Fit Control for Genesis 8 (Commercial)
17810121318
  • I updated my version to 1.2 and it crashed out immediately after "fit control has been applied". If given the chance to test the test file, I will and respond with logs in kind. I'll test it in a single instance of daz studio and while multiple are running, to put it through it's paces. However, it will be under 4.11, as 4.12 still has many issues to sort out in basic functionality.
  • xyer0xyer0 Posts: 6,348
    I'd be glad to test and provide same-day feedback. It's been over a year since I could use this on G8F, but I have not resorted to anything other than patience.
  • Zev0Zev0 Posts: 7,123
    edited August 2020
    edited
    Post edited by Zev0 on
  • I been following this since suddenly last week started crashing.  I ran the program with the figure Gwyn HD figure with lingerie, and works fine. I run it with another character with same clothing and does the crash. Dont know why Gwyn figure is working?
    this Gwyn? https://daz3d.com/catalog/product/view/id/53397
    it crashed with her loaded and only basics on.
  • jimboisthemanjimboistheman Posts: 4
    edited August 2020
    Correct, 53397 Gwyn worked for me for some odd reason but maybe not for others.
    Post edited by jimboistheman on
  • boopaterboopater Posts: 21
    Tried v1.2 and it crashed just like always right after applying.
    edited August 2020
    Version 1.3 is wrapped up and worked fine to all those who tested it. We will notify users when the update goes live.
  • Looking forward!
  • I updated the files and still get an instant crash out. running Daz 4.11.
    Version 1.3 is not available yet.
  • jardinejardine Posts: 1,217
    great news.  thanks!
  • Great, Thanks Z
    It's so nice having Fit Control back. It works better than ever. Thanks so much for fixing it, Zev0, and letting me test it.
  • inquireinquire Posts: 2,435
    Is a new version of Fit Control back? I didn't find it in my DIM.
    It is in QA. It is not released yet.
  • What is QA?
  • Quality assurance I suppose. So DAZ team is testing on bugs prior to release.
    surprise That's a thing?
    Is there a Fit Control morph that loosens/tightens around the upper shin? I have some boots that fit too loosely.
  • Yes, QA typically means Quality assurance. However, it all depends on which version it's being tested on.
  • Does FitControl work with dForce clothes?
    edited September 2020
    Yes it does. There are examples in the addon promo images.
    Version 1.3 is now live. We made it work with Studio 4.11 as well. Thank you for your patience.
  • SevrinSevrin Posts: 6,313
    So it is. Thanks.
    That would be a negative on my end- still crashes out. will upload a log file later.
    Crashes out how? Can I see some screenshots of what items are listed in script please.
    I tried it quite a few times and had no issues.  It's faster than it was toward the end, as well.
    Like a light switch. I press ok, then Daz just ends. Car into concrete barrier. Abrupt.
    see attached docs:
    A picture of your request.
    A picture of the ok screen.
    a picture of the creash window after i select 'details'.
    The saved crash file in the zip file that Daz studio generated.
    the unabridged log file, from daz startup, loading of the basic genesis 8 female model, basic wear and application of fit control.
    I'm hoping something in here can help you determine what's causing this, beceause this is well outside my depth of knowledge.
    4032 x 2268 - 2M
    4032 x 2268 - 3M
    4032 x 2268 - 5M
    zip
    zip
    DAZStudio_error_report_200915-094600.zip
    155K
    txt
    txt
    log.txt
    747K
    Thanks. So it crashes after you hit ok?
  • I'm seeing exactly the same crash as Mathias. I'm running 4.12 on Windows 10.
    The issue seems to be related to the set of installed g8f character morphs. If I go into data\DAZ 3D\Genesis 8\Female\Morphs and move all the folders to another directory, except DAZ 3D and Zev0, then I can successfully add the fit control morphs. I then start moving the folders back into the morphs folder in small groups. It continues to work for the first few groups of folders that I add back, but eventually it reaches a point where it starts failing again.
    If I then move all the folders out again, but keep the group that caused it to start failing (and DAZ 3D and Zev0), then everything works ok. So that suggests that the problem isn't specific to those morph folders.
    I guess it's either an issue with the number of morphs, or some problem with certain combination of morphs.
