How to rescale head in poser??
jorge dorlando
Hi,
what is the process to scaling a head poser?
to show hidden parameters' including scale?
I'm using Poser Pro 2012
jorge dorlando
Hi,
Err.. select the head and use the scale dial..
scale dial....?
How??
Some morph sets ( ++ or evolution or G2 equivalent I think) have a propagating Head scale dial.
I'm trying to reduce the size of the head of Mavka
Lully in sitemail showed me this:
Instructions on how to rescale head in poser is as follows, I do not know how to do this in earlier versions of daz or poser
load mavka in poser
go to properties tab and right click at the top and select 'show hidden parameters' this will make a lot more visible dials including 'scale'
select the head and turn scale from 100% down to what you want, around 66% is good, do this on both eyes as well and you have a head rescaled
note
But I can not find the parameters of scale to just head
Right click the top of the Parameters panel, or use the white arrow on the right side of it. Show hidden parameters should be the bottom option.
I'm doing something wrong ...
mine does not show as in your example, not
It appears versions prior to 10/2014 don't have that option. D3D has a toolset of free scripts which include UnHide Dials, which will do what you want.
http://www.contentparadise.com/productDetails.aspx?id=2680
Don't forget to remove the extended download service option from the cart during checkout.
Vaskania
Wow! You saved my day!
Just download the script and run it ... Finally!
Thank you for help, an indication of the inscript,
anyway, thanks for everything!
Glad you got it working. :)
Saved my day too buddy!
Thanks Vaskania! :-)
