"Spring Bedroom" for UE2 and Reality2.5
StratDragon
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
[UPDATE]
Link on ShareCG
http://www.sharecg.com/v/76271/view/5/3D-Model/Spring-Room
Link on Renderosity
http://www.renderosity.com/mod/freestuff/?item_id=73967
Previous post when this was a WIP (note: test images removed)
Howdy y'all
I'm trying to release a free when it's finished project that will work in DS4.5 for Reality2 or UberEnvironment2 without the need for users to go crazy in setup.
So far I have 3 nulls in the content, one for the bedroom, one for the 3Delight lights and one for the Reality2 lights.
My understanding in Reality is I need to reimport all the obj's from Blender back into DS before I can create ACSEL textures that anyone could get off the ACSEL sever
My other understanding is anyone with DS4.5 or up should have the UE2 lights but I don't know for sure.
When I save this scene I assume I need to go to "Support Asset...Scene Asset(s)" then include the textures, and the obj in the geometry folder but is this the right way to do this and do I need to provide anything else in order for the scene to work on anyone else's DS4.5? I'l also include the OBJ's for Poser users but I won't be able to set up anything since I don't own Poser past version 5 and I don't have it installed on anything either.
Does anyone have experience doing any of this that could guide me through the right process?
I may add one or two more items to this set to "punch up" the room a little more but I don't want to get caught in a spiral of home decorating but here's what I got so far:
I don't have Reality so having them for UE as well is great. I hope you get it figured out. You could try asking in the commons for help, someone who knows will answer and there usually isn't too long a wait depending on what it is.
Hum, I very like the UE2 render. Anyway, the are something weird with the Reality render. The metal is more realistic in UE2 version while Reality is always very realistic with galss, mirror and metals. I think you let the metal surface as glossy or if it is setup as metal so it has little shiny
It looks very nice. I like both renders, i also have UE2 but second render made with Reality 2 looks fantastic :)
You are right. UberEnvironment 2 is part of "Default Lights and Shaders for DAZ Studio" which is part of DAZ Studio, so everyone using DAZ Studio 4.5+ have UE2.
You don't need include OBJ for DAZ Studio and neither for Reality. If you want pack your scene in a versatile way, you should save every asset as Figure/Prop Asset and the assembled scene as a Scene Subset.
My way to make easy to setup the files is create a new content folder and put them temporaly at the top of list using the Directory Content Manager.
There are soething about packing a product a Documentatio Center. Hope this help.
Looks really nice.
My only suggestion would be maybe a small rug and a few more plump pillows.
@MBusch,Gulan7
the metals in the Reality image are rendered for less than an hour which any Lux user can tell you it's not even warmed up yet. I rushed that piece, it' also has a bloom (blur) to soften all the parts of the render that needed some more time in the oven so that piece is seriously "undercooked". However UE2 does do a wonderful and far faster job of metals with some simple shader adjustments and that's why I want both Reality and UE2
@TimG
More pillows? Ok I've been working on framed art and honestly the pillows in there now were an experiment with the fabric simulator in Blender after one youtube tutorial so I'm open to other possibilities and scrapping the ones I have in there now.
I'm running into issues with the data files, this is turning into a bigger project than I expected but I may release a single OBJ with all these pieces in place if anyone needs a big static room that would prevent remodeling but keep in simple if the current arrangement works.
Heres the piece allowed to bake a little longer, the metal on the bed and lamps was purposely muted
Nice render indeed! Good job!
i like that desk a lot
just my 2 cents!
note that i did see beds with proportions like yours but personally i'd move the mattresses higher
and the foot of the bed fence too would be higher
often commercial beds seem to use 1 thick mattress instead of 2
so the mattress layer is about 2/3 this height
so they can move it even more away from the floor
and the top of the mattress is still low enough for figures to sit on
(sorry 'bout the rough photoshop )
personally, to make props from selected objects in a Daz Stcudio scene
i use “PP2 Exporter” by duke533 —-> precious link follows !!
http://puzzlekiraly.hu/lom
Awwwwwwh it's not reachable !
the key words to find it are duke533 "pp2 exporter" and "objtopp2"
maybe use the wayback machine?
yes !!!
----> https://web.archive.org/web/20100214145052/http://puzzlekiraly.hu/lom/
i also found this direct link to the dsa file
recently i discovered that,
if i group a bunch of objects under a null node
select this null node and export this as a prop using PP2 Exporter
Then this prop works A-OK in Daz Studio 1, 2, 3, 4
but in poser it only loads 1 of the objects
the work around is to open the pp2 (prop) file
in a text editor
at the very bottom you will see a "doc" section
and only one of the props has an entry that reads
so i text-search for the names of the other "prop"s in the file
and complete the doc section like
now the prop is compatible with Poser
and was possibly already compatible with Carrara
then to collect all the geometry files and prop files and thumbnail images and texture files
and re-create the needed folder structure, i use my mcjPackager script
which saves me maybe 30 minutes ! ok maybe 15 minutes, maybe 5
http://www.daz3d.com/forums/discussion/12959/#279643
i then zip the whole "runtime" folder structure and post it on my google site
the users just have to unzip it in a poser or daz studio content folder
example https://sites.google.com/site/mcasualsdazscripts4/mcjteapot
Very interesting, i will have to test it. Thanks for very useful info and links.
@Casual
Ok, you got me on the right path, I noticed if I save in the Null it only drills down about one or two levels, some of the props grand-childed to other props were dissappearing, and if I save any file name ending with ...03,...04 it removed those numbers and overwrote the first prop. The work around was to name the prop manually. Another small issue is all my textures have numbers in front of them "01BenchSurface", "02BenchCloth" I need to strip those out for the ACSEL setting for Studio and they are a little cumbersome as well.
So off to a start on this but still a WIP. thanks!
@MBusch
Thank you.
if you can figure how to adapt it to your setup, here's the script i use
to change all the "usemtl" statements in the geometry files produced by obj2pp2
and here's the script i use to change the "material" statements in the pp2 files
since it was designed for my use, it's not user friendly :)
the scripts process the list of files "fnam"
it looks for files with those names in the disk folder "pathin"
it writes clean-material-names versions of those files in the disk folder "pathout"
the "pathout" folder must exist before running the script because the script doesnt attempt to create it
and you must have write/admin privileges in that folder
this worked well with my props because my material names
contained only one dash ("-") which was introduced by the obj2pp2 script
the script takes the material names, splits them at the position of the dash
and the output file keeps only the second chunk of the name
so we removed the leading number and dash part
that's the mcjA3Wedges which were processed using those scripts
https://sites.google.com/site/mcasualsdazscripts3/mcja3wedges
almost there,
I'm really starting to like UE2 again for lighting.
Link on ShareCG
Link on Renderosity
Nice work StratDragon. Thanks for posting. :-)
Thanks for this, it looks great. I found it on Renderosity and will DL it now.
