Need help creating a Camera Modifier.
SighmanSighman Posts: 56
Hi,
I have created a tree modifier that I want to apply to a camera. However, the modifier only shows up for instances. Does anyone know what needs to be done to get it registered as a camera modifier?
Thanks
  • Eric WinemillerEric Winemiller Posts: 84
    // Cognito Data
    resource 'data' (200)
      'li  ', // light
      'ca  ', // camera
      'prim', // instanciable primitive
      'grou', // group
    Good luck,
  • SighmanSighman Posts: 56
    Thanks Eric but that didn't work. I managed to get it to work by adding a '# 1' to the category...
    I guess there is no way to keep it out of the other menus?
    resource 'COMP' (kPanoramicCameraModifier) {
     kRID_ModifierFamilyID,
     kPanoramicCameraModifierID,
     "Panoramic",
     "Panoramic # 1", // This is what makes it show up in the Camera menu.
     FIRSTVERSION,
     VERSIONSTRING,
     COPYRIGHT,
     kRDAPIVersion
    resource 'GUID' (kPanoramicCameraModifier)
      R_IID_I3DExModifier,         /*I3DExModifier*/
      R_CLSID_PanoramicCameraModifier
    resource 'PMap' (kPanoramicCameraModifier) {
      'mode', 'in32', noFlags, "Panoramic Camera Mode", "",
      'hfov', 're32', interpolate, "Horizontal Field of View", "",
      'vfov', 're32', interpolate, "Vertical Field of View", ""
    // I added this anyway but I don't know what it does...
    resource 'data' (kPanoramicCameraModifier) {
     { 'ca  ' }
    Huh. That data resource was all I did to make Cognito show up for cameras. Interesting to know.
    Regards,
    Well, I ended up switching to a DataComponent. I can control when it shows up in the Effects Tab and for a particular Camera type which is what I need. That 'data' resource you provided works well with Data Components.
    Thanks again for your invaluable help.
