Plentiful/Lone Tears
DarkRepast
I'm trying to use this product: https://www.daz3d.com/tears-hd-plentiful-tears
I have to say, I have had zero luck with it. No model I've chosen works with it, no matter what dials I use. The tears barely come out of the lashes. They're like...specs at best and at worse, they corrupt the cheeks.
Any advice on how to get decent results?
Thanks!
Are you using the G3 or G8 version?
The G8 Version.
Select the Eyelashes and set the View & Render SubD to 4 otherwise they won't show correctly when using the sliders, Also make sure you apply the iRay material to the eyelashes.
Thank you! Totally worked!!
Your welcome
