Daz Studio Pro BETA - version 4.12.2.60! (*UPDATED*)
1666769717274
  • barbultbarbult Posts: 27,529
    now I know. >D how do i fix it, just reinstall it when it isn't running?
    I don't know. Maybe you should close it down then uninstall it and reinstall it.
  • Found an icons bug in hairs editor. Should I open a ticket?
    286 x 178 - 13K
    The usual procedure is: close D|S — wait until all the background shutdown tasks are finished — uninstall — reinstall. The background tasks thing is usually due to the content database control program updating the database, and should take no more than a minute or three, although a few people have reported having to wait a lot longer.
    Is it supposed to be all white now?
    the interface is gone.
    No, you installed while DAZ Studio was running. You need to exit DAZ Studio, uninstall DAZ Studio, reinstall DAZ Studio and the problem will be fixed.
  • dim_sh_ecd463260fdim_sh_ecd463260f Posts: 17
    edited October 2020
     Iray Section Plane Node doesn't work in the new build 4.12.2.60. After adding it to the scene, the render returns a memory error. In the stable version, everything works and there is no error.
    2020-10-25 12:50:33.294 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00082 iterations after 9.567s.
    2020-10-25 12:50:33.465 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00084 iterations after 9.738s.
    2020-10-25 12:50:33.691 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00086 iterations after 9.964s.
    2020-10-25 12:50:33.770 Iray [INFO] - IRAY:RENDER ::   1.13  IRAY   rend info : CUDA device 0 (GeForce GTX 1080 Ti): Allocated 717.883 KiB for frame buffer
    2020-10-25 12:50:33.775 Iray [INFO] - IRAY:RENDER ::   1.5   IRAY   rend info : CUDA device 2 (GeForce GTX 1080 Ti): Allocated 10.745 MiB for frame buffer
    2020-10-25 12:50:33.775 Iray [INFO] - IRAY:RENDER ::   1.26  IRAY   rend info : CUDA device 3 (GeForce GTX 1080 Ti): Allocated 5.813 MiB for frame buffer
    2020-10-25 12:50:33.779 Iray [INFO] - IRAY:RENDER ::   1.38  IRAY   rend info : CUDA device 1 (GeForce GTX 1080 Ti): Allocated 4.279 MiB for frame buffer
    2020-10-25 12:50:33.793 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00088 iterations after 10.066s.
    2020-10-25 12:50:34.093 Iray [INFO] - IRAY:RENDER ::   1.7   IRAY   rend info : CUDA device 0 (GeForce GTX 1080 Ti): Allocated 1.688 GiB of work space (2048k active samples in 0.000s)
    2020-10-25 12:50:34.409 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00092 iterations after 10.682s.
    2020-10-25 12:50:34.658 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.18  IRAY   rend error: CUDA device 2 (GeForce GTX 1080 Ti): an illegal memory access was encountered (while launching CUDA renderer in <internal>:947)
    2020-10-25 12:50:34.662 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.18  IRAY   rend error: CUDA device 2 (GeForce GTX 1080 Ti): Failed to launch renderer
    2020-10-25 12:50:34.662 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.8   IRAY   rend error: CUDA device 2 (GeForce GTX 1080 Ti): Device failed while rendering
    2020-10-25 12:50:34.662 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [WARNING] - IRAY:RENDER ::   1.8   IRAY   rend warn : Re-rendering iteration because of device failure
    2020-10-25 12:50:34.665 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.8   IRAY   rend error: CUDA device 2 (GeForce GTX 1080 Ti): an illegal memory access was encountered (while de-allocating memory)
    2020-10-25 12:50:34.665 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 3 (GeForce GTX 1080 Ti): an illegal memory access was encountered (while de-allocating memory)
    2020-10-25 12:50:34.668 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 3 (GeForce GTX 1080 Ti): an illegal memory access was encountered (while de-allocating memory)
    At the beginning, the rendering goes fine, then an error occurs. I repeat that everything works on the stable version 4.12.1.118 and there is no error.
    The error occurs immediately after adding a  Iray Section Plane Node  to the scene
    This happens even when there is only one Genesis 8 figure without clothes or hair
    Post edited by dim_sh_ecd463260f on
  •  Iray Section Plane Node doesn't work in the new build 4.12.2.60. After adding it to the scene, the render returns a memory error. In the stable version, everything works and there is no error.
    Are your drivers up to date? It works for me, render as well as Iray Preview DrawStyle. G8M with hair and clothing used.
    1375 x 1063 - 612K
  • SevrinSevrin Posts: 6,314
    Could you post a zip compressed scene file with a basic figure for us to try?
    edited October 2020
    added
    I also attached two videos. They are made on the same computer in different versions of the program.
    duf
    duf
    iray_error.duf
    116K
    edited October 2020
    I have the latest  studio driver 456.71
    Windows 10  64
  • I have the same issue as dim_sh_ecd
    Just tried it again with the newest daz beta update...
    Could you please upload the scene file so that we can try? For some reason dim_sh_ecd attachment only opens as a png.
  • IllidanstormIllidanstorm Posts: 655
    edited October 2020
    Just the base male with the base undies and a section plane
    here my log. Using two 2080 ti's with the 456.71 studio driver
    2020-10-25 13:22:15.315 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.2020-10-25 13:22:15.315 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.2020-10-25 13:22:15.315 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.2020-10-25 13:22:15.344 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)2020-10-25 13:22:15.344 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 02020-10-25 13:22:15.393 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 602k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 602k triangles, 0 fiber instances yielding 0 segments) took 0.049s2020-10-25 13:22:15.394 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.2020-10-25 13:22:15.407 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Ogre Pants__Cloth_1d19_408' uses MDL JIT compilation.2020-10-25 13:22:15.408 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Ogre Pants__Trim_1d1a_418' uses MDL JIT compilation.2020-10-25 13:22:15.409 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Ogre Rope__Rope_1d1b_431' uses MDL JIT compilation.2020-10-25 13:22:15.410 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 113 textures, 3 lambdas (2 unique)2020-10-25 13:22:15.413 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (1 light source with 2 triangles, 1 instance) took 0.000s2020-10-25 13:22:15.413 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.2020-10-25 13:22:15.421 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.2020-10-25 13:22:15.422 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.2020-10-25 13:22:15.423 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.2020-10-25 13:22:15.423 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.2020-10-25 13:22:15.423 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.2020-10-25 13:22:15.423 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.2020-10-25 13:22:15.428 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.2020-10-25 13:22:15.428 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer2020-10-25 13:22:15.433 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled2020-10-25 13:22:15.433 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.2020-10-25 13:22:15.436 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No device specified or usable2020-10-25 13:22:15.436 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 0 device(s):2020-10-25 13:22:15.436 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...2020-10-25 13:22:15.436 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No worker to render with: aborting render2020-10-25 13:22:15.436 Iray Render error: Internal rendering error.
    duf
    duf
    section plane fail.duf
    128K
    Post edited by Illidanstorm on
    I corrected my message. Please tell me, what is your system and configuration? Does everything work for you in the latest release?
    Yes it works in the general release (not beta)
    I have a ryzen 3700x, 64 GB RAM, 2x 2080 ti
    Also tried it with just one 2080 ti with the same result.
  • If I use my saved scene file, I don't have a problem. However, I do with both your supplied scenes. Please submit a bug report, and attach your scene files to the report.
    Win 10, 1080Ti and 32GB RAM.
    Current beta. 2080ti 456.71.
    I got a message saying that I was missing some Face Wounds morphs, but otherwise he rendered.
    1920 x 1080 - 102K
    added
    This guy rendered, too.  Covered him up a bit, though.
    1920 x 1080 - 102K
  • @Sevrin: Did it render using the GPU or CPU?
  • @SevrinDo you have the latest public build version?
  • MEC4DMEC4D Posts: 5,249
    Yesterday everything was rendering fine, today Iray don't works at all after adding G8M and Section Pane , it all stopped working even with a new scene and simple primitive !
    I am going to install the new build
    Try restarting DS first.
    Yes it worked but once I used G8M and section pane again Iray stopped working so definitely a bug , section pane works fine on primitives , it shut down Iray after I use figure with it , removing it from the scene helps nothing, I need to restart DS
    Yesterday it working fine so no idea what happened
    GPU
    Yup.  Current beta.
    edited October 2020
    Ok I found out what is going on, DS switching to CPU to render the section pane not GPU
    once you disable CPU it will not render on GPU only , it somehow shut down the Iray ability to use GPU after, until you restart again
    Yesterday my CPU was selected that why I had no issues render it, but today when I shut down CPU rendering the problem accrued
    Edit: there is no problem rendering section pane with primitives using GPU, only shut down GPU rendering after using figures
    Post edited by MEC4D on
  • hello, where can I download version 4.12.2.60 ?
    edited October 2020
    2020-10-25 10:19:41.046 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX Prime for CUDA device 22020-10-25 10:19:41.051 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: OptiX Prime error (Device rtpContextCreate): Unknown error2020-10-25 10:19:41.051 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 2 (GeForce GTX TITAN X): Device initialization failed, will not be used2020-10-25 10:19:41.051 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX Prime for CUDA device 02020-10-25 10:19:41.061 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...2020-10-25 10:19:41.061 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(353): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No worker to render with: aborting render2020-10-25 10:19:41.064 Iray Render error: Internal rendering error.2020-10-25 10:19:41.441 Finished Rendering2020-10-25 10:20:30.825 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    The error log for one of my device after using section pane with G8M with GPU
    if you render fine it means your CPU is selected , so no driver or cards are the problem here
    However no issues with primitives and section pane node
    DAZ Install Manager /.  DIM
    Having "purchased" https://www.daz3d.com/daz-studio-beta
  • For old card (1080 for me), its prefered to use a older Nvidia Studio driver 451.77, at least the graphics card is not always used.
    No more crashes after rendering, viewport iray starts faster.
    With 456.71 daz crashs at times (at the end of a render for example), freeze camera orientation and gpu clock is at maximum all the time...
    Tested on 4.12.2.60 and now no problems daz works as on 4.12.1.118.
    I know that depending on the person, the problems are not the same, if it can help someone.
    1205 x 779 - 495K
    GPU
    Yup.  Current beta.
    I doublechecked.  The renders fell back to CPU.
    I had CPU deselected, but somehow CPU fallback got enabled, which I didn't normally have.
    When I tried to render one of the scenes again with CPU fallback disabled., the render was blank.  When I enabled Iray preview, all I got was a endless loop with no preview appearing.  So yeah, Iray Section nodes won't render on GPU.  I've not used them in my scenes in a long time, but for people who do, this is obviously a big problem.
