Need help creating a Camera Modifier.
Sighman
Hi,
I have created a tree modifier that I want to apply to a camera. However, the modifier only shows up for instances. Does anyone know what needs to be done to get it registered as a camera modifier?
Thanks
Good luck,
Thanks Eric but that didn't work. I managed to get it to work by adding a '# 1' to the category...
I guess there is no way to keep it out of the other menus?
Huh. That data resource was all I did to make Cognito show up for cameras. Interesting to know.
Regards,
Well, I ended up switching to a DataComponent. I can control when it shows up in the Effects Tab and for a particular Camera type which is what I need. That 'data' resource you provided works well with Data Components.
Thanks again for your invaluable help.
