Layered Image Editor rendering weird *solved*
Tako YakidaTako Yakida Posts: 548
edited July 2020 in Daz Studio Discussion
I can't get the images I add to show up properly in Iray.
They look very faint and ghostly.
Any idea on what could be wrong?
Thanks in advance.
819 x 1364 - 200K
Post edited by Tako Yakida on
    Try adding it to the translucency image also.
  • Eustace ScrubbEustace Scrubb Posts: 2,744
    Also, make sure to layer them correctly and try different blend styles (alpha, additive, subtractive, multiplicative) for the various layers.
  • FenixPhoenixFenixPhoenix Posts: 3,258
    Indeed, this is often caused by the translucency channel. You can either add the image to that map as well or lower the translucency.
  • Tako YakidaTako Yakida Posts: 548
    Thanks guys, that worked! ^_^
