Mystique 2 & Expansions for G8F [Commercial]
245
  • ThyranqThyranq Posts: 589
    Daventaki said:
    So could someone look to see if they have all the material options who have all three packs?
    I have 17 bra options, In the Operator pack I have the first image and the first 5 in the second image missing the last in the 2nd and the whole 3rd image options.  In the Masquerade pack none of the bras are showing... but the panties are...
    Nevermind duh forgot to click the over because of all the options.
    lol I did the same thing
    Not used to having two pages of materials haha
    I think I'm gonna create separate material folders for each item, as there are SO MANY presets holy crap!
  • N3p3nth3 said:
    I accidentally at 4k.
    The level of detail absolutely supports 4k... am loving the shadowed effect of layered stockings & hose and the little tweaks done by HH that really shine when you do a large render. I think I already said it, but it's pretty darn cool work.
  • vaaernvaaern Posts: 90
    I've got a small issue where the collars of the operator blazer poke through the blazer itself, but only on the left side. Can't seem to fix it too.
  • DoctorJellybeanDoctorJellybean Posts: 10,089
    edited August 2020
    The under breast section of the blazer doesn't appear to be smooth, esp with non-default G8F breasts.
    722 x 835 - 119K
    Post edited by DoctorJellybean on
    Can you provide a screen capture or quick render please so I know exactly where the issue(s) are.
    What breasts morph(s) are you using and will be using? These will require there own morphs but is no problem. Also the product comes with two official Mystique breast morphs found (in the parameters pane) under G8F>actor>chest>Herschel Hoffmeyer that work great.
  • Nice render N3p3nth3! Don't forget to apply that heel pose after applying a full-body pose to make sure heel doesn't become distorted.
  • N3p3nth3N3p3nth3 Posts: 136
    Good shout, I usually don't do it if mark 1 eyeball is close enough on the full-body (just fine-tune the ankle bend/twist/sideside), but I'll make sure to do that in the future. :)
    I apologize for the black and white picture. If it's necessary I'll try and open the file when I can. The gray part and the black part of the blazer intersect but it's only on the left side. The other side of the clothing is fine. I though it might had to to something with the included breast morph (since my characters breasts were already kinda big and it made them massive). But I turned it off it's the same thing. (sorry for my English, I hope I explained it well enough).
    309 x 496 - 153K
    Here is a collar adjustment morph that should fix the problem and please let me know if it does. Just download the file and install it to your daz library folder, same one the Mystique product installed in.
    It works a little bit. Though Now that I've tried some other morphs some more. I've used the "undress expose breasts" morph which seems to cause the poking through. I've reduced it by a bunch and that seems to fix it.
    Oops, sorry. I was hoping to catch you before downloading. I should have double checked the morph in daz, I fixed it. Sorry for the double download, here is the correct morph as the last one was not properly exported from my modeler.
    Collar Adjustment Morph
    Well, I tried that, and unless I did something wrong (I just overwritten the previous collar morph) it doesn't do that much either. I'll keep the undress morph thingy on a lower number for now. That seems to work as well. There's enough breast to be seen :)
    You did restart DS after replacing the morph?
  • No the issue was definitely on my end again lol. It's one of those days for me, to many distractions at the house. I must have forgot to save the wearable once the morph was working properly. Tested and retested, third time's a charm.
    Collar Adjustment Morph V3 lol
  • No material presets for the Support Bra?
    You should have...
    Mystique 2
    • M2 Support Bra 1A Black Lace
    • M2 Support Bra 1A Black Sheer Lace
    • M2 Support Bra 1A Taupe Lace
    • M2 Support Bra 1A Taupe Sheer Lace
    • M2 Support Bra 1B White Lace
    • M2 Support Bra 1B White Sheer Lace
    Operator
    • M2 Support Bra 1C Red Lace
    • M2 Support Bra 1C Red Sheer Lace
    • M2 Support Bra 1D Blue Lace
    • M2 Support Bra 1D Blue Sheer Lace
    • M2 Support Bra 1E Pale Pink Lace
    • M2 Support Bra 1E Pale Pink Sheer Lace
    • M2 Support Bra 1E Pink Lace
    • M2 Support Bra 1E Pink Sheer Lace
    • M2 Support Bra 1F Black and Red Lace
    • M2 Support Bra 1F Blue and Pink Lace
    • M2 Support Bra 1F Purple Lace
    • M2 Support Bra 1F Purple Sheer Lace
    • M2 Support Bra 3A Black Lace Dark Stripes
    • M2 Support Bra 3A Black Lace Pale Pink Stripes
    • M2 Support Bra 3A Black Lace Pink Stripes
    • M2 Support Bra 3A Black Lace White Stripes
    • M2 Support Bra 3B Black Lace Pink Plaid
    • M2 Support Bra 3B Black Lace White Plaid
    • M2 Support Bra 3C Leopard Black and Pink
    • M2 Support Bra 3C Leopard Pink
    • M2 Support Bra 3E Hot Pink Polka Dot
    • M2 Support Bra 3F White Pink Plaid
    Masquerade
    • M2 Support Bra 2A Black Lace
    • M2 Support Bra 2A Black Sheer Lace
    • M2 Support Bra 2D Black Red Lace
    • M2 Support Bra 2G Black Lace Red Plaid Lace
    • M2 Support Bra 3C Cheetah
    • M2 Support Bra 3C Skulls Roses Black
    • M2 Support Bra 3C Skulls Roses Red
    • M2 Support Bra 3C Skulls Roses White
    • M2 Support Bra 3C Zebra
    • M2 Support Bra 3D Zebra Hot Pink
    • M2 Support Bra 4A Black Lace Bare
    • M2 Support Bra 4A Taupe Lace Bare
    • M2 Support Bra 4B White Lace Bare
    • M2 Support Bra 4C Red Lace Bare
    • M2 Support Bra 4D Pink Lace Bare
    • M2 Support Bra 4E Purple Lace Bare
    • M2 Support Bra 5A Black Lace Fishnets Bare
    • M2 Support Bra 5A Black Taupe Lace Fishnets
    • M2 Support Bra 5B White Lace Fishnets Bare
    • M2 Support Bra 6A Black Fishnets Bare
    Be sure to notice, depending on your setup, multiple pages of material presets.
  • Duh! I never thought about the extra page(s). I'm so used to just one lol.
    Thanks.
    Thanks.
    I know right?
    There's a LOT of materials lol. I just finished making some folders and separating everything by item so I don't get lost in them all haha
    edited August 2020
    Haha, I'll test it out later today! Thanks for trying, it happens to all of us I guess :D edit: It worked perfectly, thanks!!!
    Thanks.
    I know right?
    You can also 'zoom out' the pages, because they're all in one page for me.
    Post edited by vaaern on
  • JVRendererJVRenderer Posts: 664
    I loved the first set. Grabbed the second core set. I wish I could afford all three packages
  • Which figure was used for the promo of this product?
    https://www.daz3d.com/mystique-2-for-genesis-8-females
    Thanks
    Thanks
    My own that I'm working on that will be released as the official Mystique character for the Mystique line of products. I have more info about this upcoming character on my artstation blog (artstation link in signature).
  • DaventakiDaventaki Posts: 1,624
    edited August 2020
    Love the bend corrective morphs they look great!  She is a insta-buy!
    Mystique 2 I had to do some mesh grabber in some spots on the hose nothing major tho mainly around the knee area.  The veil on the other hand I went round and round with. The veil comes back to far over the hair/ears which made it look funny with this image (It looks fine when the hair is down like in the promos).  I also tried to dforce it to take on more of the face shape but nope it didn't matter what I did it would always fall through her face for some reason. So I got out my handy mesh grabber and along with the included morphs made it close to what I was going for.   The set only includes a white bottom with the skulls where the bra comes with white and black but it was an easy fix to change the color!
    Stunning outfit as usual!!
    (I just realized I hid the choker and didn't turn it back on *forehead slap)
    Post edited by Daventaki on
    Thanks
    I've read your blog, can't wait for the character and various morphs. As well as the additional content. The weekend is almost over smiley
  • Herschel HoffmeyerHerschel Hoffmeyer Posts: 713
    edited August 2020
    Great render! What character are you using? You should be able to correct all stocking issues with the adjustment morphs provided. To be absolutely perfect, as a product, you would need a morph for every joint bend for every supported character.
    The veil was designed to match that of reference images which came back a bit further actually. Usually, with a veil, you need complimenting hair to go with but exposing the ears (where the veil ends) I don't think is a bad thing.
    Everything looks great though, good job!
    Thanks
    The character will more than likely be coming to Daz. I haven't decided yet but I think I can turn it into a big enough product for a daz release. Also, with all the custom bending morphs, I have to follow that up with the proper clothing morphs for that bend. I have a lot more work ahead of me for this one than I originally planned.
    Another blog update will be coming later today explaining more and the Garter Belt will become available for purchase.
    Post edited by Herschel Hoffmeyer on
  • The character will more than likely be coming to Daz. I haven't decided yet but I think I can turn it into a big enough product for a daz release. Also, with all the custom bending morphs, I have to follow that up with the proper clothing morphs for that bend. I have a lot more work ahead of me for this one than I originally planned.
    Hopefully that'll include the tattoos? If so, maybe include it as a standalone L.I.E preset, so that it can be used with any texture.
    edited August 2020
    Deviantart is blowing up with mystique pictures, so I have seen quite a few by now, but this one is absolutely exquisite. I'm going to stick to my day job! :D
    Also would love to know which character you used as base!
    Post edited by N3p3nth3 on
  • It would be great if you could at some point create a morph to adjust each Strappy Garter strap individually.
  • GreybroGreybro Posts: 2,705
    Instabuy! You're quickly becoming my favorite costume creator!
    edited August 2020
    Getting the lighting was a bit tricky
    1822 x 1366 - 4M
