[Released] RSSY Clothing Converter from Victoria 4 to Genesis 8 Female [Commercial]
1…1011121315
  • RitaCelesteRitaCeleste Posts: 625
    Some clothing will have minor problems and you can edit it out with postwork. Clone brush!  The Glacerial Queen and the Dragon Keeper sleeves come down over the hands. They did not get fitted. I could make the sleeves invisable, or paint the cuffs away in photoshop. I bought the morphs for kitbashing also.  If a V4 dress has issues, a different one for a later gen may not.  I am not going sweat a few hard items and spend hours and hours on that doing it by hand if I can find a shortcut.  Tons of items worked.  Finding the V4 files from Renderosity was the bigger pain. With the hair files, I have hair but no textures in some files, but a huge working library.  This is fine because I love hair shaders and my plan was to have hair I can use with hair shaders. Modern Iray Shaders are important if you want keep using old stuff too.  I love making shaders although my past efforts were lost, I did buy some too.  And I still have seamless textures I collected.  I am going after some shoes though, that works great and so fast.  If I want to bother with Deforce, I have to speed things up somewhere.  These products do speed up things a lot. Thanks.
  • RiverSoft ArtRiverSoft Art Posts: 6,977
    You're welcome!  I am glad you are satisfied.
    Thanks for the help finding the morphs. I love the foot poser.  Shoes and boots and heels are going threw fine.  You're right tightening things down is the easy part.  They work great.  I did not expect this to work this well and fast. I'll be out of things to convert soon and back to making characters though. Thanks again.
    You're welcome.
  • sueyasueya Posts: 869
    I have had problems converting Lady Littlefox's  Cowl Dress (see attached image)  This is the first time this has happened with a dress. As you can see the sleeves are above the arms.
    1007 x 770 - 121K
  • inquireinquire Posts: 2,464
    Any chance there will be a Michael 4 to Genesis 8 Male version?
  • MelanieLMelanieL Posts: 7,882
    You mean this one? https://www.daz3d.com/rssy-clothing-converter-from-michael-4-to-genesis-8-male
    The one thing I can suggest is to delete all morphs, etc for the converted dress, restart Daz (maybe even restart the OS), and try immediately converting that item.  I have seen occasions where Daz will struggle after converting a bunch of items.  Sometimes, restarting and doing it again can help.
    What @MelanieL wrote (thanks @MelanieL for the assist smiley)
  • DMaxDMax Posts: 637
    I purchased the RSSY M4-G8 converter today and went through the entire conversion after first reading the pdf.
    (1) Rebooted DS after the conversion was completed
    (2) Loaded and selected G8M and clicked Filter by Content... none of the M4 wardrobe items showed up in Smart Content > Wardrobe
    (3) I then noticed that many of my M4 items were located at Smart Content > Lost and Found
    (4) Test loaded one of the M4 clothing onto the selected G8M character... clothing loaded but did not at all conform to G8M (stayed in T pose instead of A)
    (5) Despite the conversion, am I still supposed to load the "Parent to.." and "Fit from..." options?
    I had the impression that the converter would automatically turn M4 items into ready-to-load G8 items but I must be mistaken.
    Or I must be doing something very wrong?
    There is something going wrong because you don't need "Parent to" and "Fit".  The converted items will not show up in the "Products" Smart Content, but in the "Files" Smart Content.  If the M4 items did not have smart content, I believe they will show up in Lost and Found.
    Can you convert something and post the Daz Log please? (Help->Troubleshooting->View Log File)  Only the conversion itself, not the whole log.
    Not sure which bits of the log I should post but I did the conversion a second time after I posted on this thread.
    So I am posting two pieces of the log, one from the first conversion (2020h) and the other from the second (2140h)
    [first]
    2020-07-02 20:24:58.437 Importing File...
    2020-07-02 20:24:58.437 Importing generaljacket.cr2 ...
    2020-07-02 20:24:58.486 Reading P3DA_GeneralJacketNB.obj
    2020-07-02 20:24:59.465 File imported in: 0.1 sec (1028.15 ms)
    2020-07-02 20:24:59.488 WARNING: /src/sdksource/elements/joints/dzlegacyjointrotator.cpp(39): NULL driver for joint parameters in DzLegacyJointRotator::DzLegacyJointRotator()
    2020-07-02 20:24:59.505 WARNING: /src/sdksource/elements/joints/dzlegacyjointrotator.cpp(39): NULL driver for joint parameters in DzLegacyJointRotator::DzLegacyJointRotator()
    2020-07-02 20:24:59.518 WARNING: /src/sdksource/elements/joints/dzlegacyjointrotator.cpp(39): NULL driver for joint parameters in DzLegacyJointRotator::DzLegacyJointRotator()
    2020-07-02 20:24:59.631 WARNING: /src/sdksource/elements/joints/dzlegacyjointrotator.cpp(39): NULL driver for joint parameters in DzLegacyJointRotator::DzLegacyJointRotator()
    2020-07-02 20:24:59.635 WARNING: /src/sdksource/elements/joints/dzlegacyjointrotator.cpp(39): NULL driver for joint parameters in DzLegacyJointRotator::DzLegacyJointRotator()
    2020-07-02 20:24:59.862 Imported file: /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/runtime/libraries/character/p3da_m4_armygeneral/generaljacket.cr2
    2020-07-02 20:24:59.892 Building Scene...
    2020-07-02 20:25:00.445 File loaded in 0 min 2.4 sec.
    2020-07-02 20:25:00.446 Loaded file: generaljacket.cr2
    2020-07-02 20:25:00.830 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2020-07-02 20:25:00.831 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2020-07-02 20:25:00.844 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
    2020-07-02 20:25:00.844 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2020-07-02 20:25:00.888 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 370k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 370k triangles, 0 fiber instances yielding 0 segments) took 0.044s
    2020-07-02 20:25:00.888 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2020-07-02 20:25:00.909 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 313 textures, 0 lambdas (0 unique)
    2020-07-02 20:25:00.915 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2020-07-02 20:25:00.915 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2020-07-02 20:25:00.915 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2020-07-02 20:25:00.915 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2020-07-02 20:25:00.916 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2020-07-02 20:25:00.917 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2020-07-02 20:25:00.919 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 12 cores for rendering
    2020-07-02 20:25:00.919 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2020-07-02 20:25:00.919 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-07-02 20:25:00.919 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CPU: Processing scene...
    2020-07-02 20:25:00.919 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing Embree
    2020-07-02 20:25:00.974 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Importing lights for motion time 0
    2020-07-02 20:25:00.975 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing light hierarchy.
    2020-07-02 20:25:00.975 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Light hierarchy initialization took 0.000s
    2020-07-02 20:25:00.980 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Native CPU code generated in 0.000s
    2020-07-02 20:25:00.981 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CPU: Scene processed in 0.061s
    2020-07-02 20:25:00.987 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CPU: Allocated 12.363 MiB for frame buffer
    2020-07-02 20:25:01.175 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00001 iterations after 0.247s.
    2020-07-02 20:25:01.176 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-07-02 20:25:01.176 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Native CPU code generated in 0.000s
    2020-07-02 20:25:01.373 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00002 iterations after 0.444s.
    (snipped)
    2020-07-02 20:25:07.065 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00029 iterations after 6.136s.
    2020-07-02 20:25:07.487 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2020-07-02 20:25:07.489 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2020-07-02 20:25:07.502 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
    2020-07-02 20:25:07.502 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2020-07-02 20:25:07.539 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 370k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 370k triangles, 0 fiber instances yielding 0 segments) took 0.037s
    2020-07-02 20:25:07.539 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2020-07-02 20:25:07.558 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 313 textures, 0 lambdas (0 unique)
    2020-07-02 20:25:07.563 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2020-07-02 20:25:07.563 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2020-07-02 20:25:07.563 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2020-07-02 20:25:07.563 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2020-07-02 20:25:07.564 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2020-07-02 20:25:07.565 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2020-07-02 20:25:07.567 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 12 cores for rendering
    2020-07-02 20:25:07.567 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2020-07-02 20:25:07.567 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-07-02 20:25:07.567 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CPU: Processing scene...
    2020-07-02 20:25:07.568 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing Embree
    2020-07-02 20:25:07.610 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Importing lights for motion time 0
    2020-07-02 20:25:07.610 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing light hierarchy.
    2020-07-02 20:25:07.611 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Light hierarchy initialization took 0.000s
    2020-07-02 20:25:07.616 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Native CPU code generated in 0.000s
    2020-07-02 20:25:07.616 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CPU: Scene processed in 0.049s
    2020-07-02 20:25:07.622 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CPU: Allocated 12.363 MiB for frame buffer
    2020-07-02 20:25:07.815 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00001 iterations after 0.240s.
    2020-07-02 20:25:07.817 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-07-02 20:25:07.817 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Native CPU code generated in 0.000s
    2020-07-02 20:25:08.044 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00002 iterations after 0.467s.
    (snipped)
    2020-07-02 20:25:26.875 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00090 iterations after 19.298s.
    2020-07-02 20:25:27.069 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2020-07-02 20:25:27.071 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2020-07-02 20:25:27.080 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
    2020-07-02 20:25:27.080 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2020-07-02 20:25:27.113 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 305k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 305k triangles, 0 fiber instances yielding 0 segments) took 0.033s
    2020-07-02 20:25:27.113 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2020-07-02 20:25:27.129 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 244 textures, 0 lambdas (0 unique)
    2020-07-02 20:25:27.136 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2020-07-02 20:25:27.136 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2020-07-02 20:25:27.137 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2020-07-02 20:25:27.137 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2020-07-02 20:25:27.138 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2020-07-02 20:25:27.139 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2020-07-02 20:25:27.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 12 cores for rendering
    2020-07-02 20:25:27.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2020-07-02 20:25:27.141 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-07-02 20:25:27.141 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CPU: Processing scene...
    2020-07-02 20:25:27.141 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Initializing Embree
    2020-07-02 20:25:27.187 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Importing lights for motion time 0
    2020-07-02 20:25:27.187 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Initializing light hierarchy.
    2020-07-02 20:25:27.187 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Light hierarchy initialization took 0.000s
    2020-07-02 20:25:27.193 Iray [VERBOSE] - IRAY:RENDER ::   1.4   IRAY   rend stat : Native CPU code generated in 0.000s
    2020-07-02 20:25:27.194 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CPU: Scene processed in 0.053s
    2020-07-02 20:25:27.200 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : CPU: Allocated 12.363 MiB for frame buffer
    2020-07-02 20:25:27.441 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00001 iterations after 0.292s.
    2020-07-02 20:25:27.443 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-07-02 20:25:27.443 Iray [VERBOSE] - IRAY:RENDER ::   1.4   IRAY   rend stat : Native CPU code generated in 0.000s
    2020-07-02 20:25:27.690 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00002 iterations after 0.539s.
    2020-07-02 20:25:27.938 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00003 iterations after 0.787s.
    2020-07-02 20:25:28.062 Loaded Morph Deltas in 0 min 0.1 sec.
    2020-07-02 20:25:28.069 Loaded file: CloneMichael4.dsf
    2020-07-02 20:25:28.200 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00004 iterations after 1.050s.
    2020-07-02 20:25:28.436 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00005 iterations after 1.285s.
    2020-07-02 20:25:28.699 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00006 iterations after 1.548s.
    2020-07-02 20:25:28.956 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00007 iterations after 1.805s.
    2020-07-02 20:25:29.215 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00008 iterations after 2.064s.
    2020-07-02 20:25:29.491 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00009 iterations after 2.340s.
    2020-07-02 20:25:29.734 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00010 iterations after 2.583s.
    2020-07-02 20:25:29.989 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00011 iterations after 2.838s.
    2020-07-02 20:25:30.253 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00012 iterations after 3.102s.
    2020-07-02 20:25:30.508 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00013 iterations after 3.357s.
    2020-07-02 20:25:30.557 Loaded Morph Deltas in 0 min 0.1 sec.
    2020-07-02 20:25:30.560 Loaded file: ExpandAll.dsf
    2020-07-02 20:25:30.788 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00014 iterations after 3.637s.
    (snipped)
    2020-07-02 20:25:42.298 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00057 iterations after 15.147s.
    2020-07-02 20:25:43.499 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2020-07-02 20:25:43.501 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2020-07-02 20:25:43.514 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Auto instancing compression ratio 1.00 (Full instancing compression ratio 1.00)
    2020-07-02 20:25:43.514 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2020-07-02 20:25:43.554 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 370k triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 370k triangles, 0 fiber instances yielding 0 segments) took 0.040s
    2020-07-02 20:25:43.554 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2020-07-02 20:25:43.572 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 313 textures, 0 lambdas (0 unique)
    2020-07-02 20:25:43.578 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2020-07-02 20:25:43.578 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2020-07-02 20:25:43.578 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2020-07-02 20:25:43.578 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2020-07-02 20:25:43.579 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2020-07-02 20:25:43.580 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2020-07-02 20:25:43.582 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CPU: using 12 cores for rendering
    2020-07-02 20:25:43.582 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2020-07-02 20:25:43.582 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-07-02 20:25:43.582 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CPU: Processing scene...
    2020-07-02 20:25:43.582 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing Embree
    2020-07-02 20:25:43.624 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Importing lights for motion time 0
    2020-07-02 20:25:43.624 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Initializing light hierarchy.
    2020-07-02 20:25:43.625 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : Light hierarchy initialization took 0.000s
    2020-07-02 20:25:43.630 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Native CPU code generated in 0.000s
    2020-07-02 20:25:43.630 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CPU: Scene processed in 0.048s
    2020-07-02 20:25:43.636 Iray [INFO] - IRAY:RENDER ::   1.3   IRAY   rend info : CPU: Allocated 12.363 MiB for frame buffer
    2020-07-02 20:25:43.811 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00001 iterations after 0.222s.
    2020-07-02 20:25:43.813 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2020-07-02 20:25:43.813 Iray [VERBOSE] - IRAY:RENDER ::   1.3   IRAY   rend stat : Native CPU code generated in 0.000s
    2020-07-02 20:25:44.028 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00002 iterations after 0.437s.
    (snipped)
    2020-07-02 20:28:27.287 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 00352 iterations after 163.696s.
    [second]
    2020-07-02 21:49:20.454 DEBUG: Selecting Preset: /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/Runtime/Libraries/Character/M4UrbanWear/M4UrWJacket.cr2
    2020-07-02 21:49:20.498 DEBUG: Conformer is data/SickleYield2018/RSSYM4ToG8Converter/Conformers/RSSY M4 to G8 Converter/Dress Conformer M.duf
    2020-07-02 21:49:20.501 DEBUG: START Conversion of /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/Runtime/Libraries/Character/M4UrbanWear/M4UrWJacket.cr2
    2020-07-02 21:49:20.501 DEBUG:      USING conformer /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/data/SickleYield2018/RSSYM4ToG8Converter/Conformers/RSSY M4 to G8 Converter/Dress Conformer M.duf
    2020-07-02 21:49:20.502 DEBUG: Input Filename does not have "clothing" in its path: /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/Runtime/Libraries/Character/M4UrbanWear/M4UrWJacket.cr2
    2020-07-02 21:49:20.503 DEBUG: Input Filename does not have "accessories" in its path: /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/Runtime/Libraries/Character/M4UrbanWear/M4UrWJacket.cr2
    2020-07-02 21:49:20.504 DEBUG: Found alternate root directory "Character"
    2020-07-02 21:49:20.504 DEBUG: Converting clothing from /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/Runtime/Libraries/Character/M4UrbanWear/M4UrWJacket.cr2 to /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/People/Genesis 8 Male/Clothing/M4UrbanWear/M4UrWJacket.duf
    2020-07-02 21:49:20.506 DEBUG: Apply Preset /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/Runtime/Libraries/Character/M4UrbanWear/M4UrWJacket.cr2
    2020-07-02 21:49:20.520 Importing File...
    2020-07-02 21:49:20.521 Importing M4UrWJacket.cr2 ...
    2020-07-02 21:49:20.686 Reading M4UrWJacket1.obj
    2020-07-02 21:49:20.964 PZ3Importer: Removing face group M4UrWJacket no associated node.
    2020-07-02 21:49:20.981 File imported in: 461.057 ms
    2020-07-02 21:49:21.116 Loaded image M4UrWJacketTx.jpg
    2020-07-02 21:49:21.167 Loaded image M4UrWJacketTr.jpg
    2020-07-02 21:49:21.191 Imported file: /Volumes/Seagate 4TB/DAZ/My DAZ 3D Library/Runtime/Libraries/Character/M4UrbanWear/M4UrWJacket.cr2
    2020-07-02 21:49:21.192 Building Scene...
    2020-07-02 21:49:21.192 File loaded in 0 min 0.6 sec.
    2020-07-02 21:49:21.196 Loaded file: M4UrWJacket.cr2
    2020-07-02 21:49:21.244 DEBUG: M4UrWJacket (Unknown) is not a clothing item of Follower/Wardrobe,Follower/Accessory
    [first]
    (snipped)
    (snipped)
    (snipped)
    (snipped)
    [second]
    The first bit of the log looks like you had Iray Preview on and I don't see a conversion.  The second part is incomplete but it looks like the converter found the item to not be a clothing item.  Try SELECTing (i.e., HIGHLIGHT, not just checking) the clothing item in the dialog and click "Force Convert Item(s)"  Does it say the conversion is successful?  Did it work?
    edited July 2020
    Highlighting and Force Convert seemed to have done the trick! It took much more time than before (abt 2h total) which was a sign that things were being done... I then retried putting the same clothing on and it actually fitted G8M like a glove without me having to "parent to" or "fit to"! :)
    A lot of my M4 items are still in Lost and Found, which is fine... I actually prefer them there than scattered all over in Smart Content > Items.
    Finally, any idea why my leather jacket (open, no zip) became swimming floats? hahah should I reconvert it and perhaps choose a more accurate mould?
    540 x 570 - 87K
    Post edited by DMax on
    The gray blocks are a sign it cannot find the .dsf files.  First, are you on a Mac or PC?  (Macs can have issues where they protect directories which means not everything can be written or read).  Otherwise, make sure the .dsf it says are missing actually exist.
    I use a Mac indeed. Thanks so much for the insights and after-sales support - much appreciated.
    Ooooh, I got it right! laugh  Were you able to fix it?
    I checked and I do have Read/Write access to the Runtime.../Character directory for that particular product. I will look again tomorrow morning for the .dsf you mentioned, will check the log for more details. Will update! But I will officially move over to a PC in a week's time so all these troubles may be gone :)
    Ok, understood.
  • Hey! I'm trying to convert this dress using this converter:
    https://www.daz3d.com/renaissance-romance
    I have it selected in the covnerter, I'm clicking "force convert" and it will not convert. I have restarted DAZ multiple times to no avail.
    Here is the log:
    15:06:13 GMT-0500 (Central Daylight Time): WARNING: Forcing Conversion of Clothing Items
    15:06:13 GMT-0500 (Central Daylight Time): Executing Script
    15:06:13 GMT-0500 (Central Daylight Time): Selecting Preset: D:/Downloads/rromancegown.cr2
    15:06:13 GMT-0500 (Central Daylight Time): Input Filename does not have "clothing" in its path: D:/Downloads/rromancegown.cr2
    15:06:13 GMT-0500 (Central Daylight Time): Input Filename does not have "accessories" in its path: D:/Downloads/rromancegown.cr2
    15:06:13 GMT-0500 (Central Daylight Time): Input Filename does not have "character" in its path: D:/Downloads/rromancegown.cr2
    15:06:13 GMT-0500 (Central Daylight Time): Input Filename does not have "props" in its path: D:/Downloads/rromancegown.cr2
    15:06:15 GMT-0500 (Central Daylight Time): Execution Complete.
  • hello i'm trying to convert a military tunic to genesis 8, there are 4 models, one has been converted and the others have not. could someone help? already unchecked the check content type option and tried force convert and nothing.
    https://www.renderosity.com/mod/bcs/?ViewProduct=123221
    14:22:56 GMT-0300 (-03): Adding Files...
    14:22:56 GMT-0300 (-03):    Adding "Follower/Wardrobe/Unknown" file: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36_SS.cr2
    14:22:56 GMT-0300 (-03):    Adding "Follower/Wardrobe/Unknown" file: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36.cr2
    14:22:56 GMT-0300 (-03):    Adding "Follower/Wardrobe/Unknown" file: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43_SS.cr2
    14:22:56 GMT-0300 (-03):    Adding "Follower/Wardrobe/Unknown" file: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2
    14:31:55 GMT-0300 (-03): WARNING: Forcing Conversion of Clothing Items
    14:31:55 GMT-0300 (-03): Executing Script
    14:31:56 GMT-0300 (-03): Selecting Preset: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36_SS.cr2
    14:31:56 GMT-0300 (-03): Input Filename does not have "clothing" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36_SS.cr2
    14:31:56 GMT-0300 (-03): Input Filename does not have "accessories" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36_SS.cr2
    14:31:56 GMT-0300 (-03): Found alternate root directory "Character"
    14:31:56 GMT-0300 (-03): Converting clothing from /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36_SS.cr2 to /Users/Shared/My DAZ 3D Library/My Library/genesis8/female/clothing/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36_SS.duf
    14:32:00 GMT-0300 (-03): Preset loaded multiple objects.  Aborting conversion for /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36_SS.cr2
    14:32:04 GMT-0300 (-03): Selecting Preset: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36.cr2
    14:32:04 GMT-0300 (-03): Input Filename does not have "clothing" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36.cr2
    14:32:04 GMT-0300 (-03): Input Filename does not have "accessories" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36.cr2
    14:32:04 GMT-0300 (-03): Found alternate root directory "Character"
    14:32:04 GMT-0300 (-03): Converting clothing from /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36.cr2 to /Users/Shared/My DAZ 3D Library/My Library/genesis8/female/clothing/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36.duf
    14:32:07 GMT-0300 (-03): Preset loaded multiple objects.  Aborting conversion for /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M36.cr2
    14:32:10 GMT-0300 (-03): Selecting Preset: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43_SS.cr2
    14:32:10 GMT-0300 (-03): Input Filename does not have "clothing" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43_SS.cr2
    14:32:10 GMT-0300 (-03): Input Filename does not have "accessories" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43_SS.cr2
    14:32:10 GMT-0300 (-03): Found alternate root directory "Character"
    14:32:10 GMT-0300 (-03): Converting clothing from /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43_SS.cr2 to /Users/Shared/My DAZ 3D Library/My Library/genesis8/female/clothing/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43_SS.duf
    14:32:14 GMT-0300 (-03): Preset loaded multiple objects.  Aborting conversion for /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43_SS.cr2
    14:32:17 GMT-0300 (-03): Selecting Preset: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2
    14:32:17 GMT-0300 (-03): Input Filename does not have "clothing" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2
    14:32:17 GMT-0300 (-03): Input Filename does not have "accessories" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2
    14:32:17 GMT-0300 (-03): Found alternate root directory "Character"
    14:32:17 GMT-0300 (-03): Converting clothing from /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2 to /Users/Shared/My DAZ 3D Library/My Library/genesis8/female/clothing/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.duf
    14:32:20 GMT-0300 (-03): Preset loaded multiple objects.  Aborting conversion for /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2
    14:32:23 GMT-0300 (-03): Execution Complete.
  • contedesfeescontedesfees Posts: 299
    edited August 2020
    Can someone please explain why my every attempt to convert a V4 top or skirt results in a popup messagebox titled Execution Succesful and reading "Execution completed in x seconds on 0 clothing items?" This popup message occurs whether I use Add Files or Add Directory. I have unchecked both the "Check Content Type" and the "Ignore Daz bought files" options. Curiously, the clothing appears for an instant on the G8F figure during execution. Unsurprisingly, nothing is written to the output directory. Finally, choosing "Force Convert Items" produces a popup messagebox reading that "No items are selected. Please select some items and try again!" BAFFLING!
    Thanks to all.
    Post edited by contedesfees on
    Here is the log:
    First @horse1412000, I apologize.  I have this thread bookmarked but got no notification.
    The script requires the item to be installed in a path that includes "Clothing", "Accessories", "Character" or "Props", e.g., D:\Documents\My DAZ 3D Library\Runtime\Libraries\Props or something like that.  You can probably add one of those and copy the gown there, i.e., D:/Downloads/Clothing/rromancegown.crw
    I need to apologize to you as well @junior_franc.  I am just seeing your message now.  As the log states, the preset is loading multiple objects.  If you create a new preset with only one item loaded, that should work.
    Thanks to all.
    You are able to add the items but not convert them?  Then select one (i.e., HIGHLIGHT it) and then click "Force Convert"
    edited August 2020
    Thanks to all.
    Thank you so very much; it's appreciated. It seems, I suppose, that I have some terribly ancient V4 apparel, products I'd hate to abandon BTW. But why is it necessary to highlight one item at a time? I was under the impression that items listed in the converter UI with a check in the check box were selected.
    Thanks to all.
    They are checked but not selected.  The normal "Execute" button goes through the list, loads items, makes sure their metadata is correct (i.e., clothing), and then tries to convert them.  If the metadata is not correct, it skips that item.  The idea is that you should look at those items and make sure they really are clothing (e.g., you could have added a character, etc)  If you are sure, select (HIGHLIGHT) them (you can use SHIFT and CTRL to select a lot of items at once) and "Force Convert" them.
    10:07:47 GMT-0300 (-03): WARNING: Forcing Conversion of Clothing Items
    10:07:47 GMT-0300 (-03): Executing Script
    10:07:47 GMT-0300 (-03): Selecting Preset: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2
    10:07:47 GMT-0300 (-03): Input Filename does not have "clothing" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2
    10:07:47 GMT-0300 (-03): Input Filename does not have "accessories" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2
    10:07:47 GMT-0300 (-03): Found alternate root directory "Character"
    10:07:47 GMT-0300 (-03): Converting clothing from /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2 to /Users/Shared/My DAZ 3D Library/My Library/People/Genesis 8 Female/Clothing/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.duf
    10:07:52 GMT-0300 (-03): Preset loaded multiple objects.  Aborting conversion for /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_M43.cr2
    10:07:55 GMT-0300 (-03): Execution Complete.
    thanks for the reply friend, unfortunately i did what you said and it didn't work.
    It is still showing that yor preset, GinfV4_Tunic_M43.duf, is loading multiple objects.  If I remember correctly, I believe the Tannenbaum items don't work cleanly because even pockets are separate objects.
  • junior_francjunior_franc Posts: 3
    edited August 2020
    19:45:10 GMT-0300 (-03): WARNING: Forcing Conversion of Clothing Items
    19:45:10 GMT-0300 (-03): Executing Script
    19:45:11 GMT-0300 (-03): Selecting Preset: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.cr2
    19:45:11 GMT-0300 (-03): Input Filename does not have "clothing" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.cr2
    19:45:11 GMT-0300 (-03): Input Filename does not have "accessories" in its path: /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.cr2
    19:45:11 GMT-0300 (-03): Found alternate root directory "Character"
    19:45:11 GMT-0300 (-03): Converting clothing from /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.cr2 to /Users/Shared/My DAZ 3D Library/My Library/People/Genesis 8 Female/Clothing/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.duf
    19:45:17 GMT-0300 (-03): Directory does not exist: /Users/Shared/My DAZ 3D Library/My Library/People/Genesis 8 Female/Clothing/Tannenbaum/German_Infantry_V4
    19:45:57 GMT-0300 (-03):      Copy Icons from /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.cr2 to /Users/Shared/My DAZ 3D Library/My Library/People/Genesis 8 Female/Clothing/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.duf
    19:45:57 GMT-0300 (-03):      Copy Categories from /Users/Shared/My DAZ 3D Library/Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.cr2 to /Users/Shared/My DAZ 3D Library/My Library/People/Genesis 8 Female/Clothing/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.duf
    19:45:57 GMT-0300 (-03):      Cannot find assets for old preset /Runtime/Libraries/Character/Tannenbaum/German_Infantry_V4/GinfV4_Tunic_Camo.cr2
    19:46:03 GMT-0300 (-03): Execution Complete.
    this is the log stats of the converted tunic. The tunics are very similar, is there a way to convert to the one I had a problem with?
    Post edited by junior_franc on
