• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeo Hair Conversion Example - Monica Hair
Krys KryngleKrys Kryngle Posts: 320
October 2020 edited October 2020 in Blender Discussion
This is an example of Diffeomorphic's hair conversion from transparency mapped mesh to particles.  I've done a few now and Monica hair worked really well.  Some conversions required a lot of work to get them right.  This one worked with only a few edits to the particle hairs above the character's left ear, which took about 1 minute.  The material is Blender's built in principled hair bsdf shader.  Changing hair color from brown to blonde or anywhere in between requires changing one value, between 0 and 1.
Rendered straight from Blender using cycles, no post work (other than the compositor).
If anyone else has some examples, WIP's or whatever, I'd love to see them.
Post edited by Krys Kryngle on October 2020
  • brainmuffinbrainmuffin Posts: 1,331
    What steps do you tend to do? Convert using Diffeo and then changing the shader in Blender to principled hair?
    Post edited by brainmuffin on October 2020
  • Krys KryngleKrys Kryngle Posts: 320
    October 2020
    brainmuffin said:
    What steps do you tend to do? Convert using Diffeo and then chaning the shader in Blender to principled hair?
    Yup.  Also changing the particle settings for hair size, clumping, child particles, etc.
    October 2020
    Ok. I soon will be trying another V8 transfer. Let's see if I can follow along in the song book... :-)
    October 2020
    Is the comb tool an add-on?
  • nicsttnicstt Posts: 11,715
    October 2020
    They can create a lot of individual particle systems which can be both good and bad;  definitely bad when updating settings, so I created a script to do that.
    October 2020
    I use the 'resize hair' option to create only one particle system.  For shorter hair I pick around 9 vertices, for longer maybe around 13 vertices.  It works well.  Resize in blocks works ok too, but simple is better for my small brain.
    • Resize Hair: Change the number of hair vertices so all strands have the same number, and hence belong to the same particle system.
    • Hair Length: The number of hair vertices, if hair is resized.
    • Resize In Blocks:  Change the number of hair vertices to a multiple of ten. This results in a moderate number of particle systems and fairly uniform vertex density.
    Thanks a million for that script.  I plugged all my values in for Monica Hair so all I have to do is convert the hair and run the script.  HUGE time saver.  Really appreciate you sharing that.
    October 2020
    I've posted a WIP in the renders thread. Her hair and skin are what I'm working on next. I'll see what I understand.
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,336
    October 2020
    No, you just have to have a particle system selected and be in particle edit mode.
  • TheKDTheKD Posts: 2,711
    I must have missed it, where did you post your script share?
    NVM, I thought I remembered you posting one after my princess it render lol. So to use it, I select the hair, then run it in the script text box?
    Post edited by TheKD on October 2020
  • PadonePadone Posts: 4,336
    I second @Krampus. Absolutely do use the resize and sparsity options to get manageable hair. Also do not forget to separate the scalp and hide it.
    http://diffeomorphic.blogspot.com/p/hair.html
    Post edited by Padone on October 2020
    October 2020
    Welcome
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
