• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
blend files from daz - missing textures?
Lothar WeberLothar Weber Posts: 1,611
July 2020 edited July 2020 in Blender Discussion
I downloaded the open attic .blend file from daz. Now in blender it's missing some textures. Any clues?
Post edited by Lothar Weber on July 2020
  • Lothar WeberLothar Weber Posts: 1,611
    Another example of error in blender file of "Industrial Loft" - see image. Walls are missing and the floor is somewhere...
    1819 x 1010 - 306K
  • TDBAGZTDBAGZ Posts: 165
    Some Textures arent compatible between the two, IRAY / EVEE or Cycles.
    I dont know if its an MTL, MDL vs RSL, or Iray issue, but I have noticed that Blender always look more like 3DL, even G8Fs eyes (iris) dont display in Blender.
    I think Blender displays the one of the shader settings different Gloss, Reflection, SSS, or Specular (G8F Eye Moisture).
    The UV map and surface "Material" zone assisments are correct when importing to Daz from Blender but dont I dont have enough or recent experience with transfering material presets between the two.
    You might try adjusting those presets on a set of spheres as a test and see if any display oddly.
    Might need to tweak, reset, or even redo shader settings with the principal shader or uberbase.
    Again I have very limited experience on material transfer and Blender rendering.
    I usually model, unwrap and map UV, as well as assisgn surfaces (Materials) in Blender. Then either transfer a painted color map or use the uberbase to color and shade for DS in DS.
    ADDENDUM: I have also had issues showing volumemetric shaders in blender, it needed a created Blender light to appear in addition to just the default viewport lighting.
    Post edited by TDBAGZ on July 2020
    July 2020
    Thank you for the answer. But they are official daz Blender (.blend) files. Downloaded from the product pages. They should work in blender without any additional work - in my opinion...
  • markusmaternmarkusmatern Posts: 604
    Basically you have three options:
    1. Open a ticket and wait until it gets fixed
    2. Fix the problem in the shader
      1. The texture in the blend file, that is referenced is: granite_blackBitmap_granite_black_baked.png
      3. This is also the one used when you load the set in DAZ. In DAZ it is also used with a tiling of 5.
      4. In Blender activate the Shading workspace
      5. Open the Outliner editor and open ATS Wall 01 -> ATS Wall 01.Shape -> Mesh -> Set_9
      6. Now you can change the texture and change the tiling in the Shader Editor.
    3. Fix the problem in the file system
      1. Locate the extracted textures subdirectory where you installed your Blender files
      2. Copy the file granite_black.png to granite_blackBitmap_granite_black_baked.png
    The same is with the vases, here the texture name is white_marbleBitmap_white_marble_baked.png (Copy from white_marble.png)
    These two need to be converted from their JPG versions:
    1. There are two boxes on the floor which use brownpaperBitmap_brownpaper_baked.png (Convert from brownpaper.jpg)
    2. And last but not least a picture on the wall: picture01Bitmap_picture01_baked.png (Convert from picture01.jpg)
    1898 x 1028 - 310K
    Post edited by markusmatern on July 2020
    July 2020
    WOW thank you - that was fast. Seems we need to wait for the fixes a little longer, since it is so new.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
