Render Studio 2.0 Question (solved)
EZ3DTVEZ3DTV Posts: 1,598
Does Render Studio disable other lights in the scene when using their scene templates?
Is there a way to get around this?
Post edited by EZ3DTV on
    edited July 2020
    If you just double click the scene, things will be replaced. Right click on the scene and select "Merge into Scene". Similar behavior if you want to replace a material but leave the texture/surface print.
    Post edited by fastbike1 on
  • EZ3DTVEZ3DTV Posts: 1,598
    edited July 2020
    Thanks Fastbike for the awesome help!
    Solved, I guess other lights are working now. Not sure what the problem was.
    They seem to be working fine along with the compliment of Render Studio 2 lights and atmosphere.
    @RexRed
    Perhaps I wasn't clear enough. If you previously just double cliked on a Render Studio scene, it replaced your lighting. If you followed my advice, the Render Studio lighting was added to your scene.
