• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic DAZ-to-Blender
«1…6789101112»
  • Leonides02Leonides02 Posts: 1,379
    September 2020 edited September 2020
    Padone said:
    @Leonides02
    As for burley vs random walk. That's because the materials are supposed to mimic iray as best as possible and burley mimics iray better than random walk. Plus random walk doesn't work with eevee so for consistent results with cycles we don't use it. If you make your own materials that are not a conversion from iray and you use cycles, then definitely go for random walk.
    One issue with random walk is also that it gets artifacts with disconnected meshes inside the same object. For example eyes and teeth in the genesis figure. So if you use random walk you have to separate disconnected meshes into multiple objects to avoid artifacts. While burley works fine.
    Thanks for the explanation, Padone.
    Is anyone else having an issue with the imported cameras? Every time I import a camera and try to use it, my figure doesn't show up in the render. I can only see the figure if I move the viewport. It's very strange.
    EDIT: The camera issue was the depth of field. It's not importing correctly.
    Post edited by Leonides02 on September 2020
  • marblemarble Posts: 7,500
    SDev said:
    Singular3D said:
    Weird question: Is there any way to turn off seeing the rigging?
    Pretty easy: Just toggle show/hide it as shown in the attachment. If you would like to toggle/untoggle the visibility via quick menu, just hover over the armature eye, right click and add this feature to the quick menu.Pressing "q" or "qq" (depending on some addons) will show up all your added quick options. (See attachment 2) Alternatively you might add a shortcut for this action. Blenders reconfig possibilities are wonderful.
    HTH!
    Ps:Don't forget to save your startup file if you would like to have added this feature for the next start :)
    PPS: Tja mei, via Discord ging des schneller :P
    I've been hiding the armature in a different way (this bugged me too when I first used the Diffeo plugin). I just turn off the bone overlay here:
    381 x 604 - 50K
    Post edited by marble on September 2020
  • PadonePadone Posts: 4,243
    I just checked it and the DOF seems to work fine here. Please use the latest development version.
    http://diffeomorphic.blogspot.com/p/daz-importer-version-15.html
    Post edited by Padone on September 2020
  • SDevSDev Posts: 158
    marble said:
    SDev said:
    Hi Marble,
    you can do so, but this would only hide the bones, not the full rig. Sing is just a spoiled C4D Veteran, hrhr...
    Cheers,
    Peter
    Post edited by SDev on September 2020
    September 2020
    SDev said:
    marble said:
    SDev said:
    Hi Marble,
    Cheers,
    Peter
    Not sure what the difference is between the rig and the bones. I can't see any of the armature if I do this.
    September 2020
    marble said:
    SDev said:
    marble said:
    SDev said:
    Hi Marble,
    Cheers,
    Peter
    In general, a rig controls an object, part of the rig might be a bone structure. There are various reasons why you might hide the rig, e.g. If you just want to have a viewport render as a preview.
  • Singular3DSingular3D Posts: 658
    September 2020
    SDev said:
    marble said:
    SDev said:
    Hi Marble,
    Cheers,
    Peter
    Guys, I never posted this. Look at the postings before. The question came from someone else :) I'm just starting with Blender and really like it so far.
  • lilweeplilweep Posts: 2,841
    September 2020
    Dont mean to hijack this thread but can Cycles render scenes that dont fit on VRAM (a limitation of Iray)?
  • brainmuffinbrainmuffin Posts: 1,321
    September 2020
    It is hard to tell if it is on purpose from NVidia or just poor programming. Cycles seems to be far more efficient with memory usage.
    September 2020
    okay but are you still limited by what can fit in VRAM in Cycles?
  • hookflashhookflash Posts: 169
    September 2020
    No, Cycles is not limtied by what can fit in vram. It is able to render "out of core" (i.e., it can try to use system memory when it runs out of vram) with CUDA and OptiX. Is iRay not able to do this?
    September 2020
    Nope. When Iray runs out of VRAM, it only uses the CPU and the GPU gets to take a nap. The highend rendering cards from NVidia are $14,000 a piece and more. They offer a cloud rendering service for a price. Believe what you want from there.
  • TheKDTheKD Posts: 2,711
    September 2020
    Cycles can't do out of core with optix as far as I know. When it ran out of vram with optix on me, it just stopped the render. With cuda, it will keep going as long as you have cpu checked, if it's just the gpu checked, it stopped for me as well. It will do hybrid if both are checked. It is possible I missed something though, I am not anywhere near a master blender renderer lol.
    September 2020
    Yeah, I'm definitely no expert in Blender rendering either.smiley According to the 2.9 manual, "With CUDA and OptiX devices, if the GPU memory is full Blender will automatically try to use system memory", but I'm not 100% what is meant by "try" -- i.e., Maybe there are special circumstances out-of-core rendering isn't an option and Blender has to revert to CPU-only?
    September 2020
    Oh, I didn't even realize they put optix into vanilla blender finally. I been using a paid version of blender for a while, that had optix and ai denoise in it. I wonder if others here hadn't heard it either, I think it should have gotten some buzz lol.
  • Krys KryngleKrys Kryngle Posts: 315
    September 2020
    Exact same experience here.  With a large complex scene, Optix ran out of memory, Cuda with GPU ran out of memory, CPU did render but it took longer.  I upgraded processor and memory and CUDA works like a beast now.  Optix is still great for smaller, simpler scenes.
  • nicsttnicstt Posts: 11,715
    September 2020
    Sometimes when it runs out of GPU ram I see issues; I've never been able to decide what in particular was the cause. It does, however, have out of core rendering.
    September 2020
    does out of core rendering still mean the GPU will be used for at least the part that can fit in VRAM?
  • CinusCinus Posts: 118
    September 2020
    From the 2.8 changelog : https://wiki.blender.org/wiki/Reference/Release_Notes/2.80/Cycles#GPU_rendering
    • CUDA rendering now supports rendering scenes that don't fit in GPU memory, but can be kept in CPU memory. This feature is automatic but comes at a performance cost that depends on the scene and hardware. When image textures do not fit in GPU memory, we have measured slowdowns of 20-30% in our benchmark scenes. When other scene data does not fit on the GPU either, rendering can be a lot slower, to the point that it is better to render on the CPU. (c621832c62)
    September 2020
    Weird, I am pretty sure it was at least 2.80 I was trying out some renders, maybe it was 4.7 though. Blender been moving fast for a while, so maybe that is it. Haven't really been pushing anything lately, doing a hell of a lot more modelling than renders past 6 months or so lol.
    September 2020
    It's worth pointing out that Octane does out of core and has a similar slowdown - although I can't remember the slowdown for sure.
  • humongoushumongous Posts: 2
    November 2020
    Hi this my first time posting here and I must say that this plugin is a Godsend, I only have a question: Is it possible to import Daz Hair morphs to Blender? I have Lea hair with ponytail and I would like to transfer the ponytail's morph into Blender, I tried the winders but I get an error. It's a pain in the neck posing the ponytail by rotating each bone.
  • waltertadlockwaltertadlock Posts: 2
    December 2020 edited December 2020
    Hey All,
    In need of some assistance.  I am getting an error when trying to merge geografts.
    I have Googled and searched through the forum, and have not found any reference to this error.
    I have tried this with the 1.5 stable and the 1.5.1 dev on Blender 2.83.4, 2.90.1 and 2.91.  I have tried selecing the character model first and then the genitalia, and vice versa.  Same error everytime.  It is the Victoria 8 with the New Genitalia for Victoria 8.
    Help?
    Thanks,
    Walter
    235 x 162 - 10K
    Post edited by Chohole on December 2020
  • ThomasLarssonThomasLarsson Posts: 101
    December 2020
    Walter, are you sure that you don't unselect the first mesh when you select the second? With the B2.7x keymap, the steps are
    1. Right-click select the geograft.
    2. Shift right-click select the body.
    If you don't hold down the shift key when selecting the body, the geograft becomes unselected.
    December 2020
    waltertadlock said:
    Hey All,
    Help?
    Thanks,
    Walter
    I had this error as well and I can't be 100% sure what I did to fix it, but I think this happened after I imported new UV maps for the eyes.  I was using Dimension Theory eyes which required different UV maps.  After some trial and error I found out I cannot use them with geografts, so I just went back to the standard UV maps for eyes.
    Also, avoid importing any morphs when using geografts ('Import Body Morphs' and 'Import Custom Morphs').  You can import JCM's as much as you want and Diffeo will convert those to shapekeys which work pretty well, but importing morphs will break things.
    Please let us know how you make out and what worked for you.
    December 2020
    Thomas,
    Yes sir, I am very sure that I selected them both.  I went back all the way to Blender 2.80.75 and started from scratch with the model and it worked.  I am going to try 2.81 and 2.82 and see what it does there as well.
    Krampus,
    Thank you for the info.  This was a stock import, no changes made.
    Walter
    December 2020
    Select the hair mesh, you might have to seperate out the scalp and any extras (ribbons for example) first.
    Merge custom morphs in Blender > plugin tab. Navigate to the morphs where they are located.
    That might do it.
  • MacislavMacislav Posts: 126
    January 2021
    Today there has been an update to Genesis 8.1
    Does diffeomorphic still work with Daz Studio?
  • tillwillbill222tillwillbill222 Posts: 73
    January 2021 edited January 2021
    Looks like UV maps are different from 8 to 8.1 so I don't think that will work. Everything else seems to be either just higher quality maps or a gimick (FACS) which I dont think will have an impact.
    Edit: I take that back. FACS seem to be some sort of corrective which would be a nice addition for Diffeomorphic to incorporate like JCMs. It's the face controller that is a bit of a glorified parameter gimick
    Post edited by tillwillbill222 on January 2021
    January 2021
    FACS is not a gimmick. It is an industry-standard way of defining realistic facial movement, and it'll be a game-changer for Daz/Blender animators. Another big change with 8.1 is the PBR skin shader. In theory, I think this *should* make it easier to replicate a Genesis 8.1 character's skin in Blender, but we'll see.
«1…6789101112»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
