Plentiful/Lone Tears
I'm trying to use this product: https://www.daz3d.com/tears-hd-plentiful-tears
I have to say, I have had zero luck with it. No model I've chosen works with it, no matter what dials I use. The tears barely come out of the lashes. They're like...specs at best and at worse, they corrupt the cheeks.
Any advice on how to get decent results?
Thanks!
  • Are you using the G3 or G8 version?
  • The G8 Version.
  • PlatnumkPlatnumk Posts: 682
    edited September 2020
    The G8 Version.
    Select the Eyelashes and set the View & Render SubD to 4 otherwise they won't show correctly when using the sliders,  Also make sure you apply the iRay material to the eyelashes.
    Post edited by Platnumk on
  • Platnumk said:
    The G8 Version.
    Thank you! Totally worked!!
  • Your welcome
