Layered Image Editor rendering weird *solved*
Tako YakidaTako Yakida Posts: 548
edited July 2020 in Daz Studio Discussion
I can't get the images I add to show up properly in Iray.
They look very faint and ghostly.
Any idea on what could be wrong?
Thanks in advance.
Post edited by Tako Yakida on
    Try adding it to the translucency image also.
  • Eustace ScrubbEustace Scrubb Posts: 2,744
    Also, make sure to layer them correctly and try different blend styles (alpha, additive, subtractive, multiplicative) for the various layers.
  • FenixPhoenixFenixPhoenix Posts: 3,258
    Indeed, this is often caused by the translucency channel. You can either add the image to that map as well or lower the translucency.
  • Tako YakidaTako Yakida Posts: 548
    Thanks guys, that worked! ^_^
