How to rescale head in poser??
jorge dorlandojorge dorlando Posts: 1,159
Hi,
what is the process to scaling a head poser?
to show hidden parameters' including scale?
I'm using Poser Pro 2012
    edited May 2014
    Err.. select the head and use the scale dial..
    Post edited by Lissa_xyz on
  • jorge dorlandojorge dorlando Posts: 1,159
    scale dial....?
    How??
  • scorpioscorpio Posts: 8,534
    Some morph sets ( ++ or evolution or G2 equivalent I think) have a propagating Head scale dial.
    edited May 2014
    I'm trying to reduce the size of the head of Mavka
    Lully in sitemail showed me this:
    Instructions on how to rescale head in poser is as follows, I do not know how to do this in earlier versions of daz or poser
    load mavka in poser
    go to properties tab and right click at the top and select 'show hidden parameters' this will make a lot more visible dials including 'scale'
    select the head and turn scale from 100% down to what you want, around 66% is good, do this on both eyes as well and you have a head rescaled
    note
    But I can not find the parameters of scale to just head
    Post edited by jorge dorlando on
    edited May 2014
    Right click the top of the Parameters panel, or use the white arrow on the right side of it. Show hidden parameters should be the bottom option.
    336 x 276 - 101K
    edited May 2014
    I'm doing something wrong ...
    mine does not show as in your example, not
    1920 x 1080 - 280K
    edited May 2014
    It appears versions prior to 10/2014 don't have that option. D3D has a toolset of free scripts which include UnHide Dials, which will do what you want.
    http://www.contentparadise.com/productDetails.aspx?id=2680
    Don't forget to remove the extended download service option from the cart during checkout.
    edited May 2014
    Vaskania
    Wow! You saved my day!
    Just download the script and run it ... Finally!
    Thank you for help, an indication of the inscript,
    anyway, thanks for everything!
    1920 x 1080 - 273K
    Glad you got it working. :)
  • Saved my day too buddy!
    Thanks Vaskania!  :-)
