Adding to Cart…
Thanks ! There must be some great Russian Comics & Cartoons that you could use as a base, always love to see your work !!
The Great Pickup Artist versus the Great Putdown Artist - nice render !
One of my favourites, along with The Phantom & Garfield. Any chance of a render or two from you as well !
Thanks Stezza !
The Indelible AlphaMan, hot on the trails of the no-good WIP-1 - Not an entry
WIP - Scene, another Instances to Objects conversion
Render
Topaz Adjust
The Indelible AlphaMan, hot on the trails of the no-good WIP-2 - Not an entry
Topaz Simplify
Text and Thought Bubble
Final Image
cool stuff this... reminds me that Lucifer will back on telly next month .. S5
You're In
_thanx, but don't guess , ought to try and name Fav's might take
too many forum pages,
_and Yeah, am trying to work up some scenes *
Where's Wally strikes ! Nice one !
I have plenty that I read when available, Swamp is another good one !
Hope you have time to get those scenes done !!!
Two eyed Aliens - WIP-1 - Not an entry
WIP - Scene
Render
Topaz Adjust
Two eyed Aliens - WIP-2 - Not an entry
Filter Forge
Speech Bubble & Text
Final Image
Rework of Tough Urban Woman vs Yucky Man
Thanks for the comments everyone, especially ed3D. Hope this makes it more clear he is bothering her. I did a separate render of a bus from the browser tray to create the texture map for the bus stop sign.
Composite with NPR
I rendered out a base render (most shaders converted to black/white gradients), coverage pass, and shadow pass.
I took the base render and inserted it in the backdrop of a new scene.
In the render room, I switched from photoreal to NPR. I rendered out two NPR renders, one with a very transparent brush and one with a more dense brush.
I composited the shadow pass with the NPR, and adjusted some with the base pass to get the text more readable. I didn't like the lines from the coverage pass show I excluded it.
Here are the scene setups and NPR settings - but remember that I composited with the base render. I've posted two screengrabs to show the two different brushes. There are two scene setups because the first one has the figures and set and the second shows the first base render inserted in backdrop of a new NPR scene.
quickie visit to keep hat in ring - sorry not to comment on the excellent renders! been busy managed to pick up some work - finally
this is Freddie from poser - custom morph Working Title - if only you were real like me ...
freddie unprocessed is here https://poserdazfreebies.miraheze.org/wiki/Freddie
thanks ! yes Poser runtime is full of 'stuff'
great scene and body language and style !
thanks again for those walk throughs, great library of data here in this thread
this one is my favourite style I think
I still think you should work for the newspapers as a social commentator :)
some random stuff from my runtime PhilW's Giovanni and Tiny ? Tim.
Topaz simplifuy, filter forge for watercolourt texture Photodonut for pencil lines
Used Carrara's built in Toon filter and also ToonPro for line work
prepost image - geographically in post I tilted boy's head more (chap on right) and made the kids eyes smaller as that kind of head and eyes annoys me :)
Nice work on the composition !!
I should use the NPR setting more often, thanks for showing your settings !
Some nice items in there !
Hopefully will be of use to those contemplating doing post work !
I have a number of favourites, the filter used is one of them.
Gets both the thoughts and the giggles going !!!
Interesting blend you have going there ! Hmmm "Let them eat cake", made an Orange cake this afternoon - yummy !!
Pink - WIP-1 - Not an Entry
Is a Poser figure, was doing some funny things in Carrara while trying to pose it, so assume it is a late Poser item with weight painting issues.
WIP - Scene
Render
Topaz Adjust
Pink - WIP-2 - Not an Entry
Topaz Adjust image with Gaussian blur applied
DAP filter
Final image
Oh, What A Tangled Web
The image is pretty dark, so you will need to click on to the larger size so the white forum background doesn't fry your eyes. :)
I rendered the BG separately, and loaded it onto a plane. It was made using the Black Widow model and a GMIC filter (Contours>Skeleton, the raw render is below), and then tweaked with lights and bump maps.
Spiderman is M4, using the Joe Quick freebie morph and textures at ShareCG. The boots and mask have individual morph controls. Pretty impressive for a freebie!
No postwork
