• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Skin shader from scratch (version 1.1)
«12»
  • brainmuffinbrainmuffin Posts: 1,292
    October 2020
    I need to read this thread in depth. Here is Shan HD moved over via Diffeo and she sure looks like a mannequin.
    1920 x 1080 - 2M
    October 2020
    Krampus said:
     After adjusting the red Subsurface Radius value, we can then adjust the Subsurface mix value without changes the radius values.  The shader is linked in my signature and is included in the 3 light setup over at Blendswap.  Just save the .blend file and then append->NodeTree->'SSS Math Node'.  I'd be happy to post a screenshot of the math node if anyone would prefer that instead.
    When applying this Node, does one select the Mesh of the imported DAZ figure?
  • Krys KryngleKrys Kryngle Posts: 315
    October 2020
    Yes, for the face, ears, lips, torso, arms, and legs.
    October 2020
    Not sure I did it correctly. I don't see a difference in my render. I'll look at the shader tab.
  • VyusurVyusur Posts: 2,235
    October 2020 edited October 2020
    Mostly I'm using 2.79 for my pipeline. But this time I was messing around with sss params in 2.91. Here is a couple of renders of my custom character.
    Cycles
    Eevee
    1300 x 1669 - 1012K
    1300 x 1669 - 839K
    Post edited by Vyusur on October 2020
  • PadonePadone Posts: 4,154
    October 2020
    @Vyusur Judging by the shadows and sss I'd swear the first is eevee and the second is cycles.
    October 2020
    Nope, it's just as I said.smiley
    Well, this is interesting. In Studio, I did a second version of the scene by removing the lights and backdrop and adding a DTLP HDRI for lighting in the Dome. Exporting via Diffeo doesn't bring the HDRI along, so I added two area lights on either side of the camera. The one to the right is 500 w and the one on the left 250w. I hadn't let applied any additional shaders to the skin, but this does look much better.
    1920 x 1080 - 2M
    Post edited by brainmuffin on October 2020
  • nonesuch00nonesuch00 Posts: 18,856
    October 2020
    Yeah, it sounds wierd, but I more often like Eevee than Cycles when I can detect any discernable difference at all between to rendered frames at a glance.
    October 2020
    That's odd. The eyes in second picture show both noise and random walk artifacts that's only possible in cycles.
    And yet it is so. I made a couple of close-up screenshots.
    1726 x 1448 - 3M
    1726 x 1448 - 1M
    @Vyusur If you don't mind sharing the scene I'd be insterested in your setup. Mainly because I get the sss much stronger in eevee than in cycles, while you seem to get the opposite. And also because I'd like to look at the strange green artifacts around the eyes in eevee, that are usually caused by random walk in cycles if you don't separate disconnected meshes.
    Since the character is yours a basic G8 with the same materials will do for me.
    Post edited by Padone on October 2020
    October 2020
    I'm sorry, but I can't share this scene, since the figure in the scene is a WIP that I make for sale.
    @Vyusur I'm not interested in the character, that I believe couldn't be shared anyway as for the daz eula. I'd like to look at the materials so a blender monkey with the same skin will do for me. Then if you need to protect your material setup too and don't want to share I understand it. Cheers.
    October 2020
    Ok! Suzanne:
    zip
    zip
    Suzanne_sss.zip
    110K
    October 2020
    @Vyusur Thank you.
  • amy_aimeiamy_aimei Posts: 141
    October 2020
    I don't know why the light seems to pass through the character's body, see the circled area of the attached picture.  I have turned off the subsurface by setting it to 0.0 at the shader.  Any clue?
    720 x 720 - 355K
    October 2020
    Hi Amy_Aimei - Do you have translucency on?  If SSS is 0 and transluncy is off, there really should not be anything glowing (light should not be penetrating the skin).  Can you post a screenshot of your nodes and whether you are using Cycles or Eevee?
    October 2020
    The setup is so simple. The group of nodes for the skin material takes 2 inputs, the bump map and the diffuse map. There is only one light in the scene located on the left hand side (from the viewer's perspective) of the scene. The light setup is shown in the second picture.
    I'm using Cycles to render.  The render settings are the same as the default comes with Blender 2.90.1.
    Noted that I also tried without the RGB Curves and rendered in various versions of Blender, i.e., 2.79, 2.80, 2.83, and 2.90.
    1088 x 689 - 125K
    1025 x 426 - 52K
    October 2020
    Your input in the Base Color socket of the principled BSDF node is a jpg, but you have it set to non-color.  Try changing that to sRGB.
    October 2020
    That jpg you saw in the screenshot is the bump map.  That's why it is set to non-color.  The jpg for the diffuse map is set as sRGB.
  • j cadej cade Posts: 2,310
    I think that is at least mostly just bounce light,  bouncing off the figure back into itself, for whatever reason this effect always seems stronger in Cycles than Iray, though you can get it in both (and it is also a thing that happenes in the real world too)
    It's actually something I frequently try to accentuate in renders as it's a common feature of classical portraiture (it's in almost every baroque portrait and I love it) - it should also become *less* strong when you add sss and more light will be absorbed, thus less light bouncing off to cause the effect.
    edit one of my favorite painting examples
    see that highlight on the underside of the chin helping to seperate it from the neck  without relying on a strong shadow?  (also just the indirect lighting in the shadow of her hat, this painting is absolute lighting goals for me)
    Post edited by j cade on October 2020
    October 2020
    amy_aimei said:
    Any clue?
    I see nothing odd. But you may try disconnecting the textures from the principled shader so to get if the issue is from the textures or the shader setup. That may be a first step.
    Thanks Krampus, j cade and Padone for comments and suggestions.  With all these suggestions, I've found the cause of that.  It is the light (Sun).  I deleted the light and linked a HDR image to the Background node for the World.  The output looks better than the one with the light.
    As you may notice, I tried to make a skin material for using with Blender Cycles renderer to achieve the similar result as the Iray renderer.
    720 x 720 - 59K
    Post edited by amy_aimei on October 2020
  • futureghostfutureghost Posts: 0
    November 2020
    j cade said:
    Right. For my skin treatise:
    Very helpful, thanks. Can I ask what HDRI or lights the iray example uses? For testing purposes.
«12»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
