3/8 o shot when occasion comes up? ;) Whether it is M or F usually can be identified by the icon quite clearly.
  • they created this mess by splitting the genders instead of finding a way to make clothing creation easier for either on a unisex figure
    people come in all shapes and sizes and IMO a unisex figure is better for that
    Some vendors manage with things like "Happy 01", "Angry 27", ect. Even attempting to use broad categories helps you know where to start. And things like "Sitting" "Standing" "Running" are great as well. I'm not against numbered poses, I don't like ONLY numbers. I do buy pose sets, but the numbered only ones are usually in bundles, and they get overlooked when I am searching for starter poses. If the product/folder is something like "Running Poses", then yes, the numbers are ok to me because I can still find it when I'm looking for running poses.
    I know I can create my own folder, I do that for most content. It's just annoying to have yet another level of work I have to do if I want to find a pose when I need it.
    Numbered poses and expressions are a pain in you_know_where... Especially with the thumbnails being so small that you cannot really see what it is trying to show and I only have 1920x1200 monitors.
    Going through Expression 01 to 35, one by one just to see what they are...
    I appreciate everyone's input. I was afraid I was the only one bothered by this problem.
  • tsaristtsarist Posts: 1,642
    Mattymanx said:
    tsarist said:
    I had at one time suggested vendors make a pdf with decent sized pictures, so we could see CLEARLY what each pose looked like.
    You could always download the promos and make your own.
    That would only make sense if I had that much time on my hands.
    Post edited by tsarist on
    Not "political", but commercial.  Daz wants to promote the Genesis brand.
    Understandable. But on the other hand, they are hurting their brand with this crappy policy. EITHER get the damn SmartContent right, so that the software can "decide" which e.g material or pose I need to use, OR allow the PA's to propperly label the things. Best way: do both. Currently, its trial and error, or takes extra time.
    They have lost quite a LOT of commerce already by treating their customer base as they do. A store "upgrade" that (ab)used the customers as beta testers, unclear or misleading promo advertizing, overpricing cut-down bundles, products that never have seen QA / QC, tickets that remain in the CS queue until Judgement Day.... you name it.
    You could group them, but a single item/product can belong to only a single group (and the  new flags are a group so you'd need to turn them off, at least for updates to content you'd already grouped by figure). Filter by Conext should help when viewing files, but not when looking inside a product container.
  • CricketCricket Posts: 501
    Sevrin said:
    3Diva said:
    I want descriptive names for Poses and Expressions. I want to know if someone is smiling, not "doing a number two!" The same goes for Poses.
    Oh, I see. I think most of the products in the Daz3D store come with TIP files, so that once you hover the icon a larger icon appears so that you can better see what the preset looks like. :)
    To enable this it's: Edit >> Preferences >> Interface >> Tool Tips On :)
    But yeah, I can see why a description would also be helpful. Though expressions can sometimes be complex and difficult to name descriptively. Like a kind-kind-of-sort-of-smile, but not really, mouth side up a little. Eyes relaxed. Brow up. What, to me, could look like a smirk it could look like a sweet smile to someone else. lol Naming it "Va-Voom Expressions 04" keeps it open to interpretations, I guess. :) But yeah, descriptions could be helpful too. So I can see both sides.
    VERY few vendors who make poses, or anything, for that matter, add larger tip files.
    Related: It's annoying when you have to click on items made for multiple generations to see in the "Additional Information" window what generation the preset is for.
    This annoys me as well. I have a few different items (hair, clothing) that are made for both G3 and G8, but until I open the "Additional Information" tab, I don't know which preset is for which generation. A simple "G3" or "G8" on the thumbnail would be very helpful.
    But, all the filtering on context relies on PROPER SmartContent metadata. I have bought about 150 products during PA and PC+ sale, including NEW items. NOT A SINGLE ONE had correct metadata
  • I would like hair colours, in particular, named so I don't give someone green hair by mistake. Make up too, though that can be trickier.
    I was struggling with this the other day. A dozen numbered hair colours in the Content Library pane; four almost identical dark browns, four only slightly different near-blondes, a black and a few reds. All the blondes came out as different kinds of light mousy brown. I was looking for a nice bright yellow, like the Buttercup shade in the UHT Hair Shaders set, and eventually I used that, because none of the presets that came with the hair actually used textures that matched the content thumbnail. Actual named colours would have made my search a lot easier.
  • If there were four shades of dark brown though, what names would have made it better? I do agree I prefer when you at least get categories like blonde, brown, and gray, especially when it can be hard in thumbnails to tell gray from blonde, depending on lighting and close ups. But at least if the thumbnail looked blonde but said light brown you would know it wasn't a misunderstanding or a product error.
    Well. hair colour manufacturers come up with quite nice names already. Mahogany, Chestnut, Caramel, etc... why not name hair colours accordingly? I do understand that PA's would rather focus on the artwork on their product, but giving a hair colour a unique name is an added value, and might, in the long run, boost sales. If I know a given PA is doing excellent work (not just artwork, but delivering the whole package), I might consider new products an instant buy.
    OK. Hey, I wonder if we have any "COVID" facemasks for our DAZ characters.
    if "we" includes Renderosity...yes
  • I know a sight impared user who frequently asks me on FB messenger what colour a hair or eye is because the DAZ vendor only uses numbers
    some people actually use DAZ stuff due to vision problems for doing illustrations
  • 3Diva3Diva Posts: 12,058
    That's a good point. More descriptive names would help people with color blindness or other visual difficulties. TIP files would help with that too - I've always created TIP files for my products (and actually figured it was a requirement) so I just figured other PAs did too. I didn't realize until was mentioned here that some PAs don't create them.
    Post edited by 3Diva on
  • plasma_ringplasma_ring Posts: 1,027
    I would find simple names like that super helpful! The naming for the Daz expression dials are actually really good this way, because with names like "Smile Simple" and "Smile Mouth Open" I can be pretty sure how the pose dial will move the face. All the emotion dials have straightforward names too.
    Mod Edit :-to sort out the quote.
    Post edited by Chohole on
    I'm not sure what happened with the quote there, but I didn't say that. :)
