Some products not updating
I have a few products that show up in the Updates tab.  When I right-click on the little circle-arrow in the upper-right corner of the icon and select Install Updates, it looks like it is working, but when it is all done, it still shows it needs updating.
Here's what I've tried...
  • Deleting product and re-installing
  • Updating Metadata, and then selecting Install updates
It is also important to note that many other updates work just fine.
Here's what my log file shows...
2020-06-20 11:02:42.969 Beginning Update of "Sea Shanty Props"
2020-06-20 11:02:43.318 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file Zero Bodhr¯n Beater.png props/merlin/sea shanty props/3delight/zero bodhr¯n beater.png in product Sea Shanty Props 70141
2020-06-20 11:02:43.318 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file Zero Bodhr¯n.png props/merlin/sea shanty props/3delight/zero bodhr¯n.png in product Sea Shanty Props 70141
2020-06-20 11:02:43.318 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file Zero Bodhr¯n.png props/merlin/sea shanty props/iray/zero bodhr¯n.png in product Sea Shanty Props 70141
2020-06-20 11:02:43.318 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file Zero Bodhr¯n Beater.png props/merlin/sea shanty props/iray/zero bodhr¯n beater.png in product Sea Shanty Props 70141
2020-06-20 11:02:43.334 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Could not find URL for file MRLN_Bodhr¯nSkinS.jpg runtime/textures/merlin/sea shanty props/mrln_bodhr¯nskins.jpg in product Sea
... lines deleted for space...
2020-06-20 11:09:33.633 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): Failed to download output file "B:/poseruser/documents/DAZ 3D/Studio/My Daz Connect Library\data\cloud\1_70141\props/merlin/sea shanty props/3delight/genesis 8 female bodhr¯n.duf.part"
2020-06-20 11:09:33.894 "Sea Shanty Props": Update Failed.
  • Richard HaseltineRichard Haseltine Posts: 111,420
    Yes, this is a known issue - it's because of the accented a in the item name.
  • TesseractSpaceTesseractSpace Posts: 1,583
    I've found for some items, downloading the offline connect install files and installing them fixes whatever it is that gets stuck in Update mode.  The Sea Shanty set has that additional accent mark issue, but this worked for getting it out of Update, even if the broken instrument is still broken due to the accent.
    Is it being fixed? I haven't seen any posts on the subject since the original mentions over on the "sale problems" thread.
    As far as I know
