CARRARA CHALLENGE 53: Cartoons & Comics - WIP
1235712
  • HeadwaxHeadwax Posts: 10,437
    mmmmm brains ....
    ha ha yes they are good with capers
    hope you arent being locked down
    edited July 2020
    "Felix is losing it"
    Another wip panel
    Kitchen is Andy's fabulous ( and free!)  Scene - thank you, it's a gem, easy to work with and full of character
    a better crop
    1983 x 2000 - 3M
    2000 x 3030 - 5M
    Post edited by Headwax on
  • Bunyip02Bunyip02 Posts: 9,278
    Another wip panel
    a better crop
    The plot thickens - will make for a great mini graphic novel !
    edited July 2020
    Evolution - WIP-1 - Not an Entry
    WIP-Scene
    Test render
    Toon! part III
    Test render
    Topaz Adjust - used HDR Sketch this time
    2256 x 1035 - 1M
    1600 x 1200 - 2M
    2269 x 1037 - 1M
    1600 x 1200 - 2M
    1921 x 1039 - 1M
    Post edited by Bunyip02 on
    edited July 2020
    Evolution - WIP-2 - Not an Entry
    Topaz Studio - Simplify
    Gaussian Blur in PSP
    Used Radius of 2
    Final Image
    1919 x 1044 - 2M
    1923 x 1024 - 1M
    1918 x 1039 - 1M
    1600 x 1200 - 4M
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Thank you Dart, Bunyip, and HW for the comments on the Kirby tribute render.  Very much appreciated!
    You're welcome UB, always looking forward to what you have to offer, hope you have time to do a few more renders !!
    edited July 2020
    Power Pixie fun - WIP-1 - Not an entry
    WIP - Scene
    Test render
    Topaz Adjust
    PicToPainting
    2260 x 1033 - 1M
    1600 x 2120 - 3M
    1916 x 1033 - 906K
    1921 x 1037 - 1M
    edited July 2020
    Power Pixie fun - WIP-2 - Not an entry
    PicToPainting added as layer in PSP, Opacity adjusted
    Text & Speech Bubble added
    Final image
    1921 x 1042 - 1M
    1925 x 1039 - 1M
    1200 x 1590 - 5M
  • DartanbeckDartanbeck Posts: 21,988
    Awesome HW!!! Very cool render!
    Bunyip, that Evolution is using Mec4D's Evolution textures on Genesis, perhaps? Looks great regardless!
    I'm loving everything I've seen in here so far! Great job everyone!
    Thanks - Shaders on Genesis are from Darwin the Toon Chimp - https://www.daz3d.com/darwin-the-toon-chimp
    Darwin has a custom UV, so I loaded him in DAZ Studio and saved as a Character Preset and opened that in Carrara.
    Still hoping you get time to join in !
    Thanks Bunyip at Dart !
     yes it is going somehwre - into a dark and unlit abyss :)
    Power Pixie is terrific. Great pose very... err powerful :)
    More little Johnny
    1788 x 2000 - 3M
    More little Johnny
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,303
    nice use of 3Dage kitchen there
    More little Johnny
    Thanks
    Great to see little Johnny progressing !
    No extra scene from me today, been working on a DAZ Studio scene in Carrara, all of it's items are grouped together which is making life difficult, nearly given up on it several times now....
    Select them all within the group > Ctrl + U (Ungroup)
    Thanks Dart, tried it but it didn't work. All of the objects in the scene are together on the one layer, only thing that is different are the UVs. Found a solution that works, but due to the size of the scene it's slow work !
    edited July 2020
    Toon Croc WIP-1 - Not an entry
    Had a few problems with this scene. Base scenery is a DAZ Studio scene that is all one object with just the UVs different.
    Next when I loaded it into Carrara all of the leaves/branches loaded without transperancy maps, when I loaded them the leaves on all the trees turned invisible regardless of what I did.
    Tried deleting the troubled trees in the model room but due to the size of the scene it was taking forever, then decided to turn the maps for the trees invisible.
    1. The offending scene
    2. The tree vegetation shaders worked on
    3. Kept the transperancy map in the Alpha channel just in case it was needed for a possible fix, went down to Operators and clicked on Multiply. For source 2 I clicked on Value (0-100%) and left the value at 0.
    Next issue was that I wanted to use a Surface Replicator to add some trees to the scene, since there was no individual Terrain layer I had to obtain it from the combined object.
    Opened the scene in DAZ Studio and exported it as an obj in Carrara units, next I opened that obj in Silo.
    Using the Grow Selection command in Silo I picked the Terrain base
    Once picked I copied and pasted the Terrain, deleted the original combined obj, then exported the Terrain obj for use in Carrara.
    2271 x 1035 - 1M
    2265 x 1039 - 553K
    2142 x 1009 - 1M
    2140 x 1009 - 1M
    edited July 2020
    Toon Croc WIP-2 - Not an entry
    After loaded the Terrain obj into Carrara with AutoPosition and AutoScale turned off, loaded a Surface Replicator into the scene
    1. Chose the Terrain obj
    2. Added a tree
    3. Set the number of trees, however, down the bottom of the screen I got fewer
    4. Adjusted Rotation
    5. Adjusted scale
    6. Unticked Align object to normal
    7. Adjusted distance
    8. Ticked Use Shader
    9. Clicked on Edit Shader
    10. Needed to load a texture Map
    11. Located and loaded the Map
    After doing a Test Render, took the render into Topaz Adjust
    Final Image
    2276 x 1037 - 1M
    2221 x 1010 - 265K
    2267 x 1035 - 485K
    1923 x 1044 - 999K
    800 x 504 - 844K
    edited July 2020
    Toon Croc WIP-3 - Not an entry
    Had a problem with the Toon Croc when first loaded - no skeleton for posing
    Opened Toon Croc in DAZ Studio, clicked on Edit - Figure - Rigging - Convert Figure to Weight Mapping
    Chose TriAx Weight Mapping
    Save As - Support Asset - Figure/Prop Assets
    Name
    2414 x 1027 - 506K
    2416 x 1029 - 468K
    2421 x 1027 - 513K
    2414 x 1025 - 424K
    don't collapse the UV tiles exporting an obj!
    I discovered this the other day
    Carrara can read UDIM
    edited July 2020
    Toon Croc WIP-4 - Not an entry
    Save Options - Accept
    Save As - Character Preset
    Name
    2427 x 1029 - 435K
    2418 x 1035 - 512K
    2427 x 1026 - 439K
    Thanks for that advice Wendy - is handy to know !
    Bummer. Sorry. Yeah, some DUF scenes I just give up on. I haven't been returning them, just giving up until the day I decide to try them in DS - as much as I do jump into DS, I still never work that way - as a render studio.
    The animation I was working on made me think of this thread, but alas... I remember that folks don't really care for Dart and Rosie renders around these parts - so I digress. I'll think of something before this is done, perhaps! ;)
    who said that?
    I love your renders, always have
    I am just not fond of tutorials by anyone
    I only watch ones when I really need to find out something, yours are good BTW but they are still tutorials
    I utterly love your actual render videos! heart
  • StezzaStezza Posts: 8,819
    edited July 2020
    Jack Kirby Tribute
    The background is Urban Sprawl rendered in the Carrara Non-Photorealistic render engine.  Jack could do amazingly detailed foreground images, but he often left the background sketchy.  I wanted a sketchier look.
    After loading the background onto a plane, I added the characters, which are Genesis (Hulk), F4 (The Thing), V4, K4, and M3 (the cops).  The police car is a Carrara native object.  I made the caption, and tweaked a bunch of things in the modeling room.
    The Thing is in a classic Jack Kirby pose.  Just copying the pose - by itself - was an education.
    In the beginning, I wasn't sure that I could get The Thing rock texture to look how I wanted.  But the Carrara shader room astounded me.  I didn't have to import any maps.  The texture is all Carrara.  Toon 3 was used for outlines, and GMIC (within Carrara) provided some basic image controls.
    No postwork.
    awesome... your fav settings & style certainly shine yes
    I fiddled around with ChickenMan Lorenzo again with textures for his chicken supersuit and different set up using mmoirs city background and some free stuff from mortemvetus from RDNA when it was there.
    Rubble
    1586 x 788 - 189K
    800 x 600 - 653K
    Post edited by Stezza on
    edited July 2020
    seen a post about Hagar...
    so today I modeled an table, beer stein with froth, Viking outfit, shield, helmet, sword and arrows and did a Hagar render!
    using Genesis
    900 x 675 - 1M
    Would love to get Howie's Ultra Scenery converting to Carrara, but the potential size of the files (if it is practical to do so) has me going EEEEK !!!!
